Paccmpura
Can't update/upgrade old raspi. :(
Sun Jan 12, 2020 9:51 am
Hello dear All!
Just tried to "sudo apt-get update/upgrade" my RaspI and got this fault:
> Failed to fetch ht##tp://mirrordirector.raspbian.org/raspbian/dists/wheezy/.....
> Some index files failed to download. ...
How to fix the index files download URL(s) if that's the reason of fault, or what to do if the reason differs from that one?
Board: Raspberry Pi 4 mod.B,
OS: Raspbian Buster (сore 4.19.97-v7l+, #1294 SMP, 30.01.2020, armv7l, GNU/Linux
PeterO
Re: Can't update/upgrade old raspi. :(
Sun Jan 12, 2020 10:10 am
Probably it's just too old !
PeterO
Paccmpura
Sun Jan 12, 2020 10:32 am
PeterO
Sorry, but what do You mean exactly - too old hardware (Raspberry Pi 2 mod B), or just Wheezy's not supported anymore?
Sun Jan 12, 2020 10:43 am
Wheezy isn't updated now (it's too old).
The repo has been moved and archived.
The time to start with a fresh new install of Raspbian Buster is NOW!
buja
Sun Jan 12, 2020 10:47 am
Nothing wrong with a 2B, but Raspbian Wheezy is too old and I guess the links are not active anymore.
Time for a fresh installation of Raspbian Buster.
Backup your important files to a USB stick or something and put a fresh install of Raspbian Buster on the SD card. It might be a good time for a fresh SD card as well.
Paccmpura
Sun Jan 12, 2020 11:15 am
Thanks for explanations!
Then the next question is - will the RasPi 2 mod B carry Raspbian Buster? O'Henry: "Bolivar, he's plenty tired, and he can't carry double.")
buja
Sun Jan 12, 2020 11:24 am
Yes, Raspbian Buster runs very well on a 2B, no problem at all.
Paccmpura
Sun Jan 12, 2020 11:32 am
Sounds very good! Thank you! :D
[... mooving to Buster!]
GlowInTheDark
Sun Jan 12, 2020 11:34 am
I've noticed that Wheezy systems no longer can get new software (get errors as reported by OP).
But the note above that the Wheezy repo has been moved/archived gives me hope that it still does exist, in some form. Is that the case? If so, can it still be used?
And, no, the whole point of this question is that "updating" the system is not an option. If it were, there would be no problem.
Poster of inconvenient truths.
Back from a short, unplanned vacation. Did you miss me?
Sun Jan 12, 2020 11:36 am
Hello dear All!
Yes Wheezy repositories being archived / moved has been discussed:
https://www.raspberrypi.org/forums/view ... p?t=242895
Paccmpura
Sun Jan 12, 2020 1:03 pm
Thanks to All of you! :D
Finally, I've got updated Wheezy from 'legacy.raspbian.org/raspbian' (as good as it got), then saved command line history to recall all config file editions, app installations, git clonings etc., and now I'll backup SD-card (just in case) and move to the Raspbian Buster.
