shukero
Rasbian is making me pull out my hair :( no true root access?
Mon Dec 24, 2018 12:47 am
Hi everyone,
Brand new to Raspberry Pi and the Debian distro of Linux. (I've been using Arch / Manjaro for a little while now) I've been trying to install some node_modules for Node.js; and I keep getting "Permission Denied" errors for Discord.js installs. When I tried to use su - root / root terminal it asks for the root password. I input the password that Raspbian asked me to create when I installed Raspbian; but it states that password is wrong. I also tried Raspberry, raspberry, and pi just in-case; but with no luck.
So next I thought I might have entered the password I had created wrong; so I checked by SSH'ing into the Pi with my remembered password, and it worked... SO now I'm pulling out my hair because for some reason Debian won't give me full ROOT access.
can someone help me - PLEASE!
~Shukero
WillBoxOwO
Re: Rasbian is making me pull out my hair :( no true root access?
Mon Dec 24, 2018 2:11 am
Try this:
sudo (your command that requires root access)
I like cats
HawaiianPi
Mon Dec 24, 2018 3:27 am
As said above, preface commands that require root privileges with sudo (which I believe is an acronym for Super User do).
To get a root terminal:
sudo su
In normal Debian GNU/Linux the user must be in the sudo group, and enters its own password for sudo actions. In Raspbian the default pi user is a member of sudo, and has passwordless sudo enabled.
The root account is disabled by default in Debian and its derivatives (Ubuntu, Mint, etc.). With sudo it's not needed, but you can create a passwrod for root if you want to use it.
shukero
Mon Dec 24, 2018 3:32 am
Hi again you two,
I had already tried sudo, sudo -i, sudo su, and sudo - root; however, when I tried sudo su and sudo - root; it asked me for a password; which I provided correctly - the one I entered when I setup raspbian, and it did not work. So I'm a bit confused as to why NOOBS / Debian does not allow true root level access :(
I was able to get my discord app off the group without having to result to "true" root access thankfully; but it just sucks that I don't have the ability to get into the root terminal program or use sudo su / sudo - root; as the password I input for root / raspberry doesn't work for these two programs / things.
Very disappointing. If I could easily install arch / manjaro on this PI I would have.
Thanks for trying to help though.
~Shukero
HawaiianPi
Mon Dec 24, 2018 5:07 am
... So I'm a bit confused as to why NOOBS / Debian does not allow true root level access :(
It does, so something must have gone wrong with your install. (Keyboard or language configuration?) :?
Rather than using NOOBS, try installing a Raspbian image from: https://www.raspberrypi.org/downloads/raspbian/
Download the image you want (Lite, Desktop, Full) and write it to your card with Etcher: https://www.balena.io/etcher/
  • Write it directly from the .zip archive (don't extract it first, Etcher will do that for you).
  • You don't need to format the card before writing (image contains complete filesystem).
  • If you have trouble writing/verifying, check the download against the SHA256 hash sum on the download page.
This skips the NOOBS middleman installer, which saves space and updates properly (NOOBS doesn't update when you update Raspbian).
scruss
Mon Dec 24, 2018 5:41 am
… but it just sucks that I don't have the ability to get into the root terminal program or use sudo su / sudo - root
There's no root user under Raspbian. Or at least, not one with a regular login. You pretty much don't need it, anyway. The very few things that don't work with regular sudo can be done using sudo -i.
Pronouns: he/him
ShiftPlusOne
Mon Dec 24, 2018 6:54 am
What's "true root access"? If sudo doesn't work, then please explain what you've done that made it stop working. If you would like to use su or login through the ttys, then you just need to set a root password ('sudo passwd root').
Also, you shouldn't be able to install Arch, if you're more comfortable with it. The instructions on Archlinux ARM's site are quite thorough and simple.
davidcoton
Mon Dec 24, 2018 10:12 am
I think you mean "should" :?:
ShiftPlusOne
Tue Dec 25, 2018 10:32 am
That's right. Had a bit of a Trump moment, sorry.
hippy
Tue Dec 25, 2018 12:39 pm
I don't believe using NOOBS would be causing the problem. Using "sudo su" works for me on my NOOBS installed Pi's, without prompting for any password. It seems it's something else.
procount
Tue Dec 25, 2018 1:48 pm
Quite rght. There's no difference to the Raspbian that is installed by Etcher or NOOBs.
If space is a problem use NOOBS-lite.
If you want self-updating, use PINN, now with individual OS backup, restore, replace or reinstall, fschk, passwird recovery and much more.
bakan
Wed Dec 26, 2018 7:30 am
Try checking your /etc/sudoers and /etc/sudoers.d/ configurations
there should be a line like this in one of those files:
pi ALL= NOPASSWD: ALL
drushtx
Contact: Website Yahoo Messenger Facebook YouTube
Wed Dec 26, 2018 9:27 pm
Seriously? This is permissible? May I take political potshots at Mrs. May, as well?
Wed Dec 26, 2018 9:54 pm
Yes please. Free speech, to an extent.
ShiftPlusOne
Thu Dec 27, 2018 8:40 am
Click the report button next to my post and one of the moderators will take a look at it. IMHO, referencing the would/wouldn't incident isn't a political statement for or against anything.
n67
Thu Dec 27, 2018 9:09 am
IMHO, referencing the wshould/wshouldn't incident isn't a political statement for or against anything.
He's referring to the phrase "Trump moment".
But he's from Texas, which explains a lot.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
ShiftPlusOne
Thu Dec 27, 2018 10:36 am
So was I. I'd link a relevant news article, but I'm sure somebody would have a problem with whatever source I choose.
Burngate
Thu Dec 27, 2018 11:45 am
Lots of people voted for Trump, just like lots of people voted for May, and are happy, but the ones who didn't are complaining like mad, hoping to change things to the way it "ought" to be.
But Trump has one thing May hasn't: he's got a "Moment" named after him.
Tell you what: You let us have Trump, and you take May. That way we'd all be happy.
mahjongg
Thu Dec 27, 2018 12:41 pm
May I remind everybody that politics is off-topic for this forum.
As I see no new on topic messages, I’m closing this thread.
