Mirukai
My RPi2's Public IP is the same as my laptop's!
Tue Jul 05, 2016 3:31 pm
As you can tell from the title, this is very annoying when setting up Dynu DNS, as it automatically routes to my laptop, which has no server software on it, instead of my Pi, which has Apache2 and a Minecraft Server on.
I did on my Pi:
wget http://ipecho.net/plain -O - -q | pico plain
And it gave me 188.220.74.40, and then I went to IPChicken.com on my laptop and it gave me the same.
When you navigate to the IP, which I don't mind you doing, it puts you on the Apache2 Debian Default Page, but when using a DNS, it gets confused between the two devices! Please help me out!!
Mirukai
ghans
Re: My RPi2's Public IP is the same as my laptop's!
Tue Jul 05, 2016 3:37 pm
This is normal. Your home router does NAT just like
it was designed to.
Simply set up port forwarding correctly in your routers
control panel and Dynamic DNS will work (outside your
home network at least - some home routers don't support NAT
loopback).
You should always test your dynamic DNS setup
from a public library , Starbucks or over 3G.
ghans
Mirukai
Tue Jul 05, 2016 4:00 pm
I have a Sky Router, any way to do that NAT Loopback you're talking about on that?
ghans
Tue Jul 05, 2016 4:07 pm
"NAT loopback" or "NAT hairpin" is a router feature (and
it should be enabled by default ?!). You need the router
manual/product brief to know if your router has it.
Check your ISP website for router manuals (good luck) or
ask your ISP hotline. Perhaps you can use manuals for
the orginal "base" model your router was rebranded from.
Using services like "is this website down" or
"Online Port Scanners" is probably easier ... or lend or beg
a smartphone with 3G and test it that way.
ghans
Mirukai
Tue Jul 05, 2016 4:19 pm
Ah, cheers, but now I have another problem... My Apt-get is broken...
This is the error it throws at me.
root@raspberrypi:/var/www/html# sudo apt-get install vsftpd
Reading package lists... Error!
W: Encountered status field in a non-version description
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
AGH!! What now?!
FlexibleSigmoid
Tue Jul 05, 2016 6:58 pm
Learn to search for your error messages, there's a ton of resources available if you Google the last error line.
Mirukai
Tue Jul 05, 2016 7:41 pm
Yup, googling last error message helped me, thanks! I will do this from now on.
Tue Jul 05, 2016 9:29 pm
BTW, whatever you do, DO NOT open ports 20/21 to the public internet.
Mirukai
Mon Jul 11, 2016 3:40 pm
Why should I leave port 20 closed? I know FTP is meant to be secure, but why 20?
epoch1970
Mon Jul 11, 2016 5:00 pm
FTP active uses both 20/tcp and 21/tcp.
You can lookup ports for well-known protocols in /etc/services or over the internet.
Tue Jul 12, 2016 6:06 pm
Mirukai wrote:Why should I leave port 20 closed? I know FTP is meant to be 100% totally, completely insecure, but why 20?
FTFY
If you need to accept files from the public internet use sshd/sftp or Apache2 with libcommons-fileupload
Both of those actually have a semblance of security.
mfa298
Wed Jul 13, 2016 8:14 am
FTFY
Although please change the pi users password first (and ideally create a new user and remove the pi user). Personally I'd also suggest not running ssh on port 22.
Having a pi with ssh on port 22 and the default pi:raspberry credentials accessible to the internet is arguably less secure than ftp. SSH is only as secure as it's been set up to be, if the credentials are easily guessable it's not very secure.
