DavidPlumpton
rt5370 (D-Link DWA-125) Wifi not creating wlan0
Sat Sep 22, 2012 10:17 am
I'm using 2012-09-18-wheezy-raspbian and I have a D-Link DWA-125 Wifi USB dongle. The problem is that the wlan0 interface is never created.
ifconfig -a shows:
eth0 Link encap:Ethernet HWaddr b8:27:eb:34:cd:cd
inet addr:192.168.2.203 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:58 errors:0 dropped:0 overruns:0 frame:0
TX packets:59 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4770 (4.6 KiB) TX bytes:6377 (6.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1104 (1.0 KiB) TX bytes:1104 (1.0 KiB)
lsusb shows that the device is recognised:
Bus 001 Device 004: ID 2001:3c19 D-Link Corp. DWA-125 Wireless N 150 Adapter(rev.A3) [Ralink RT5370]
Bus 001 Device 005: ID 046d:c31c Logitech, Inc. Keyboard K120 for Business
lsmod shows:
Module Size Used by
snd_bcm2835 19889 0
snd_pcm 74834 1 snd_bcm2835
snd_seq 52536 0
snd_timer 19698 2 snd_seq,snd_pcm
snd_seq_device 6300 1 snd_seq
snd 52489 5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc 4951 1 snd_pcm
joydev 9102 0
evdev 8682 2
If I unplug and then plug in the dongle the following lines appear in syslog:
Sep 22 10:11:23 raspberrypi kernel: [ 274.288626] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Sep 22 10:11:23 raspberrypi kernel: [ 274.406077] usb 1-1.2: New USB device found, idVendor=2001, idProduct=3c19
Sep 22 10:11:23 raspberrypi kernel: [ 274.406108] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 22 10:11:23 raspberrypi kernel: [ 274.406126] usb 1-1.2: Product: 11n Adapter
Sep 22 10:11:23 raspberrypi kernel: [ 274.406139] usb 1-1.2: Manufacturer: Ralink
Sep 22 10:11:23 raspberrypi kernel: [ 274.406150] usb 1-1.2: SerialNumber: 1.0
I have tried with and without a powered USB Hub, but there is no difference in behaviour.
I'm on the latest OS, apt-get install firmware-ralink shows the latest version. Most of the advice out there is what to do to bring up wlan0 correctly, not to make it appear in the first place.
Anybody have any concrete suggestions?
raspbee
Re: rt5370 Wifi not creating wlan0
Tue Sep 25, 2012 1:42 pm
Same issue here, I guess the RT5370 isn´t the best choice overall.
When I plug the LogiLink dongle in "sudo ifconfig" does exactly nothing.
I don´t believe in a power issue I am using a 5V/2A power supply (old one from a IOMEGA ZIP drive).
Maybe wicd is conflicting? I have no idea. :-(
A setup guide came with my Logilink Dongle but didn´t work out.
raspbee
Sat Sep 29, 2012 2:29 pm
I figured out it didn´t work if you start the rasp directly into desktop mode.
If you install wicd from console and startx then it worked for me.
fmfalcao
Sun Sep 30, 2012 1:10 am
I'm a total noob. I'm trying to get my d-link dwa-125 to work with my Raspberry Pi running wheezy.
Where can i get some info on how to get this thing to work. (step by step for a noob)
FM-Canada
rs_lbs
Re: rt5370 (D-Link DWA-125) Wifi not creating wlan0
Mon Oct 01, 2012 8:17 am
Hi. I too have the same problem with using a DLink DWA-125 Wifi USB Adapter with my Debian Wheezy distro installed on my Raspberry Pi.
I followed the instructions in the fantastic 'Raspberry Pi User Guide' noting that this device does indeed need the ralink firmware - which was loaded with the distro. But get the following messages when executing 'Sudo iwlist scan'
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
Please help ... perhaps it needs another driver.
Richard.
GregB
Thu Oct 04, 2012 12:18 pm
Ditto for me.
To backtrack a bit, about six weeks ago I was able to borrow a friend's D-Link DWA-125 dongle while he was going overseas. I persisted for about a month trying to get the thing to activate, following all the other forum posts (MrEngman's posts seemed very useful) but still no joy. Then a couple of weeks ago the new Raspbian Wheezy distro was released and I updated/upgraded that week. Once done I started wicd and lo and behold the dongle was recognised, fired up and started scanning for networks. I was even able to connect to my home broadband! Marvellous. I thought I must have been doing something wrong (a returnee to linux and pretty much a noob wrt wifi) and the new distro had sorted it out for me. So now that I was up and running, I thought I had better go out and buy my own DWA-125 (knowing that it worked!). I get it home and nothing worked from wicd. Hmmmm. I plugged both dongles in a discovered via lsusb that their firmware versions were different! My friend's dongle was rev.A2 Ralink RT3070. Mine rev.A3 Ralink RT5370. I've tried update/upgrade again, both from raspbian and debian sources without joy. I'm thinking that perhaps the firmware-ralink packages haven't yet been tinkered with for RT5370 (not knowing how new it is, perhaps very new and yet to be updated in the package list??).
So perhaps I just wait and see which bright spark out there will come up with a fix OR I might just swap my dongle with my mate's and he wouldn't be any the wiser :lol:
Greg
amontag
Fri Oct 05, 2012 4:34 am
same here....unfortunately I didn't see this thread before buying it last night.
Iw works like a charm in my standard Fedora 8-)
amontag
Sun Oct 07, 2012 9:03 am
I made a comparison between Fedora and Raspbian and I note that rt2800usb and rt2x00usb is not loaded.
I think that this is why dongle is not seen: shall we force its loading by insmod??
argief
Sun Oct 07, 2012 6:27 pm
Hey Guys, with regards to RT5370 chipset. This chipset is used by various devices, I am currently using this chipset successfully with my raspi, although I did struggle in the beginning to get it working. I used this great resource, which finally got it working on my end! It was written by an Ubuntu user, but since its also Debian based, it works perfectly. (I have used the instructions on gentoo). Basically, you need to ensure you have the firmware: (more info here)
sudo apt-get install firmware-ralink
(the firmware can also be obtained from ralink's site in which case you will have to place the *.bin files in /lib/firmware)
and then run these commands:
sudo modprobe rt2800usb
echo 148F 5370 | sudo tee /sys/bus/usb/drivers/rt2800usb/new_id
amontag
Mon Oct 08, 2012 9:48 am
in my case firmware-ralink package had already been installed..
Do you think that
should do the trick??
Can you explain what is the second line instruction for??
amontag
Mon Oct 08, 2012 9:58 am
furthermore from this page:
http://wiki.debian.org/rt2800usb
I see that this USB dongle should be supported.....
amontag
Mon Oct 08, 2012 10:04 am
Another question...
should be read as :
echo 07D1:3C0D | sudo tee /sys/bus/usb/drivers/rt2800usb/new_id
to have the D-link adapter recognized????????
drgeoff
Mon Oct 08, 2012 12:21 pm
GregB wrote: discovered via lsusb that their firmware versions were different! My friend's dongle was rev.A2 Ralink RT3070. Mine rev.A3 Ralink RT5370.
Yes, some manufacturers have the nasty habit of completely changing a product's internals but keeping the same model number.
amontag
Mon Oct 08, 2012 8:42 pm
it works: tnx a lot
but when I reboot I have to re-issue the command.How can I can make it permanent???
amontag
Tue Oct 09, 2012 4:47 am
I am back: not sure that everything is o.k.
- after issuing commands, card is started, wlan is created and connection are listed, when I try to connect to an open network, I see connect/disconnect, then wlan disappeard and module is not existing any more.
bilibao
Sat Oct 20, 2012 12:21 pm
You can try using the ralinktech driver (compiling it your self)
[I did it successfully with 3.1.9+ kernel and redoing it right now for 3.2.27]
First you need to get linux headers as explained in:
http://www.raspberrypi.org/phpBB3/viewt ... ead#unread
then download and install:
2011_0719_RT3070_RT3370_RT5370_RT5372_Linux_STA_V2.5.0.3_DPO.bz2
from ralink site:
http://www.ralinktech.com/en/04_support ... hp?sn=5016
something like:
tar xjvf 2011_0719_RT3070_RT3370_RT5370_RT5372_Linux_STA_V2.5.0.3_DPO.bz2
cd 2011_0719_RT3070_RT3370_RT5370_RT5372_Linux_STA_V2.5.0.3_DPO/
sudo make
sudo make install
Edit:
In addition I changed the following lines in os/linux/config.mk
# Support Wpa_Supplicant
HAS_WPA_SUPPLICANT=n
# Support Native WpaSupplicant for Network Maganger
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n
to
HAS_WPA_SUPPLICANT=y
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y
GregB
Mon Nov 12, 2012 11:38 am
argief wrote:Hey Guys, with regards to RT5370 chipset. This chipset is used by various devices, I am currently using this chipset successfully with my raspi, although I did struggle in the beginning to get it working. I used this great resource, which finally got it working on my end! It was written by an Ubuntu user, but since its also Debian based, it works perfectly. (I have used the instructions on gentoo). Basically, you need to ensure you have the firmware: (more info here)
Pardon my ignorance (Linux noob) but exactly where and how do you get the *.bin files from the ralink site? I've had a quick look but couldn't find my way around the site to locate the bin files.
Thanks, Greg.
GregB
Wed Nov 28, 2012 4:00 am
Thanks, Greg.
After re-reading the above steps a number of times, along with some other instructions about the place I worked out what needed to be done.
So I have spent the last two evenings trying to sort this USB adaptor out without success. So rather than waste anmore of my time on this problem which seems to do with the RT5370 firmware, I have decided to drop this device in favour of a Edimax EW-7811UN USB adaptor which for all intents and purposes (and doco on the elinux site) works out of the box for the latest version of Raspbian.
The reasoning being of want most things to work out of the box or with very minimal behind the scenes jiggery-pokery as my intention is to advise those with VERY if NO Linux experience how to quickly setup the Pi and wifi connectivity for the purpose I am envisaging (model rail control and interaction in a Club setting).
The DWA-125 dongle I will use on my PC for both internet access to the home internet router, as well as looking at communicating with the Pi via VNC (flavours to be investigated for simplicity of operation). So this device will be re-used rather than discarded.
Thanks for the help to date. Hopefully I won't be back on the forum with problems with the Edimax dongle! :lol:
GregB
Fri Apr 05, 2013 2:52 am
Finally getting back to this and it would appear from new information from http://elinux.org/RPI-Wireless-Hotspot that the Edimax doesn't support AP mode whereas the RT5370 does (apprently!). Probably explains why I couldn't get iwlist to show any 'AP' mode available. Oh well, back to the drawing board! I'll update my Raspbian files (or do the latest image) as it has been awhile, so potentially the Dlink dongle will be recognised now. Here's hoping!
pluggy
Fri Apr 05, 2013 7:55 am
The RT5370 works out of the box with recent Raspdian too. I have 4 wireless Pi's, 3 with the RTL8188CUS (No names using the same chipset as the much more expensive Edimax) and 1 with the RT5370 chipset. They are all headless and I can swap the wireless adaptors over without changing anything. I don't try and use any as an AP, but I'm led to beleive the RTL8188CUS won't do this whilst the RT5370 will. The 8188's drop a ridiculous amount of packets (~60%) with the Pi's iffy USB, the RT5370 only drops a few (~1%) so is much faster. I had stability problems with the RT5370 in the past, but it seems OK now. The RTL8188CUS has stability issues with the model A with the normally updated Raspdian but is OK with the latest from Github via rpi-update. I use static IP addresses.
iface lo inet loopback
#iface eth0 inet dhcp
# The primary network interface
#auto eth0
#iface eth0 inet static
#  address 192.168.1.248
#  netmask 255.255.255.0
#  network 192.168.1.0
#  broadcast 192.168.1.255
#  gateway 192.168.1.1
auto wlan0
#iface wlan0 inet dhcp
iface wlan0 inet static
address 192.168.1.254
gateway 192.168.1.1
wpa-ssid "OrangeD11A98"
wpa-psk "whatever"
wireless-power off   # This bit appears to clear up wifi issues
root@raspberrypi3:~#
This is the sum total of the configuration I do on them. The RTL8188CUS giver an error during startup with the 'wireless-power off' bit but fire up and work anyway. The RT5370 goes to sleep and doesn't wake up without it. I gave up trying to get ethernet and wireless working together, but this could be linked to the 8188's issue with running as an AP. All I've changed in the /etc/network/interfaces file is the password (wpa-psk). That is actually my routers ssid, Google's black Astras went through years ago and I've changed it since then. ;)
GregB
Fri Apr 05, 2013 10:46 am
Pluggy, thanks for the reply and I'll give the Dlink a go with a later version of Raspbian. I was actually quite surprised to see a reply considering this forum topic hadn't seenany activity since last year!
Greg
victagayun
Sat Jul 13, 2013 1:45 pm
I also have the same USB wifi dongle and facing the same problem. I have the latest image 2013-05-25-wheezy-raspbian.zip.
After update, dist-update and rpi-update and rebooted, I installed, samba, ntfs-3g and tightvncviewer.
BTW, I ssh and vnc to raspi from another desktop. before I vnc to raspi I ssh lsmod, lsusb and ifconfig, and here are the details.
pi@raspberrypi ~ $ lsusb
pi@raspberrypi ~ $ lsmod
Module Size Used by
snd_bcm2835 16304 0
snd_pcm 77560 1 snd_bcm2835
snd_seq 53329 0
snd_timer 19998 2 snd_pcm,snd_seq
snd_seq_device 6438 1 snd_seq
snd 58447 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc 5145 1 snd_pcm
arc4 1676 2
rt2800usb 14940 0
rt2800lib 55351 1 rt2800usb
crc_ccitt 1522 1 rt2800lib
rt2x00usb 11215 1 rt2800usb
rt2x00lib 42334 3 rt2x00usb,rt2800lib,rt2800usb
mac80211 273413 3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211 184163 2 mac80211,rt2x00lib
rfkill 18202 2 cfg80211
leds_gpio 2235 0
led_class 3562 2 leds_gpio,rt2x00lib
pi@raspberrypi ~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:f0:a7:d0
inet addr:192.168.1.101 Bcast:192.168.1.255 Mask:255.255.255.0
RX packets:64315 errors:0 dropped:0 overruns:0 frame:0
TX packets:46647 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:84727723 (80.8 MiB) TX bytes:4487378 (4.2 MiB)
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 28:10:7b:42:00:66
UP BROADCAST MULTICAST MTU:1500 Metric:1
When I logged in using vnc, wpa_gui still can see wlan0. When I start to scan or connect to any available network/s, lsusb cannot be detected anymore and here are the details of lsusb and lsmod.
Module Size Used by
snd_bcm2835 16304 0
snd_seq 53329 0
arc4 1676 0
rt2800usb 14940 0
rfkill 18202 1 cfg80211
leds_gpio 2235 0
I've read somewhere that the wrong drivers are loaded so i downloaded the driver from mediatek site, unzipped it and compiled it. But it stopped during compiling, due to some error, "build" folder is not present.
make: *** /lib/modules/3.6.11+/build: No such file or directory. Stop.
make: *** [LINUX] Error 2
So i made a folder and complied again. another error came out.
make[1]: Entering directory `/lib/modules/3.6.11+/build'
make[1]: *** No rule to make target `modules'. Stop.
make[1]: Leaving directory
I also tried this method:
pi@raspberrypi ~ $ sudo modprobe rt2800usb
pi@raspberrypi ~ $ echo 148F 5370 | sudo tee /sys/bus/usb/drivers/rt2800usb/new_id
148F 5370
I have also tried wpa_cli:
[b]pi@raspberrypi ~ $ wpa_cli[/b]
wpa_cli v1.0
Copyright (c) 2004-2012, Jouni Malinen <j@w1.fi> and contributors
This program is free software. You can distribute it and/or modify it
under the terms of the GNU General Public License version 2.
Alternatively, this software may be distributed under the terms of the
BSD license. See README and COPYING for more details.
Selected interface 'wlan0'
Interactive mode
> scan
OK
<3>CTRL-EVENT-SCAN-RESULTS
<3>CTRL-EVENT-TERMINATING - signal 15 received
> 'PING' command failed.
Connection to wpa_supplicant lost - trying to reconnect
It doesnt help, the wifi dongle still cannot be detected by lsusb.
glad if you guys can help me.
Victor
victagayun
Sat Jul 13, 2013 3:21 pm
Just in-case anyone is interested in these info:
pi@raspberrypi ~ $ lsusb -v -s 001:004
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2001 D-Link Corp.
idProduct 0x3c19 DWA-125 Wireless N 150 Adapter(rev.A3) [Ralink RT5370]
bcdDevice 1.01
iManufacturer 1
iProduct 2
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 67
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 450mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 7
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 5
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Victor
