Foa
Add / Remove Software
Sat Mar 04, 2017 6:43 pm
I got Raspberry 3 with Pixel installed.
When I use Add / Remove Software and select Firefox and press Apply it will install and also when I press OK.
But I can not find the installed Firefox and use the program.
SurferTim
Re: Add / Remove Software
Sat Mar 04, 2017 6:49 pm
I have a RPi3 with Pixel, and have Firefox installed. Reboot, click on the applications icon (top far left), then select Internet.
edit: ...and it put an icon on my desktop.
My advice applies to RaspiOS only. Please mention if you use another OS.
Foa
Sat Mar 04, 2017 7:10 pm
Thanks SurferTim but it will not be in "Internet" after reboot.
Looks strange.
SurferTim
Sat Mar 04, 2017 7:13 pm
I guess your PRi3 doesn't like you. Mine shows both in Applications/Internet and a desktop icon, and both work fine.
edit: open the terminal (command console) and type firefox. Does it start Firefox?
Foa
Sat Mar 04, 2017 7:37 pm
No I got the answer The command firefox do not exist
SurferTim
Sat Mar 04, 2017 7:50 pm
Then you did not install firefox, or installed it incorrectly.
sudo apt-get install firefox-esr
Foa
Sat Mar 04, 2017 8:50 pm
This is the result with Terminal:
http://mirrordirector.raspbian.org/raspbian/ jessie/main firefox-esr armhf 45.5.0esr-1~deb8u1
404 Not Found [IP: 93.93.128.193 80]
DirkS
Sat Mar 04, 2017 8:56 pm
Foa wrote:This is the result with Terminal:
that's not the current version.
Run
sudo apt-get update
first to update the package information
Foa
Sat Mar 04, 2017 10:18 pm
The problem is solved.
I burned an image to the SD-card and now Firefox is installed.
klricks
Sat Mar 04, 2017 10:55 pm
Foa wrote:Thanks!
Good but to avoid such drastic measures always do [Options] --> [Refresh Package Lists] or do:
sudo apt-get update
from a command line before attempting to do any install or upgrade.
Foa
Sun Mar 05, 2017 2:04 pm
Well it was not so drastic for me. Pixel was installed by using NOOBS
And I did not check the SHA-1: 9bb4b421a9a39ecbe75701de35ba9a3524b801c9
Perhaps the download was not good.
So I got some training to use ISO and Image-installation.
Again Thanks
