alonedriver
Ras3 crashes after update
Mon Mar 11, 2019 5:16 pm
Regular update results in an unrecoverable crash in system... today.
The following packages will be upgraded:
libopenjp2-7 raspi-copies-and-fills
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 117 kB of archives.
After this operation, 6,144 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian stretch/main armhf raspi-copies-and-fills armhf 0.8 [8,520 B]
Get:2 http://mirrors.pidginhost.com/raspbian/raspbian stretch/main armhf libopenjp2-7 armhf 2.1.2-1.1+deb9u3 [108 kB]
Fetched 117 kB in 11s (10.5 kB/s)
Reading changelogs... Done
(Reading database ... 158545 files and directories currently installed.)
Preparing to unpack .../libopenjp2-7_2.1.2-1.1+deb9u3_armhf.deb ...
Unpacking libopenjp2-7:armhf (2.1.2-1.1+deb9u3) over (2.1.2-1.1+deb9u2) ...
Preparing to unpack .../raspi-copies-and-fills_0.8_armhf.deb ...
Unpacking raspi-copies-and-fills (0.8) over (0.6) ...
Setting up libopenjp2-7:armhf (2.1.2-1.1+deb9u3) ...
Setting up raspi-copies-and-fills (0.8) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
dpkg: error processing package libc-bin (--configure):
subprocess installed post-installation script was killed by signal (Segmentation fault)
dpkg: error: error executing hook 'if { test "$DPKG_HOOK_ACTION" = add-architecture || test "$DPKG_HOOK_ACTION" = remove-architecture; } && test -x /usr/share/pkg-config-dpkghook; then /usr/share/pkg-config-dpkghook update; fi', exit code 11
Usage:
glib20.mo [OPTION…]
sh: 1: 34:ln=01: not found
sh: 1: 36:mh=00:pi=40: not found
sh: 1: 33:so=01: not found
sh: 1: 35:do=01: not found
sh: 1: 35:bd=40: not found
sh: 1: 33: not found
sh: 1: 01:cd=40: not found
sh: 1: 01:or=40: not found
sh: 1: 31: not found
sh: 1: 01:mi=00:su=37: not found
sh: 1: 41:sg=30: not found
sh: 1: 43:ca=30: not found
sh: 1: 41:tw=30: not found
sh: 1: 42:ow=34: not found
sh: 1: 42:st=37: not found
sh: 1: 44:ex=01: not found
sh: 1: 32:*.tar=01: not found
sh: 1: 31:*.tgz=01: not found
sh: 1: 31:*.arc=01: not found
sh: 1: 31:*.arj=01: not found
sh: 1: 31:*.taz=01: not found
sh: 1: 31:*.lha=01: not found
sh: 1: 31:*.lz4=01: not found
sh: 1: 31:*.lzh=01: not found
sh: 1: 31:*.lzma=01: not found
sh: 1: 31:*.tlz=01: not found
sh: 1: 31:*.txz=01: not found
sh: 1: 31:*.tzo=01: not found
sh: 1: 31:*.t7z=01: not found
sh: 1: 31:*.zip=01: not found
sh: 1: 31:*.z=01: not found
sh: 1: 31:*.Z=01: not found
sh: 1: 31:*.dz=01: not found
sh: 1: 31:*.gz=01: not found
sh: 1: 31:*.lrz=01: not found
sh: 1: 31:*.lz=01: not found
sh: 1: 31:*.lzo=01: not found
sh: 1: 31:*.xz=01: not found
sh: 1: 31:*.zst=01: not found
sh: 1: 31:*.tzst=01: not found
sh: 1: 31:*.bz2=01: not found
sh: 1: 31:*.bz=01: not found
sh: 1: 31:*.tbz=01: not found
sh: 1: 31:*.tbz2=01: not found
sh: 1: 31:*.tz=01: not found
sh: 1: 31:*.deb=01: not found
sh: 1: 31:*.rpm=01: not found
sh: 1: 31:*.jar=01: not found
sh: 1: 31:*.war=01: not found
sh: 1: 31:*.ear=01: not found
sh: 1: 31:*.sar=01: not found
sh: 1: 31:*.rar=01: not found
sh: 1: 31:*.alz=01: not found
sh: 1: 31:*.ace=01: not found
sh: 1: 31:*.zoo=01: not found
sh: 1: 31:*.cpio=01: not found
sh: 1: 31:*.7z=01: not found
sh: 1: 31:*.rz=01: not found
sh: 1: 31:*.cab=01: not found
sh: 1: 31:*.jpg=01: not found
sh: 1: 35:*.jpeg=01: not found
sh: 1: 35:*.mjpg=01: not found
sh: 1: 35:*.mjpeg=01: not found
sh: 1: 35:*.gif=01: not found
sh: 1: 35:*.bmp=01: not found
sh: 1: 35:*.pbm=01: not found
sh: 1: 35:*.pgm=01: not found
sh: 1: 35:*.ppm=01: not found
sh: 1: 35:*.tga=01: not found
sh: 1: 35:*.xbm=01: not found
sh: 1: 35:*.xpm=01: not found
sh: 1: 35:*.tif=01: not found
sh: 1: 35:*.tiff=01: not found
sh: 1: 35:*.png=01: not found
sh: 1: 35:*.svg=01: not found
sh: 1: 35:*.svgz=01: not found
sh: 1: 35:*.mng=01: not found
sh: 1: 35:*.pcx=01: not found
sh: 1: 35:*.mov=01: not found
sh: 1: 35:*.mpg=01: not found
sh: 1: 35:*.mpeg=01: not found
sh: 1: 35:*.m2v=01: not found
sh: 1: 35:*.mkv=01: not found
sh: 1: 35:*.webm=01: not found
sh: 1: 35:*.ogm=01: not found
sh: 1: 35:*.mp4=01: not found
sh: 1: 35:*.m4v=01: not found
sh: 1: 35:*.mp4v=01: not found
sh: 1: 35:*.vob=01: not found
sh: 1: 35:*.qt=01: not found
sh: 1: 35:*.nuv=01: not found
sh: 1: 35:*.wmv=01: not found
sh: 1: 35:*.asf=01: not found
sh: 1: 35:*.rm=01: not found
sh: 1: 35:*.rmvb=01: not found
sh: 1: 35:*.flc=01: not found
sh: 1: 35:*.avi=01: not found
sh: 1: 35:*.fli=01: not found
sh: 1: 35:*.flv=01: not found
sh: 1: 35:*.gl=01: not found
sh: 1: 35:*.dl=01: not found
sh: 1: 35:*.xcf=01: not found
sh: 1: 35:*.xwd=01: not found
sh: 1: 35:*.yuv=01: not found
sh: 1: 35:*.cgm=01: not found
sh: 1: 35:*.emf=01: not found
sh: 1: 35:*.ogv=01: not found
sh: 1: 35:*.ogx=01: not found
sh: 1: 35:*.aac=00: not found
sh: 1: 36:*.au=00: not found
sh: 1: 36:*.flac=00: not found
sh: 1: 36:*.m4a=00: not found
sh: 1: 36:*.mid=00: not found
sh: 1: 36:*.midi=00: not found
sh: 1: 36:*.mka=00: not found
sh: 1: 36:*.mp3=00: not found
sh: 1: 36:*.mpc=00: not found
sh: 1: 36:*.ogg=00: not found
sh: 1: 36:*.ra=00: not found
sh: 1: 36:*.wav=00: not found
sh: 1: 36:*.oga=00: not found
sh: 1: 36:*.opus=00: not found
sh: 1: 36:*.spx=00: not found
sh: 1: 36:*.xspf=00: not found
sh: 1: 36:: not found
E: Sub-process /usr/bin/dpkg returned an error code (2)
E: Problem executing scripts DPkg::Post-Invoke '/usr/bin/test -e /usr/share/dbus-1/system-services/org.freedesktop.PackageKit.service && /usr/bin/test -S /var/run/dbus/system_bus_socket && /usr/bin/gdbus call --system --dest org.freedesktop.PackageKit --object-path /org/freedesktop/PackageKit --timeout 4 --method org.freedesktop.PackageKit.StateHasChanged cache-update > /dev/null; /bin/echo > /dev/null'
E: Sub-process returned an error code
trying to reboot not working...
reboot
Failed to connect to bus: Invalid argument��vP��(��vH������vP����L`�v-=[
Tried the update in 2 machines failes both.
Hard reboot does not help... crash in booting sequence.
ANY IDEAS or HELP?
ShiftPlusOne
Re: Ras3 crashes after update
Mon Mar 11, 2019 5:17 pm
Note to other users: DO NOT UPGRADE
I'm doing my best to have the update pulled ASAP.
If you can, take the card out and remove /etc/ld.so.preload . That should get you back into a working state.
ShiftPlusOne
Mon Mar 11, 2019 5:21 pm
Okay, the responsible package has been removed. That was a serious mistake on my behalf and I apologise. Really can't test things enough.
I hope not many others have been bitten by this.
alonedriver
Mon Mar 11, 2019 5:30 pm
i have no physical access to the machines, just remote access... any ideas?
ShiftPlusOne
Mon Mar 11, 2019 5:37 pm
Oh no, that's the worst case scenario.
If you can remove /etc/ld.so.preload, you may be able to recover it, but I had no luck trying that without taking the card out.
alonedriver
Mon Mar 11, 2019 5:39 pm
No luck...
If there is any ideas just post them... unfortunately machines are sitting thousands km away...
alonedriver
Mon Mar 11, 2019 5:42 pm
can i overwrite that file from vnc viewer somehow / transfer a working file or something like that?
or edit something else?
ShiftPlusOne
Mon Mar 11, 2019 5:59 pm
rm is one of the simplest things to run, so if that doesn't work, I don't think anything else will. Everything I tried resulted in corrupted memory and segfaults.
ShiftPlusOne
Mon Mar 11, 2019 6:10 pm
Try "LD_PRELOAD=/usr/lib/arm-linux-gnueabihf/libarmmem-v6l.so sudo rm /etc/ld.so.preload"
v6 version seems to be fine and LD_PRELOAD should take precedence over ld.so.preload, so maybe that will work.
Mon Mar 11, 2019 6:35 pm
Wow! I'd just got to libarmmem.so being the problem when I found this thread. Only broke four out of eighteen raspberries.
rpbit
Mon Mar 11, 2019 11:08 pm
I was also affected by this update, see viewtopic.php?f=28&t=235600&p=1440779.
But it still shows up on my other Raspis, is it safe to update now?
ShiftPlusOne
Mon Mar 11, 2019 11:20 pm
version 0.10 should be safe.
rpbit
Mon Mar 11, 2019 11:25 pm
ok, all fine now.
ShiftPlusOne
Mon Mar 11, 2019 11:26 pm
Again, sorry about that.
Tue Mar 12, 2019 5:50 am
No problem. You found the problem before I'd shot 16 out of 18 raspberries dead. The hardest fix was my weather station - it's out of doors and I had to dismantle the case to get the SDCard back into the slot.
The sudo rm /etc/ld.so.preload fix is easy enough.
The best thing was when I was fsck'ing one of the hard drives I found some archived SDCard images that I'd forgotten about but contain something I was looking for after my NAS had a catastrophic HD failure. "Clouds and silver linings."
pmunts
Wed Mar 13, 2019 8:38 am
raspi-copies-and-fills version 0.10 breaks the Subversion command line client with existing checkouts. I had to manually downgrade to 0.5-1 to get Subversion working again.
With 0.10 svn status --no-ignore generates a lot of this:
! S python/Make/modularity/GPIO.py
! S python/Make/modularity/MeArm.py
! S python/Make/modularity/ZeroMQ.odt
! S python/Make/modularity/ZeroMQ.pdf
! S python/Make/modularity/bar
! S python/Make/modularity/cgi-bin
! S python/Make/modularity/client1.py
! S python/Make/modularity/client2.py
! S python/Make/modularity/client3.py
! S python/Make/modularity/client_lights.py
! S python/Make/modularity/foo
! S python/Make/modularity/server1.py
! S python/Make/modularity/server2.py
! S python/Make/modularity/server3.py
! S python/Make/modularity/server_lights.py
! S python/Make/modularity/test1.py
! S python/Make/modularity/test2.py
! S python/Make/modularity/test_robot.py
! S python/Make/modularity/webserver
! S python/Make/modularity/webserver.odt
! S python/Make/modularity/webserver.pdf
! S python/Make/modularity/zmq
ShiftPlusOne
Wed Mar 13, 2019 4:46 pm
Having trouble reproducing this one. I checked out a random repo and ran the command you gave.
If you go to 0.10 and comment out the line in /etc/ld.so.preload, does the problem go away? Do you have reliable steps to reproduce the issue?
rayjoh
Wed Mar 13, 2019 6:01 pm
Removing /etc/ld.so.preload cured my problem with subversion
-- Raymond
deathkid535
Wed Mar 13, 2019 11:31 pm
Version 0.10 also seems to break some Plex functionality.
Worked for me but I imagine there are quite a lot confused users out there who don't know about this. You might want to look into it.
ShiftPlusOne
Thu Mar 14, 2019 12:18 am
Kodi devs are also reporting issues. We'll roll back. Thanks, everyone.
JAW206
Thu Mar 14, 2019 5:47 am
Hello, what exactly does this command do? I am new to Linux in general and while it fixed the problem with my Plex server, after running this command the /var/lib/plexmediaserver folder seems to have gone missing.
rpbit
Thu Mar 14, 2019 6:07 pm
I would like to add that raspi-copies-and-fills seems to also "break" Chromium in a weird way.
If i type an url into chromium and hit enter i almost always get directed to the default search engine which shows me the results for that url. This is not the case if i don't update to the latest raspi-copies-and-fills. And this update is still available today. So i would recommend to stay away from that specific package (i put it on hold via sudo apt-mark hold raspi-copies-and-fills on all my raspis).
ShiftPlusOne
Thu Mar 14, 2019 8:20 pm
What a mess :(
0.11 is out, rolling everything back to as it was in 0.6.
davidcoton
Thu Mar 14, 2019 8:58 pm
What a mess :(
You can take pride in this...
When your stuff breaks, it does it big time. :lol:
ShiftPlusOne
Thu Mar 14, 2019 9:09 pm
What a mess :(
That's true. If nobody has to travel thousands of kilometres to fix it, why even bother. :oops:
