JamesPi123
Rpi zero w wifi antenna broken
Sat Jun 29, 2019 12:53 am
Hi there, my raspberry pi zero w's wifi antenna is broken
Image attached. What can i do and will it work?
(it is the one circled in yellow)
kflmiami420
Re: Rpi zero w wifi antenna broken
Sat Jun 29, 2019 3:30 am
get one of each
https://www.ebay.com/itm/Angle-USB-2-0- ... Sw-llcwVlR
https://www.ebay.com/itm/Home-Wireless- ... Sw3UlczS1e
that will fix your 14 dollar pi zero w
Imperf3kt
Contact: Twitter
Sat Jun 29, 2019 6:37 am
get one of each
But then how do you plug in a mouse? The USB port only supports a single device. Adding more requires use of a hub, not s power splitting device.
55:55:44:44:4C
52:4C:52:42:41
PhatFil
Sat Jun 29, 2019 8:32 am
search utube.. i am sure i have seen a pi-0-w mod placing a wifi aerial connector (tiny snap on type as found on lappy pcie cards..) on the 3 x solderpads visible in ypur pic at circa 2 o'clock above the screen printed 'usb'.
https://www.youtube.com/watch?v=KonrpeVRRjc
it was easy to find.. ;)
Ive not done this myself so cant guarantee it will work..
Imperf3kt
Contact: Twitter
Sun Jun 30, 2019 3:29 am
It works, just don't get caught as it breaks FCC certification and is thus illegal / not allowed to be discussed here.
55:55:44:44:4C
52:4C:52:42:41
JamesPi123
Tue Jul 09, 2019 7:28 am
ok, thanks *says discreetly to avoid acma turning up at the front door*
kflmiami420
Wed Jul 10, 2019 2:20 am
you will need this one as well for your mouse https://www.ebay.com/itm/Micro-USB-Male ... SwUQxc7zso
