I recently purchased a Raspberry Pi 4b with 4 gigs memory and am using it as my desktop computer. It works nicely for a while (so not a connection issue) but eventually the wifi stops working and the only way I have found to get it back is to reboot. After this happens "sudo iwlist scan" fails, the wifi menu shows no options. I'm wondering if it is an overheating problem with the wifi chip, the more I use wifi the faster it happens and if I reboot without letting things cool down it reoccurs sooner.
Display set to 2160p, using a pimoroni case with power & hdmi connectors up, official power supply.
Re: Wifi stops working until reboot rpi 4b brcmfmac: firmware halted
This didn't happen for a few days, but happened twice today.
Looking in syslog, I find errors with the tag brcmfmac. Some occur every hour or so, but when the "firmware halted" happens I need to reboot to get wifi working:
Dec 18 20:01:18 raspberrypi kernel: [32602.760237] brcmfmac: brcmf_sdio_hostmail: mailbox indicates firmware halted
Dec 18 20:01:20 raspberrypi kernel: [32605.220455] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
Dec 18 20:01:20 raspberrypi kernel: [32605.220945] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
Dec 18 20:01:20 raspberrypi kernel: [32605.220963] brcmfmac: brcmf_run_escan: error (-110)
Dec 18 20:01:20 raspberrypi kernel: [32605.220976] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Dec 18 20:02:20 raspberrypi kernel: [32665.221558] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
Dec 18 20:02:20 raspberrypi kernel: [32665.222032] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
Dec 18 20:02:20 raspberrypi kernel: [32665.222051] brcmfmac: brcmf_run_escan: error (-110)
Dec 18 20:02:20 raspberrypi kernel: [32665.222064] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
Dec 18 20:03:20 raspberrypi kernel: [32725.222666] brcmfmac: brcmf_run_escan: error (-110)
The same problem occurs on a different Raspberry Pi 4B (4 gig) with a different case. (3rd party clear molded.) Same SD card, peripherals. If anything, it happened faster, which if it is heat is unsurprising since the case is not as well ventilated. Now trying in a different orientation.
I have the same problem. This is the package which could be generating the error:
# apt-cache policy firmware-brcm80211
firmware-brcm80211:
Installed: 1:20190114-1+rpt4
Candidate: 1:20190114-1+rpt4
Version table:
*** 1:20190114-1+rpt4 500
500 http://archive.raspberrypi.org/debian buster/main armhf Packages
100 /var/lib/dpkg/status
20190114-2 500
500 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages
Hmmm... I'll try "downgrading" to the version in raspbian rather than the version from the debain archives.
Worth a try anyway.
Worth a try anyway.
