xsw2_2wsx
rpi 3b+ stopped working? Please help
Fri Apr 20, 2018 2:36 pm
I had some expirience with rpi before, i used old model that i have borowed. Everything worked fine. Then i bought a rpi3b+, with worked for a few days but now im unable to boot. Im not even getting rainbow screen with suggests that sd card is unreadable, but i tried to reformat and reflash 2 cards, and also using noobs and still no results. Possible Pi damage? I'll add that im unable to boot since i last unplugged power without shutting os down. Thanks for all the help.
drgeoff
Re: rpi 3b+ stopped working? Please help
Fri Apr 20, 2018 4:18 pm
Read the "not booting" sticky.
gordon77
Fri Apr 20, 2018 4:25 pm
I would suggest trying another SD card, a better power supply and/or a better usb cable.
xsw2_2wsx
Sat Apr 21, 2018 9:18 am
Usb cable is perfectly fine, its a fast charging cable so it ca handle the pi. I was able to boot just with 5v 1a from a pc USB, so power supply shouldnt be a problem, and event if it was it would load a rainbow screen, and then fail to load kernel because it requires higher amp. But i tried it just to make sure, with 5v 2a charger and a new cable - nothing changed.
Ill buy some sd cards and ill also try to give ones that dont work for me to my friend to see if he can boot.
Thank you for the help.
xsw2_2wsx
Sat Apr 21, 2018 9:22 am
I have read that already and tried reformatting and flashing again sd cards and also using noobs. Havent found much information about rpi3b+, most information relates to older models. Did i miss something?
Thank you for help.
Sat Apr 21, 2018 9:28 am
Thank you for help.
There was an updated Raspbian Stretch with Desktop release a couple of days ago.
https://www.raspberrypi.org/downloads/raspbian/
If you use Etcher it will both unzip and create a bootable SD Card in one operation.
https://etcher.io
mahjongg
Sat Apr 21, 2018 12:59 pm
Thank you for help.
yes you missed that information about other models than the 3B+ also applies (unless the sticky tells you otherwise) to the 3B+
xsw2_2wsx
Sat Apr 21, 2018 5:23 pm
Thank you for help.
https://etcher.io
Ok, but how woult it make older versions stopped working? I was successful to boot with the image i reflashed the cards with. But i'll try it anyway, just to make sure. And btw i just tried third sd card- still same thing- power LED is on, but no active LED. Im starting to worry.
Im using etcher already.
Thanks for the help.
xsw2_2wsx
Sat Apr 21, 2018 5:28 pm
Thank you for help.
Ok , ill read it again then,
Thank you.
