drdkccd
Need help with "undefined reference makedev"
Thu Aug 29, 2019 5:01 am
Hello RPi'ers
I have been trying to install WsprryPi app from GitHub and I cannot get it to ‘make’ properly.
I get through the download and the WsprryPi directory is there, but when I go to ‘make’ the program,
there are a lot of warnings and it ends in an error.
It reads ….. undefined reference to ‘makedev’
Then, exits with an ERROR
It looks like there is a missing C++ library, or some part of C++ is not installed.
I have built the RPi system properly and updated the OS.
Can someone please help me out here?
Dave Kenyon
Re: Need help with "undefined reference makedev"
Thu Aug 29, 2019 7:19 am
You don't need makedev on a system with device trees and udev.
Write a dumb program makedev.c
#include <stdlib.h>
int main (int argc, char* argc[]){
return 0;}
compile that and move it to /usr/local/sbin.
That should keep your stuff happy as it will do nothing and set a successful return code.
Paeryn
Thu Aug 29, 2019 11:03 am
The problem is a missing function called makedev, not a program.
makedev() is actually a macro and you need to include the correct header for it. At the top of mailbox.c add the following line
#include <sys/sysmacros.h>
I assume if the code used to compile under Stretch then one of the other includes used to include sysmacros but no longer does on Buster.
Kira the Koding Kitty, R.I.P. 8/3/24
DedBurd
Wed Nov 06, 2019 3:09 pm
Genius!!
Fixed my WsprryPi install in seconds....
Thanks. :D :D :D :D :D :D
