Snakehead321
2.4 ghz Rii Mini keyboard trackpad issues
Sat Aug 18, 2012 4:49 am
I am having difficulties with my keyboard trackpad combo trackpad. Most of the times I try to use the trackpad, the cursor will jump down to the bottom of the screen and become stuck. I can still move it left to right, just not up. Please advise
Reider
Re: 2.4 ghz Rii Mini keyboard trackpad issues
Sat Aug 18, 2012 11:15 am
You didn't say what Distro you're using but try this. The next time you open the desktop with STARTX be prepared for when it opens. Move the cursor to the top of the screen and hold it there while the desktop GUI continues loading. It should then stop getting stuck at the bottom, by the taskbar. I read this somewhere else and tried it then put my Rii mini keyboard/trackpad back into use. It's worked perfectly ever since.
Steve
mahjongg
Sat Aug 18, 2012 11:39 am
Are you running a wired keyboard with trackpad directly on the PI?
I hope the current use of the device doesn't exceed 100mA, (because it needs to also have a full hub inside for the trackpad) or you might have problems due to the polyfuses in the PI's USB port, which may lower the working voltage for the peripheral to unacceptable low values.
If however you are using a wireless device then its fine, as the bluetooth adapter itself probably uses far less than 100mA.
In general peripherals using more than 100mA must be powered by an externally powered hub.
Snakehead321
Sat Aug 18, 2012 1:24 pm
Reider wrote:You didn't say what Distro you're using but try this. The next time you open the desktop with STARTX be prepared for when it opens. Move the cursor to the top of the screen and hold it there while the desktop GUI continues loading. It should then stop getting stuck at the bottom, by the taskbar. I read this somewhere else and tried it then put my Rii mini keyboard/trackpad back into use. It's worked perfectly ever since.
Steve
I'm using The Debian image, and your fix didn't work, it just got stuck again once I tried moving it.
@other poster, I say 2.4 ghz keyboard in my title, means wireless, so the wired things don't apply to me
Reider
Sat Aug 18, 2012 3:33 pm
Surprising it didn't work, it's worked in all Distros I tried so far. Although theirs more than one type of Rii keyboard/trackpad.
Steve
Snakehead321
Sat Aug 18, 2012 11:12 pm
Reider wrote:Surprising it didn't work, it's worked in all Distros I tried so far. Although theirs more than one type of Rii keyboard/trackpad.
Steve
I've tried several more times and when it does allow me to move to the top, the moment I touch it again it jumps to the bottom
ftag
Sun Aug 19, 2012 4:36 pm
Hi fellows, I have a Rii touch N7 and tested it with both raspian and Fedora 17 remix. The solution is still far to come in my case. Yes, it is true that pointing the cursor on the top of the screen gives control on it through the trackpad, but it doesn't last for more than 2 minutes or so.
This was tested on raspian, since here we are given a text login and we write startx on the shell; the Fedora 17 has an automatic X start. I am prompted with a graphical login and, by the time I type user and password, the cursor is suddenly stuck at the bottom of the screen.
It is really sad I had been waiting this keboard to come from China, and when it has arrived to my home I trusted that it would have worked, since in every Web page about this product, it's told that it's fully compatible with Linux systems. I have Ubuntu on my pc and I haven't tested the Rii there still. I will do this and post here the result, in the coming days.
ftag
Wed Aug 22, 2012 4:58 pm
Hi everybody, after a long test on Ubuntu with this model of mini keyboard I found out that it works very well. Touchpad and keys. Thus I thought that the problem might be on RPi's poor default system tools in order to recognize and set the monitor resolution and the refresh rate. The very same pc monitor to which both ubuntu and RPi are connected is set by Ubuntu at 1280x1024, and by Raspian at 1154x898 of resolution. I am going to chase data about it. Feel free to post me any link available to improve the monitor resolution on RPi
jutleys
Sun Sep 30, 2012 7:03 am
I thought the 2.4ghz model works out the box but it's not working for me in wheezy or rasbmc I tried it on normal windows machine works fine do I need to unload a previous wireless keyboard driver any ideas?
shellback3
Sun Dec 02, 2012 3:25 am
I just received my RP and RII 2.4 GHz keyboard. The keyboard works just fine on Ubuntu 11.10 and Mac Mountain Lion but not on Wheezy where the cursor is stuck at the bottom of the display. I did notice that the RP was unable to figure out the display dimensions and wonder if this is part of the problem. I'm kind of a beginner in LINUX. I don't own a USB keyboard or mouse and don't really want to make the purchase. Any ideas?
cito
Tue Dec 11, 2012 3:02 am
I just bought this and the mouse cursor gets stuck at the bottom also
i noticed in xorg.conf.d there are 2 "touchpad" configs getting loaded
in /usr/share/X11/xorg.conf.d I have
10-evdev.conf that comments say is a "catch-all" for trackpads/touchpads
and
50-synaptics.conf
which has references to evdev and some numbers
I havent tried adjusting any of them as both of the comment sections say to not touch anything and that these 2 files are auto loaded and installed when touchpads/etc are detected
anyhow i can get it to work after unplugging the wifi dongle, plugging it back in, rebooting, then sometimes it works perfectly, when it works it works forever until rebooted.
then mouse cursor get stuck at bottom again, I wish there was a mouse driver like gdm I could just restart like killall -HUP to force a reset of the mouse driver.
But I don't see anything like that for rasbian.
Anyhow running latest rasbian, on a revision 2 raspi board, on a fully upgraded distro, with a brand new RII mini wireless 2.4ghz combat keyboard/trackpad.
the Rii works on my laptop (windows 7) / my 3 desktops (slackware linux / windows xp / windows 7) and works on my android tablet.
so i know it's not a defective item. And I am using the same powered usb hub advertised on the main site and linked to hundreds of times here: http://www.youtube.com/watch?v=pDA7MxFtoS0
So I know the power is fine, unless it's defective board or OS problem.
nikasio
Fri Dec 21, 2012 7:29 pm
Hi, I bought an iPazzPort RF 2.4Ghz and I'm experimenting the same problem as the rest, the cursor stays in the bottom of the screen. The only diffenrence is that I'm not using a usb powered hub.
That could solve my problem?
benrogerson
Sun Jan 06, 2013 1:07 pm
Hi
I bought an Anker Wireless Handheld keyboard (model KP-810-10A). It uses 2.4Ghz wireless and I've had the same issue with the cursor being stuck the the bottom of the screen. Seems to work fine on my win7 machine.
I tried removing the usb dongle and and put it back in as @cito suggested. Putting it back caused the Pi to reset itself (not sure if this is normal behaviour) but when it re-started the trackpad was working fine. I'm using wheezy, an HTC phone charger as power source and have an Edimax wifi dongle in the other USB port.
theoB610
Fri Jan 11, 2013 5:00 pm
I think that this should be brought to a bit more attention, as no suggested fix works all the time (apparently).
I'm experiencing exactly the same thing- cursor gets stuck at bottom of screen, tried different fixes, didn't work.
Possibly try something with raspi-config changing keyboard settings- mine was not on there so I'm not sure what to do.
Can someone with a bit more knowledge give us help?
theoB610
Sun Jan 13, 2013 10:09 am
qwerty489
Sat Jan 19, 2013 6:49 pm
I'm has having exactly the same problem: cursor gets stuck at bottom of screen.
When unplugging the wifi dongle and plugging it back the touchpad works perfectly.
Then I make a new sd from the last raspberry image and run it for the firts time using the Wiffi keyboard/touchpad and surprisely it begins working fine everytime.
qwerty489
Sun Jan 20, 2013 6:20 pm
Sorry. :cry: :cry:
After beeing disconnet for some time the problem reapears: cursor gets stuck at bottom of screen until the dongle is unpluged/pluged.
jefeti61
Sat Feb 09, 2013 5:05 pm
i solved it by removing the dongle from the USB port, than I restarted the raspberry-pi and during the start-up I put the dongle in the USB port.
After starting startx, I was able to move the pointer with the though pad.
htaccess
Sat Mar 02, 2013 4:00 am
I would edit my previous post but its lost in some sort of moderation limbo, who knows how long for.
I am pretty sure this problem can be solved by tweaking the xorg config. I don't have the knowledge to do this but am posting information that may be useful to someone who does:
---------------------------------------------------8<-------------------------------------------
pi@raspberrypi ~ $ cat /proc/bus/input/devices
I: Bus=0003 Vendor=0c45 Product=7000 Version=0111
N: Name="RCMCU 2.4GHz receiver"
P: Phys=usb-bcm2708_usb-1.2/input0
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
U: Uniq=
H: Handlers=sysrq kbd event0
B: PROP=0
B: EV=120013
B: KEY=800000 0 e0b0ffdf 1cfffff ffffffff fffffffe
B: MSC=10
B: LED=1f
P: Phys=usb-bcm2708_usb-1.2/input1
S: Sysfs=/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
U: Uniq=
H: Handlers=kbd mouse0 event1
B: PROP=0
B: EV=1f
B: KEY=4837fff 72ff32d bf544446 0 0 1f0001 20f90 8b17c000 677bfa d941dfed 9ed680 4400 0 10000002
B: REL=143
B: ABS=1 0
B: MSC=10
relevant parts of /var/log/Xorg.0.log
[ 28.667] (II) config/udev: Adding input device RCMCU 2.4GHz receiver (/dev/input/event0)
[ 28.667] (**) RCMCU 2.4GHz receiver: Applying InputClass "evdev keyboard catchall"
[ 28.667] (II) LoadModule: "evdev"
[ 28.669] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 28.682] (II) Module evdev: vendor="X.Org Foundation"
[ 28.683] compiled for 1.12.1, module version = 2.7.0
[ 28.683] Module class: X.Org XInput Driver
[ 28.683] ABI class: X.Org XInput driver, version 16.0
[ 28.683] (II) Using input driver 'evdev' for 'RCMCU 2.4GHz receiver'
[ 28.684] (**) RCMCU 2.4GHz receiver: always reports core events
[ 28.684] (**) evdev: RCMCU 2.4GHz receiver: Device: "/dev/input/event0"
[ 28.684] (--) evdev: RCMCU 2.4GHz receiver: Vendor 0xc45 Product 0x7000
[ 28.685] (--) evdev: RCMCU 2.4GHz receiver: Found keys
[ 28.685] (II) evdev: RCMCU 2.4GHz receiver: Configuring as keyboard
[ 28.685] (**) Option "config_info" "udev:/sys/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0/event0"
[ 28.685] (II) XINPUT: Adding extended input device "RCMCU 2.4GHz receiver" (type: KEYBOARD, id 6)
[ 28.685] (**) Option "xkb_rules" "evdev"
[ 28.686] (**) Option "xkb_model" "pc105"
[ 28.686] (**) Option "xkb_layout" "gb"
[ 29.232] (II) config/udev: Adding input device RCMCU 2.4GHz receiver (/dev/input/event1)
[ 29.232] (**) RCMCU 2.4GHz receiver: Applying InputClass "evdev pointer catchall"
[ 29.232] (**) RCMCU 2.4GHz receiver: Applying InputClass "evdev keyboard catchall"
[ 29.232] (II) Using input driver 'evdev' for 'RCMCU 2.4GHz receiver'
[ 29.233] (**) RCMCU 2.4GHz receiver: always reports core events
[ 29.233] (**) evdev: RCMCU 2.4GHz receiver: Device: "/dev/input/event1"
[ 29.233] (--) evdev: RCMCU 2.4GHz receiver: Vendor 0xc45 Product 0x7000
[ 29.233] (--) evdev: RCMCU 2.4GHz receiver: Found 9 mouse buttons
[ 29.233] (--) evdev: RCMCU 2.4GHz receiver: Found scroll wheel(s)
[ 29.234] (--) evdev: RCMCU 2.4GHz receiver: Found relative axes
[ 29.234] (--) evdev: RCMCU 2.4GHz receiver: Found x and y relative axes
[ 29.234] (--) evdev: RCMCU 2.4GHz receiver: Found absolute axes
[ 29.234] (II) evdev: RCMCU 2.4GHz receiver: Forcing absolute x/y axes to exist.
[ 29.234] (--) evdev: RCMCU 2.4GHz receiver: Found keys
[ 29.234] (II) evdev: RCMCU 2.4GHz receiver: Configuring as mouse
[ 29.234] (II) evdev: RCMCU 2.4GHz receiver: Configuring as keyboard
[ 29.235] (II) evdev: RCMCU 2.4GHz receiver: Adding scrollwheel support
[ 29.235] (**) evdev: RCMCU 2.4GHz receiver: YAxisMapping: buttons 4 and 5
[ 29.235] (**) evdev: RCMCU 2.4GHz receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 29.235] (**) Option "config_info" "udev:/sys/devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1/event1"
[ 29.236] (II) XINPUT: Adding extended input device "RCMCU 2.4GHz receiver" (type: KEYBOARD, id 7)
[ 29.236] (**) Option "xkb_rules" "evdev"
[ 29.236] (**) Option "xkb_model" "pc105"
[ 29.236] (**) Option "xkb_layout" "gb"
[ 29.239] (II) evdev: RCMCU 2.4GHz receiver: initialized for relative axes.
[ 29.239] (WW) evdev: RCMCU 2.4GHz receiver: ignoring absolute axes.
[ 29.241] (**) RCMCU 2.4GHz receiver: (accel) keeping acceleration scheme 1
[ 29.241] (**) RCMCU 2.4GHz receiver: (accel) acceleration profile 0
[ 29.241] (**) RCMCU 2.4GHz receiver: (accel) acceleration factor: 2.000
[ 29.242] (**) RCMCU 2.4GHz receiver: (accel) acceleration threshold: 4
[ 29.245] (II) config/udev: Adding input device RCMCU 2.4GHz receiver (/dev/input/mouse0)
[ 29.245] (II) No input driver specified, ignoring this device.
[ 29.245] (II) This device may have been added with another device file.
[ 29.292] (EE) FBDEV(0): FBIOBLANK: Operation not permitted
jackokring
Sat Mar 02, 2013 1:08 pm
I have this keyboard, the non bluetooth one. It works fine for me on latest Raspbian. I have framebuffer size set it /boot/config.txt, if that helps. I also use it via a powered hub. It is not interference from WiFi or bluetooth, as I also have both these types of dongle installed.
