Re: 3440x1440 not applying
Mon Sep 09, 2019 8:47 am
Add
hdmi_pixel_freq_limit=400000000
to config.txt to see if that helps. This 3440x1440 seems to have a very high pixel frequency, higher even than the higher resolution 4kp60, which is a bit strange, but must be some reason for it.
dustamust
Mon Sep 09, 2019 4:02 pm
that worked! thank you so much!!
Mon Sep 09, 2019 4:44 pm
Good news. Will look to getting the change accepted in to the main firmware codebase. Got a few little things to sort out first.
romal
Thu Jan 07, 2021 6:24 pm
I seem to have the same problem.
I use a 64 Bit Raspi4.
Linux raspberrypi 5.4.79-v8+ #1373 SMP PREEMPT Mon Nov 23 13:32:41 GMT 2020 aarch64 GNU/Linux
I have tried to some options in config.txt, but they didn't help.
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
arm_64bit=1
start_x=1
gpu_mem=512
hdmi_enable_4kp60=1
hdmi_cvt=3440 1440 60 7 0 0 1
The eeprom is up to date:
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
VL805 firmware in bootloader EEPROM
BOOTLOADER: up-to-date
CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
LATEST: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000138a1
My edid looks like this:
pi@raspberrypi:~ $ edid-decode edid.dump
EDID version: 1.3
Manufacturer: SAM Model dc3 Serial Number 0
Made in week 27 of 2016
Digital display
Maximum image size: 80 cm x 33 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
First detailed timing is preferred timing
Display x,y Chromaticity:
Red: 0.6621, 0.3281
Green: 0.2763, 0.5908
Blue: 0.1337, 0.1328
White: 0.3076, 0.3710
Established timings supported:
720x400@70Hz 9:5 HorFreq: 31469 Hz Clock: 28.320 MHz
640x480@60Hz 4:3 HorFreq: 31469 Hz Clock: 25.175 MHz
640x480@67Hz 4:3 HorFreq: 35000 Hz Clock: 30.240 MHz
640x480@72Hz 4:3 HorFreq: 37900 Hz Clock: 31.500 MHz
640x480@75Hz 4:3 HorFreq: 37500 Hz Clock: 31.500 MHz
800x600@56Hz 4:3 HorFreq: 35200 Hz Clock: 36.000 MHz
800x600@60Hz 4:3 HorFreq: 37900 Hz Clock: 40.000 MHz
800x600@72Hz 4:3 HorFreq: 48100 Hz Clock: 50.000 MHz
800x600@75Hz 4:3 HorFreq: 46900 Hz Clock: 49.500 MHz
832x624@75Hz 4:3 HorFreq: 49726 Hz Clock: 57.284 MHz
1024x768@60Hz 4:3 HorFreq: 48400 Hz Clock: 65.000 MHz
1024x768@70Hz 4:3 HorFreq: 56500 Hz Clock: 75.000 MHz
1024x768@75Hz 4:3 HorFreq: 60000 Hz Clock: 78.750 MHz
1280x1024@75Hz 5:4 HorFreq: 80000 Hz Clock: 135.000 MHz
1152x870@75Hz 192:145 HorFreq: 67500 Hz Clock: 108.000 MHz
Standard timings supported:
1152x864@75Hz 4:3 HorFreq: 67500 Hz Clock: 108.000 MHz
1280x800@60Hz 16:10
1280x720@60Hz 16:9
1280x1024@60Hz 5:4 HorFreq: 64000 Hz Clock: 108.000 MHz
1440x900@60Hz 16:10 HorFreq: 55500 Hz Clock: 88.750 MHz
1600x900@60Hz 16:9
1680x1050@60Hz 16:10 HorFreq: 64700 Hz Clock: 119.000 MHz
Detailed mode: Clock 265.250 MHz, 797 mm x 333 mm
3440 3488 3520 3600 hborder 0
1440 1443 1453 1474 vborder 0
+hsync -vsync
VertFreq: 49 Hz, HorFreq: 73680 Hz
Monitor ranges (GTF): 50-100Hz V, 30-152kHz H, max dotclock 550MHz
Monitor name: CF791
Serial number: H1AK500000
Has 1 extension blocks
Checksum: 0xe6 (valid)
CTA extension block
Extension version: 3
33 bytes of CTA data
Video data block
VIC 16 1920x1080@60Hz 16:9 (native) HorFreq: 67500 Hz Clock: 148.500 MHz
VIC 31 1920x1080@50Hz 16:9 HorFreq: 56250 Hz Clock: 148.500 MHz
VIC 4 1280x720@60Hz 16:9 HorFreq: 45000 Hz Clock: 74.250 MHz
VIC 19 1280x720@50Hz 16:9 HorFreq: 37500 Hz Clock: 74.250 MHz
VIC 3 720x480@60Hz 16:9 HorFreq: 31469 Hz Clock: 27.000 MHz
VIC 18 720x576@50Hz 16:9 HorFreq: 31250 Hz Clock: 27.000 MHz
VIC 5 1920x1080i@60Hz 16:9 HorFreq: 33750 Hz Clock: 74.250 MHz
VIC 90 2560x1080@60Hz 64:27 HorFreq: 66000 Hz Clock: 198.000 MHz
Audio data block
Linear PCM, max channels 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker allocation data block
Speaker map:
FL/FR - Front Left/Right
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 2.0.0.0
Supports_AI
Maximum TMDS clock: 300MHz
Vendor-specific data block, OUI c45dd8 (HDMI Forum)
Version: 1
Maximum TMDS Character Rate: 550MHz
SCDC Present
Underscans PC formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
1 native detailed modes
Detailed mode: Clock 319.750 MHz, 797 mm x 333 mm
1440 1443 1453 1481 vborder 0
+hsync -vsync
VertFreq: 59 Hz, HorFreq: 88819 Hz
Detailed mode: Clock 543.500 MHz, 797 mm x 333 mm
1440 1443 1453 1510 vborder 0
+hsync -vsync
VertFreq: 99 Hz, HorFreq: 150972 Hz
Detailed mode: Clock 241.500 MHz, 797 mm x 333 mm
2560 2608 2640 2720 hborder 0
1440 1443 1448 1481 vborder 0
+hsync -vsync
VertFreq: 59 Hz, HorFreq: 88786 Hz
Detailed mode: Clock 148.500 MHz, 0 mm x 0 mm
1920 2008 2052 2200 hborder 0
1080 1084 1089 1125 vborder 0
+hsync +vsync
VertFreq: 60 Hz, HorFreq: 67500 Hz
Checksum: 0x2e (valid)
Any help or ideas would be greatly appreciated.
Regards,
Robert
RaspJamZelzate
Sun Jan 10, 2021 11:22 am
Have now my uwqhd screen running proper resolution of 3440x1400 @ 60Hz on my PI400 Screen cable connected next to sd card slot.
sudo nano /boot/config.txt
[uwqhd]
hdmi_enable_4kp60=1
sudo reboot now
romal
Sun Jan 10, 2021 3:22 pm
I figured it out. Raspi4 with a Samsung CF791 connected to HDMI port 0 (the one next to the USB powerport).
gpu_mem=256
hdmi_aspect_21_9=7
hdmi_pixel_freq_limit=600000000
hdmi_group:0=2
hdmi_mode:0=87
framebuffer_width=3440
framebuffer_height=1440
max_framebuffer_width=3440
max_framebuffer_height=1440
Regards,
Robert
przemek
Wed Mar 03, 2021 7:48 am
It took me a while to make it working, so here's what I have in /boot/config.txt for iiyama G-Master GB3461WQSU-B1 34" 3440×1440. I hope someone will find it helpful:
hdmi_enable_4kp60=1
gpu_mem=256
hdmi_aspect_21_9=7
hdmi_group:0=2
hdmi_mode:0=87
thibaultmol
Tue Mar 23, 2021 8:44 am
przemek's settings also work for my iiyama ProLite XUB3493WQSU-B1
richfer2000
Tue Apr 13, 2021 2:01 am
Thanks - those settings helped me too! I have an Acer 34 inch widescreen monitor that can support HDMI at 100hz and Display Port at 144Hz in 3440x1440 resolution. These work flawlessly on my windows and mac devices, but were limited to 60hz in that resolution on a Raspberry pi. Using the above settings, when I changed the 60 number to 75, it switched to 75hz. However, i still cannot get 100hz support over HDMI when I change the settings of the hdmi_cvt command.
I cannot complain, but apart from thanking the above post, I also wanted to ask if there was a different hdmi_pixel_freq_limit that i need to use to support higher refresh rates?
Thanks again for everything.
RaspJamZelzate
Sun May 02, 2021 7:05 am
[uwqhd]
hdmi_enable_4kp60=1
sudo reboot now
Also tested and working fine on Ubuntu Desktop 20.10 for RPI
sudo nano /boot/firmware/config.txt
[uwqhd]
hdmi_enable_4kp60=1
sudo reboot now
Also tested and working fine on Ubuntu Desktop 21.04 for RPI
[uwqhd]
hdmi_enable_4kp60=1
sudo reboot now
fb0mbs
Sun Jul 04, 2021 1:04 am
Hello, new user here...
When I am in the config.txt files, where do I make these changes? I have a 3440x1440 MSI Optix MAG341CQ 34" that I have been unsuccessful to run my Raspberry Pi 4 off of. I am currently using it on my TV and would like to have it on my desk. Any help would be greatly appreciated.
