Me again,
I should add that it's Raspbian. The image is
Linux raspberrypi 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l
I have installed postfix/courier, apache2, php5, MySql server and PHPMyAdmin. These were all woring untill the update.
Here's the full install screen output if it helps:
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
libmysqlclient18 mysql-client-5.5 mysql-common mysql-server mysql-server-5.5
mysql-server-core-5.5
6 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,915 kB of archives.
After this operation, 626 kB disk space will be freed.
Do you want to continue [Y/n]? y
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-common all 5.5.24+dfsg-9 [76.3 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmysqlclient18 armhf 5.5.24+dfsg-9 [616 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server all 5.5.24+dfsg-9 [74.5 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-5.5 armhf 5.5.24+dfsg-9 [1,714 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-client-5.5 armhf 5.5.24+dfsg-9 [1,413 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-server-core -5.5 armhf 5.5.24+dfsg-9 [3,021 kB]
Fetched 6,915 kB in 11s (594 kB/s)
Preconfiguring packages ...
(Reading database ... 62221 files and directories currently installed.)
Preparing to replace mysql-common 5.5.24+dfsg-8 (using .../mysql-common_5.5.24+d fsg-9_all.deb) ...
Unpacking replacement mysql-common ...
Preparing to replace libmysqlclient18:armhf 5.5.24+dfsg-8 (using .../libmysqlcli ent18_5.5.24+dfsg-9_armhf.deb) ...
Unpacking replacement libmysqlclient18:armhf ...
Preparing to replace mysql-server 5.5.24+dfsg-8 (using .../mysql-server_5.5.24+d fsg-9_all.deb) ...
Unpacking replacement mysql-server ...
Setting up mysql-common (5.5.24+dfsg-9) ...
Preparing to replace mysql-server-5.5 5.5.24+dfsg-8 (using .../mysql-server-5.5_ 5.5.24+dfsg-9_armhf.deb) ...
[ ok ] Stopping MySQL database server: mysqld.
Unpacking replacement mysql-server-5.5 ...
Preparing to replace mysql-client-5.5 5.5.24+dfsg-8 (using .../mysql-client-5.5_ 5.5.24+dfsg-9_armhf.deb) ...
Unpacking replacement mysql-client-5.5 ...
Preparing to replace mysql-server-core-5.5 5.5.24+dfsg-8 (using .../mysql-server -core-5.5_5.5.24+dfsg-9_armhf.deb) ...
Unpacking replacement mysql-server-core-5.5 ...
Processing triggers for man-db ...
Setting up libmysqlclient18:armhf (5.5.24+dfsg-9) ...
Setting up mysql-client-5.5 (5.5.24+dfsg-9) ...
Setting up mysql-server-core-5.5 (5.5.24+dfsg-9) ...
Setting up mysql-server-5.5 (5.5.24+dfsg-9) ...
[FAIL] Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed !
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
dependency problems - leaving unconfigured
mysql-server-5.5
mysql-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
There may be erroneous break in some of the lines because of the width of the remote ssh window I was running from.
I guess any one doing the same will get the same problem so a solution seems to be needed but it's beyond me without a few clues.
Many thanks
Andy
Edit: If there's an easy way to go back using apt-get I'd love to find out.
