whowantspi
RTC on Stretch
Fri Mar 16, 2018 2:24 am
I have had DS3231 RTC's on my Pi's running Wheezy, Jessie and now Stretch. Everything worked as expected on Wheezy and Jessie but Stretch has a problem I haven't been able to figure out.
I followed the instructions here for Jessie and Stretch. https://learn.adafruit.com/adding-a-rea ... t-rtc-time
and also installed NTP using DougieLawson post in this thread viewtopic.php?t=194468
which is ...
sudo apt install ntp
sudo systemctl enable ntp
sudo timedatectl set-ntp 1
When the pi is first booted the RTC time always shows Thu 2016-11-03 17:17:15 (give or take a few seconds)
timedatectl
Local time: Thu 2018-03-15 16:29:38 CDT
Universal time: Thu 2018-03-15 21:29:38 UTC
RTC time: Thu 2016-11-03 17:17:15
Time zone: America/Chicago (CDT, -0500)
Network time on: yes
NTP synchronized: yes
RTC in local TZ: no
After a few minutes the RTCs will get their time set correctly, but it's always wrong at boot.
Since I have 9 raspberry pi's of different versions that all do the exact same thing, it has to be software.
Thanks for any help, Max
Re: RTC on Stretch
Fri Mar 16, 2018 10:08 am
Have you added
dtoverlay=i2c-rtc,ds3231
to /boot/config.txt?
whowantspi
Re: RTC on Stretch
Fri Mar 16, 2018 12:40 pm
Yes. That's step one in the Adafruit instructions.
gregeric
Re: RTC on Stretch
Fri Mar 16, 2018 12:57 pm
Is your RTC's backup cell healthy?
Edit: failed to notice that this afflicts 9 raspberries so unlikely to be that.
Checked my DS3231 RTC & with network disconnected it's booting back up with the current time. That's Stretch / kernel 4.9.
pcmanbob
Re: RTC on Stretch
Fri Mar 16, 2018 3:36 pm
Did you remember to write the correct time/date to the RTC using
sudo hwclock -w
then check it with
sudo hwclock -r
whowantspi
Re: RTC on Stretch
Wed Mar 21, 2018 2:46 pm
After trying everything I could find on the net I finally gave up and downloaded the latest release of Stretch. Following my same notes it appears to be working correctly now. I just wish I could have figured out how to fix my orginal problem. Now I have to rebuild 9, make that 10 (just bought a new 3B+) systems. What a pain.
Max
