timg11
Installing lirc with GPIO-based interface - irsend won't work
Sat Feb 01, 2020 6:16 pm
Using Raspbian GNU/Linux 9 (stretch) on a Pi 3B.
$ uname -a
Linux Pi3B-TG2 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
I have this IR interface with the IR transmitter and receiver on GPIO 17 and 18 respectively.
The configuration instructions are linked from the page and here.
I've installed lirc (sudo apt-get install lirc),
I edited config.txt (sudo nano /boot/config.txt) to change like this:
# Uncomment this to enable the lirc-rpi module
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_out_pin=17
I created /etc/lirc/hardware.conf to look like this:
LIRCD_ARGS="--uinput --listen"
LOAD_MODULES=true
DRIVER="default"
DEVICE="/dev/lirc0"
MODULES="lirc_rpi"
I changed /etc/lirc/lirc_options.conf to look like this:
[lircd]
nodaemon        = False
driver          = default
device          = /dev/lirc0
I stopped and restarted lirc:
pi@Pi3B-TG2:/etc/lirc $ sudo /etc/init.d/lircd stop
[ ok ] Stopping lircd (via systemctl): lircd.service.
pi@Pi3B-TG2:/etc/lirc $ sudo /etc/init.d/lircd start
[ ok ] Starting lircd (via systemctl): lircd.service.
Based on the guidance at lirc.org I should be able to get a response of installed drivers, etc from ir-keytable.
Expected response as shown in example from lirc.org:
    $ ir-keytable
    Found /sys/class/rc/rc0/ (/dev/input/event11) with:
        Driver em28xx, table rc-pinnacle-pctv-hd
        Supported protocols: NEC RC-5 RC-6
        Enabled protocols: RC-5
Actual response from my installation:
pi@Pi3B-TG2:~ $ ir-keytable
Found /sys/class/rc/rc1/ (/dev/input/event3) with:
        Driver gpio_ir_recv, table rc-rc6-mce
        Supported protocols: other lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp
        Enabled protocols: lirc
        bus: 25, vendor/product: 0001:0001, version: 0x0100
        Repeat delay = 500 ms, repeat period = 125 ms
Couldn't find any node at /sys/class/rc/rc0/input*.
Cannot send with irsend:
pi@Pi3B-TG2:~ $ sudo irsend SEND_ONCE  RD6831 KEY_OPEN
hardware does not support sending
Error running command: Input/output error
Trying other Test and debug tools from lirc.org:
pi@Pi3B-TG2:~ $ mode2
Using driver default on device /dev/lirc0
Cannot initiate device /dev/lirc0
pi@Pi3B-TG2:~ $ lirc-config-tool
Output dir:
    /home/pi/.config/lirc
Scanned /etc/lirc/lircd.conf
    Found 0 key symbols.
Created:
    mode_browser.lircrc
    mode_numeric.lircrc
    mplayer.lircrc
    mythtv.lircrc
    vlc.lircrc
    vlc_popupmenu_mode.lircrc
    volume_alsa.lircrc
    volume_mythtv.lircrc
    volume_pulse.lircrc
lirc-setup
pi@Pi3B-TG2:~ $ lirc-setup
Unable to init server: Could not connect: Connection refused
  File "/usr/bin/lirc-setup", line 10, in <module>
    import mvc_control
  File "/usr/lib/arm-linux-gnueabihf/python3/dist-packages/lirc/mvc_control.py", line 16, in <module>
    import mvc_view
  File "/usr/lib/arm-linux-gnueabihf/python3/dist-packages/lirc/mvc_view.py", line 12, in <module>
    gi.require_version('Vte', '2.91')
  File "/usr/lib/python3/dist-packages/gi/__init__.py", line 118, in require_version
    raise ValueError('Namespace %s not available' % namespace)
ValueError: Namespace Vte not available
From the lirc.org configuration guide:
pi@Pi3B-TG2:~ $ sudo systemctl status lircd.socket lircd.service
● lircd.socket
   Loaded: loaded (/lib/systemd/system/lircd.socket; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2020-02-01 11:51:48 CST; 1h 36min ago
   Listen: /run/lirc/lircd (Stream)
Feb 01 11:51:48 Pi3B-TG2 systemd[1]: Listening on lircd.socket.
● lircd.service - Flexible IR remote input/output application support
   Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2020-02-01 11:51:50 CST; 1h 36min ago
     Docs: man:lircd(8)
           http://lirc.org/html/configure.html
 Main PID: 481 (lircd)
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/lircd.service
           └─481 /usr/sbin/lircd --nodaemon
Feb 01 11:51:51 Pi3B-TG2 lircd[481]: lircd-0.9.4c[481]: Warning: Failed to initialize hardware
Feb 01 11:51:51 Pi3B-TG2 lircd[481]: lircd-0.9.4c[481]: Notice: accepted new client on /var/run/lirc/lircd
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: Notice: accepted new client on /var/run/lirc/lircd
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: Info: [b]Cannot configure the rc device for /dev/lirc0
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: Error: could not get file information for /dev/lirc0
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: default_init(): No such file or directory[/b]
Feb 01 11:51:51 Pi3B-TG2 lircd-0.9.4c[481]: Warning: Failed to initialize hardware
pi@Pi3B-TG2:~ $
timg11
Re: Installing lirc with GPIO-based interface - ir-keytable not found
Sat Feb 01, 2020 8:01 pm
Maybe getting on the right track - this article says kernel 4.19 changes things:
Changes to config.txt
dtoverlay=gpio-ir,gpio_pin=18
dtoverlay=gpio-ir-tx,gpio_pin=17
I am able to get mode2 to work for receiving:
sudo mode2 -d /dev/lirc1
push button on remote…..
pi@Pi3B-TG2:~ $ sudo mode2 -d /dev/lirc1
Using driver default on device /dev/lirc1
Trying device: /dev/lirc1
Using device: /dev/lirc1
Running as regular user pi
pulse 933
space 857
pulse 919
space 857
pulse 920
^C
I then edit lirc_options.conf to
device = lirc0
so I can use the output. I restart lirc. Then I try irsend:
pi@Pi3B-TG2:~ $
I am looking for a fix to that problem now...
Modules are present:
pi@Pi3B-TG2:~ $ find /lib/modules/4.19.66-v7+/ -name "gpio-ir*"
/lib/modules/4.19.66-v7+/kernel/drivers/media/rc/gpio-ir-recv.ko
/lib/modules/4.19.66-v7+/kernel/drivers/media/rc/gpio-ir-tx.ko
pi@Pi3B-TG2:~ $ lsmod | grep gpio
gpio_ir_recv           16384  0
gpio_ir_tx             16384  0
pi@Pi3B-TG2:~ $
pi@Pi3B-TG2:~ $ ls -al /dev/lirc*
crw-rw---- 1 root video 252, 0 Feb  1 14:01 /dev/lirc0
crw-rw---- 1 root video 252, 1 Feb  1 14:01 /dev/lirc1
pi@Pi3B-TG2:~ $
timg11
Re: Installing lirc with GPIO-based interface - irsend won't work
Sun Feb 02, 2020 7:23 pm
I did a clean flash from 2018-06-27-raspbian-stretch.img.
I now have
 $ cat /etc/debian_version
9.4
$ uname -a
Linux Pi3-TG2 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l GNU/Linux
I am now able to use lirc successfully. Lots of time struggling with 4.19, finally had to abandon.
Another important discovery, that appears to be necessary even with 4.14 kernel. I was still getting "irsend: hardware does not support sending"
This article provides a different way to start the LIRC daemon in the last post.
"...run following command in console:
sudo lircd --device /dev/lirc0
to start LIRC daemon..."
If you get the error "lircd: there seems to already be a lircd process", then precede with
