macstr1k3r
Wierd RTC(ds1307) problem
Sun Oct 21, 2012 4:00 pm
For the pas week or so I have been trying to hook up a ds1307 with my r-pi. I have not been able to find anyone on google with a similar problem so I decided to post my problem here.
LSMOD:
root@raspberrypi:~# lsmod
rtc_ds1307              6710  0
i2c_bcm2708             3542  0
i2c_dev                 5587  0
snd_bcm2835            19889  0
snd_pcm                74834  1 snd_bcm2835
snd_seq                52536  0
snd_timer              19698  2 snd_seq,snd_pcm
snd_seq_device          6300  1 snd_seq
snd                    52489  5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc          4951  1 snd_pcm
evdev                   8682  2
I am able to detect the rtc on the i2c bus
root@raspberrypi:/home/pi# i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
It is clear from the following shippet that the chip is successfully "registered"
root@raspberrypi:/home/pi# echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
Once I run hwclock -r or hwclock -s I get:
root@raspberrypi:/home/pi# hwclock -r
hwclock: ioctl(RTC_RD_TIME) to /dev/rtc0 to read the time failed: Invalid argument
Any help or guidance would be apriciated. Thanks in advance
M33P
Re: Wierd RTC(ds1307) problem
Sun Oct 21, 2012 7:20 pm
Try
echo 7 > /proc/sys/kernel/printk
to enable debug messages in the kernel log.
Then can you post the output of dmesg after you perform those steps (again) to register the DS1307?
And also
i2cdump -y 0 0x68 b
ravidborse
Wed Jun 05, 2013 5:34 pm
Hi
I also used to get the error
RTC Problem RTC_RD_TIME: Invalid argument ioctl() to /dev/rtc0 to read the time failed.
My Problem Solved Using Following Link:
Run Command Mentioned In Link:
# sudo hwclock --systohc -D --noadjfile --utc
# sudo hwclock --set --date "06/05/13 23:00:00"
# sudo hwclock --show
Wed 05 Jun 2013 23:00:13 UTC  -0.369063 seconds
# sudo shutdown now
Remove all power supply wiring for 5 Mins.
After 5 Mins Wire Complete Set Up Again and Login the Raspberry PI
Wed 05 Jun 2013 23:05:05 UTC  -0.761500 seconds
http://www.mail-archive.com/smartphones ... 02020.html
rgkrishnas
Tue Oct 03, 2017 7:14 am
Pi Zero W Needs the below config changes to work RTC 1307 module
sudo nano /boot/config.txt
## Add the below line
dtoverlay=i2c-rtc,ds1307
edit the below line
sudo nano /lib/udev/hwclock-set
## Comment the below 3 lines
e.g.
#if [ -e /run/systemd/system ]; then
#exit 0
#fi
sudo reboot
sduo hwclock -r
Regards
Gopal
alphanumeric
Tue Oct 03, 2017 12:21 pm
I have a DS1307, and two DS3231's running fine, following this tutorial. https://learn.adafruit.com/adding-a-rea ... pberry-pi
brubbel
Wed Mar 28, 2018 12:12 pm
FWIW, same issue with pcf8523. Only happens at first use, when the RTC is not (yet) initialized.
Issue is repeatable by removing the battery of the RTC for a minute, then replugging the module on the RPI.
dtoverlay and rtc_pcf8523 module load correctly, but 'timedatectl' and 'hwclock --show' produce the error 'Invalid argument'.
Running sudo hwclock --show twice seems to solve the problem, or running 'hwclock --systohc'.
