Botspot
Chromium ffmpeg displaying static instead of videos
Wed Apr 17, 2019 5:26 pm
About a month ago I updated and upgraded my Raspbian Stretch desktop to the latest package versions. Chromium was updated from version 65 to version 72. All videos played in the browser now look "scrambled up". Several days later, I did another update and upgrade, and the chromium packages were listed again as "to be upgraded". I did the upgrade, but nothing changed. Videos still look scrambled.
This is what I see when I attempt to play a video:
Screenshot from 2019-04-17 12-13-15.png (35.26 KiB) Viewed 662 times
Questions:
Why did I never have this problem on Chromium 65?
What could be causing this to happen?
Is anyone else having (or had) this problem?
What steps can I take to fix the problem?
Easily install anything on your Pi using Pi-Apps! Over 1 million users.
150+ apps including image editors, text editors, games, web browsers, appearance themes, and other upgrades to get the most out of your Pi.
ShiftPlusOne
Re: Chromium ffmpeg displaying static instead of videos
Wed Apr 17, 2019 6:44 pm
What's your GPU mem?
Botspot
Wed Apr 17, 2019 6:49 pm
ShiftPlusOne wrote:What's your GPU mem?
My GPU memory allocation is 64.
Botspot
Wed Apr 17, 2019 6:56 pm
Rebooted with it set to 256 and Chromium now plays videos properly!
It played videos fine, set at 64, before the upgrade; why would that change with the Chromium update?
Anyway, it works now. :)
odroid
Mon Apr 27, 2020 7:11 pm
have you tweaked chrome flags?
try chromium --disable-gpu as fast yes/no test
Then /if enabled/ try disable native memory gpu buffers, zero copy.
