DirkS
Re: Rpi3 + Usb + Samba - problem with copying large files
Sun Jul 22, 2018 6:45 am
IngoKnito wrote:
Sun Jul 22, 2018 6:37 am
How can i find out the exact version rahter than 'uname -a'?
cat /etc/os-release
should give more information
IngoKnito
Sun Jul 22, 2018 6:48 am
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
DirkS
Sun Jul 22, 2018 6:55 am
Forgot to ask: what is the output of
apt-cache policy raspberrypi-kernel
IngoKnito
Sun Jul 22, 2018 6:57 am
raspberrypi-kernel:
Installed: 1.20180703-1
Candidate: 1.20180703-1
Version table:
*** 1.20180703-1 500
500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
100 /var/lib/dpkg/status
Sun Jul 22, 2018 7:42 am
Uname -a is the right thing to try, 4.14.34 is the kernel version and 34 does not have the fix, so this here is a problem with the updating.
Just to confirm, you say you don't have wireless, but this is a 3b+?
DirkS
Sun Jul 22, 2018 7:43 am
raspberrypi-kernel:
Version table:
Your kernel version should be the same as mine...
When was the last time you rebooted your Pi?
When raspberrypi-kernel gets updated it needs a reboot to activate the new kernel
IngoKnito
Sun Jul 22, 2018 8:38 am
After a reboot, the version is now the Latest :-)
Linux raspberrypi 4.14.52+ #1123 Wed Jun 27 17:05:32 BST 2018 armv6l GNU/Linux
Many thanks! :)
But the issue is not solved on my PI :(
Same file, same result: Network-Error with a 100 MByte-File over Samba.
I have an old PI 1 from 2011, but it looks like an software-issue not hardware.
A copy via xcopy results in "File creation error - Unexpected network error"
Now i have tested some Samba-transfers:
100 MB: Error
74 MB: Error (77.399.040 Bytes)
60 MB OK! (62.758.912 Bytes)
40 MB: OK! (40.869.888 Bytes)
35 MB: OK! (37.158.912 Bytes)
10 MB OK! (11.526.144 Bytes)
It looks like a limit around 64MB
LTolledo
Sun Jul 22, 2018 12:57 pm
OK... since the problem seemed to be a Raspberry Pi 3 model B+, here's my 2nd test setup:
A. Raspberry Pi 3 Model B+ (lets call it RPi3B+) , with
A1. Raspbian Stretch with Desktop on 32GB Sandisk Cruzerfit USB Flash memory (native USB boot, Stretch is updated and upgraded as of July 22, 2018)
A2. Ethernet connection to Ethernet Switch HUB -B
A3. Samba server and client installed, running fine
A4. 1 share folder in Ext4 format (inside 32GB USB Flash Memory)
A5. NTFS formatted 128GB Cruzerfit USB flash memory plugged into vacant USB port
A6. of the 1GB on board memory, 192MB is allocated for video because of Kodi
A7. RPi3B+ connected to HDMI monitor, 2.4GHz wireless keyboard and mouse
A8. RPi3B+ running non-stop in the last 12Hrs prior to this test
A9. PSU is 5v 2.5A
A10. I2S DAC HifiBerry clone connected to 40-pin GPIO
B. NAS (EXT4 format) connected to Ethernet Switch HUB- A
C. Ethernet Switch HUB -B connected to Ethernet Switch Hub -A
What I did.
1. Using the RPi3B+ Stretch desktop file manager, connected to the samba share of NAS
2. Selected a 4GB video file ( a single file! not a directory of smaller files)from my video collection in the NAS.
3. Copied the 4GB video file to the 128GB USB memory plugged into RPi3B+
4. Copy completed in under 10 minutes... no errors...
Using RPi3B+ copying a 4GB file over samba and saving it to USB Flash memory plugged into RPI3B+'s USB port did not produce any error or freezes
The 128GB USB Flash memory was actually connected to the RPi3B+'s USB port via USB extension cable
The same RPi3B+ am using to write this post to this forum
Just to add...an 8GB video file took 20 minutes to complete the copy from NAS to RPi3B+'s 128GB USB flash memory...
I wanted to test higher file size (10GB and up) but dont have any in my collection.
Some people be like:
LTolledo
Sun Jul 22, 2018 2:55 pm
Oh and here's some additional stuff about my setup above
~ $ apt-cache policy raspberrypi-kernel
raspberrypi-kernel:
  Version table:
~ $ uname -a
Linux RPi3BP1 4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 BST 2018 armv7l GNU/Linux
ejolson
Sun Jul 22, 2018 11:39 pm
For those reading this thread it should be emphasized that the problem you are describing occurs with a Pi 1 rather than a Pi 3. While discussing similar problems with the Pi 1 in this thread may seem logical, the root cause of the problem may be different as the hardware has changed quite a bit over the years.
Here are some ideas:
1. Maybe your USB stick is uncommonly slow or mounted as a full-speed rather than high-speed device. Check this with
sudo lsusb -t
sudo lsusb -v
and report back.
2. It might help to plug the USB stick into a different socket on the Pi. Try unplugging the keyboard and mouse, then plugging the stick into each of the 4 (or 2 if it's really old) available sockets and testing if that makes a difference.
3. The same TCP transmission segmentation offload feature that was recently broken on the Pi 3 is also problematic on the Pi 1. Try entering the command
sudo ethtool -k eth0
sudo ethtool -K eth0 tx-tcp-segmentation off
report back and check whether the problem persists.
IngoKnito
Mon Jul 23, 2018 5:11 am
Thanks for the ideas to solve the issue.
First of all: I've been using the PI for several years and my 'usb-server' worked for a longer time (~3..4 Months) perfectly with the larger files of 100 MByte. Now not anymore.
The "Stick" is a Garmin Device witch is plugged on a USB-Hub to avoid power-consumption issues.
I have no keyboard or mouse connected.
The tx-tcp-segmentation was already off.
Here the Details:
sudo lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/7p, 480M
|__ Port 4: Dev 10, If 0, Class=Mass Storage, Driver=usb-storage, 480M
sudo lsusb -v
Bus 001 Device 010: ID 091e:2673 Garmin International
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x091e Garmin International
idProduct 0x2673
bcdDevice 5.09
iManufacturer 0
iProduct 0
iSerial 5 0000e82151bf
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0005
Self Powered
Test Mode
Bus 001 Device 004: ID 2001:f103 D-Link Corp. DUB-H7 7-port USB 2.0 hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2001 D-Link Corp.
idProduct 0xf103 DUB-H7 7-port USB 2.0 hub
bcdDevice 1.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 7
wHubCharacteristic 0x002d
Per-port power switching
Compound device
Per-port overcurrent protection
TT think time 16 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 100 milli Ampere
DeviceRemovable 0xfe
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0503 highspeed power enable connect
Port 5: 0000.0100 power
Port 6: 0000.0100 power
Port 7: 0000.0100 power
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0xec00 SMSC9512/9514 Fast Ethernet Adapter
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceProtocol 255
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
Self Powered
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idProduct 0x9512 SMC9512/9514 USB Hub
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1 Single TT
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x000d
Compound device
TT think time 8 FS bits
bHubContrCurrent 1 milli Ampere
DeviceRemovable 0x02
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0503 highspeed power enable connect
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.14
iManufacturer 3 Linux 4.14.52+ dwc_otg_hcd
iProduct 2 DWC OTG Controller
iSerial 1 20980000.usb
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
Ganged power switching
bPwrOn2PwrGood 1 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
Hub Port Status:
Self Powered
Features for eth0:
Cannot get device udp-fragmentation-offload settings: Operation not supported
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: off
tx-scatter-gather: off [fixed]
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: off
tx-tcp-segmentation: off [fixed]
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp-mangleid-segmentation: off [fixed]
tx-tcp6-segmentation: off [fixed]
udp-fragmentation-offload: off
generic-segmentation-offload: off [requested on]
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: off [fixed]
tx-vlan-offload: off [fixed]
ntuple-filters: off [fixed]
receive-hashing: off [fixed]
highdma: off [fixed]
rx-vlan-filter: off [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-gre-csum-segmentation: off [fixed]
tx-ipxip4-segmentation: off [fixed]
tx-ipxip6-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-udp_tnl-csum-segmentation: off [fixed]
tx-gso-partial: off [fixed]
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off [fixed]
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: off [fixed]
Mon Jul 23, 2018 8:50 am
This thread is specifically for the 3B+. Please start another thread for any non-3B+ related issues. Once a new thread is started I will delete the non-3B+ information in this one to avoid confusion.
Reason - The 3B+ has a completely different ethernet chip on it, with a completely different driver, so its almost certain that the issues are not the same.
LTolledo
Mon Jul 23, 2018 11:15 am
@IngoKnito....
Yes please hurry up and make a new topic so I can post my test results..... for the Raspberry Pi (c)2011.12
Mon Jul 23, 2018 12:05 pm
If your results are for the 3b+ then simply post them here, if for anything else, start a new thread.
LTolledo
Mon Jul 23, 2018 1:35 pm
have already posted my test results for the RPi3B+ (7 post above this)
my reply above was for IngoKnito.....(edited it already...)
ejolson
Mon Jul 23, 2018 5:37 pm
Everything in the output looks reasonable to me. That and the fact that it was working fine before makes one think this is a 4.14.x kernel regression.
I've taken the liberty to start a new thread to further discuss this problem.
