GianfrancoPa
Usb power issues: how fix it?
Thu Sep 06, 2012 7:36 am
I read in Internet (http://himeshp.blogspot.se/2012/07/rasp ... imate.html) that to fix usb power problems, it is necessary to use two 1ohm resistors on F1 and F2 fuses.
Today I read on Raspberry main site (http://www.raspberrypi.org/archives/1929) that the revision n2 of Raspberry will fix the problem "replacing the fuses with links". So, is not necessary the use of resistors??
Thanks at all!!
RaTTuS
Re: Usb power issues: how fix it?
Thu Sep 06, 2012 7:53 am
if you have rev 2 of the board then you dont need to do anything
if you don't have rev 2 then it will work fine as long as you use a good powered usb hub or you bridge the 2 fuses [0ohm]
Covfefe
Thu Sep 06, 2012 8:51 am
And also use the most up to date distro, which has fixes for USB issues. This fixing is still ongoing, so keep things updated and things will only get better!
pluggy
Thu Sep 06, 2012 9:44 am
I just short circuited my USB polyfuses with copper wire from some old cat 5 cable.
The 1 ohm resistors are to reduce possible surges through the main polyfuse if you're powering through the Micro USB connector (which I don't) when plugging in heavy current USB devices.
redhawk
Thu Sep 06, 2012 9:54 am
snap :D
Just be careful not to solder anything else to the board and you should be alright.
Richard S.
pluggy
Thu Sep 06, 2012 10:00 am
Your soldering is neater than mine, my excuse is the peepers aren't what they used to be.....
GianfrancoPa
Thu Sep 06, 2012 10:01 am
So, if I've used the two resistors, It's ok?
pluggy
Thu Sep 06, 2012 10:22 am
Assuming it works, yes. Later boards have 0 ohm resistors instead of polyfuses and the latest boards have had them removed altogether. The short circuit method is now "legitimate" but 1 ohm resistors across there won't hurt.
