hectorkvs
RPi4 freezes after last (today) update [solved]
Thu May 28, 2020 11:01 pm
I have three RPi4 4 Gb and the latest Raspbian image on all of them, two on SD cards and one on SSD and after today upgrade i have random freezes and black screen on all of them, especially when watching Youtube in Chromium..before the last update, everything was perfect..anyone else with this issue? I'm still using old or last official kernal 4.19.118-v7l+ , no OC on all three Pi's.
Raspberry4thewin
Re: RPi4 freezes after last (today) update
Fri May 29, 2020 12:54 am
Same updated the OS and started to watch Twitch.tv and would black screen. On me went back to 2020-02-13-raspbian-buster-full... No issues now.
Raspberry4thewin
Fri May 29, 2020 1:22 am
Same happen to me I was watching twitch tv fine before the OS update. After it black screen on me about 10 sec end to trying to watch a stream. I went back to previous 2020-02-13 raspbian-buster-full . Starting watching Twitch again and haven't had any more issues.
kenkrsme
Sat May 30, 2020 7:29 am
I am also having this issue. black screen, completely unresponsive. always associated with video playback. i have seen it with youtube, twitch, and random autoplay videos on news sites.
paulja17
Sat May 30, 2020 8:17 am
I'm getting the same, black screen, unresponsive when trying to play youtube video's in Chromium after the latest update. youtube in Firefox works fine. This is on a RaspberryPi 4 2GB.
hectorkvs
Sat May 30, 2020 11:33 am
I am also having this issue. black screen, completely unresponsive. always associated with video playback. i have seen it with youtube, twitch, vlc, and random autoplay videos on news sites.
That's exactly what is happening to all of my 3 Pi's...definitely related with video playback after last upgrade..black screen,unresponsive and freezing.
gsh
Sat May 30, 2020 11:51 am
Can you right click on the YouTube and get the stats to make sure it's h264 not vp8?
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Sat May 30, 2020 12:20 pm
Can you give a url that definitely shows the problem?
What is hdmi resolution. Are you watching in default window size or switched to fullscreen?
Is this is with default config.txt (e.g. no overclock)?
Roughly how long do I need to watch for before seeing an issue? (e.g. seconds/minutes/hours)
gsh
Sat May 30, 2020 12:25 pm
Mine seems to be broken as well... I can't see any good video from youtube
Only way to watch it is to disable h264ify and let it play is VP9
Gordon
kenkrsme
Sat May 30, 2020 12:35 pm
H264, cant find a link that makes it do it consistently. i have reinstalled 3 times to try to remedy this. with or without overclock. sometimes happens just as a video loads. sometimes after watching for several minutes and through several videos. also has happened after leaving a video pauses for several minutes and then hitting play caused it to go black. again i can not make it happen. i dont general watch videos in fullscreen on this pi so im not sure about that.
not sure if its the cause, but seemed to start after going to usb-msd boot.
rainer.brito
Sat May 30, 2020 12:56 pm
Hi!
I believe it is the same issue reported in these threads:
viewtopic.php?f=66&t=275414
viewtopic.php?f=28&t=275640
I confirm the issue and would like to add that my wifi is much less stable after the upgrade. As everyone said, it is a complete system freeze.
With a raspbian image around 2 weeks older everything is fine. I also made a point about the issue in the USB boot thread -- I believe there is something related to the recents upgrades of rpi-eeprom.
Best and take care!
hectorkvs
Sat May 30, 2020 1:03 pm
There is no specific situation that i can recreate, it's random..when watching YT or some other video..VLC, Live TV in Chromium etc..it happens sometimes after few minutes, sometimes after few seconds..screen go black and system unresponsive no matter if it's in full screen or windowed..as i've said, i have 3 RPi4 all with different resolution and not OC..2 are on full HD and one is on 720p, all three attached on different screens..the only thing that is the same for all of 3 is the latest Raspbian i've upgraded 2 days ago..before upgrade everything was ok
Update: i've tried disabling h264 and watching with vp9 enabled, result is the same..Live TV in Chromium after few seconds screen goes black..needed to pull power cable off..i think this is definitely Chromium related,cos i cant't even acces Chromium settings page without Aw,Snap! warning...Firefox works ok so far..
hectorkvs
Sat May 30, 2020 2:38 pm
Find out one video from YT that will definitely force system to go black and freeze Pi.. https://www.youtube.com/watch?v=KDGL4T1vnxA
kenkrsme
Sat May 30, 2020 2:42 pm
this live feed made it go black
https://www.youtube.com/watch?v=uexTqJGzFtE
doesnt matter if its usb-msd boot or sd+ssd boot. i can confirm that doesnt change anything.
i can also confirm this video made mine got black.
Doug_
Sat May 30, 2020 2:53 pm
Same crash for me. Chromium -> YouTube Try to stream SpaceX live stream results in immediate black screen.
Doug_
Sat May 30, 2020 2:55 pm
How does one do that?
Sat May 30, 2020 3:15 pm
It's a chromium addon. Click on its icon (h) in top right of chromium window and uncheck "Enable h264ify"
M.aD
Sat May 30, 2020 4:51 pm
So far i have been able to play a couple of youtube videos without the pi locking up after disabeling the h264ify extension. Thanks for the tip.
li20034
Sat May 30, 2020 5:56 pm
I've also been having this issue. It seems like downgrading the raspberrypi-bootloader (aka VideoCore firmware) package to this (http://archive.raspberrypi.org/debian/p ... _armhf.deb) alone resolves the issue for me.
Sat May 30, 2020 6:00 pm
Can those people seeing the issue provide a little more information please. For example, the resolution of the display you are using, anything unusual about your setup etc. Full screen, windowed. What board revision are you using (cat /proc/cpuinfo), that sort of thing. Are you using new installs or upgraded systems etc. Anything that can give us a hint as to the combination that causes the issue.
li20034
Sat May 30, 2020 6:50 pm
The display I'm using is 1920x1080 (60Hz) and it's connected via a few adapters (Micro HDMI -> HDMI -> DVI). I don't have any displays with a native HDMI input. I've only seen it happen in windowed mode, but I haven't watched many videos in fullscreen lately. This is an upgraded install (original image was downloaded in late March).
Last few lines of /proc/cpuinfo (serial is removed because I'm paranoid):
Hardware	: BCM2835
Revision	: c03112
Serial		:
Model		: Raspberry Pi 4 Model B Rev 1.2
config.txt is left at default except the following changes:
disable_overscan=1
# resolution autodetect fails (likely due to the chain of adapters I'm using), so I have to force it
[HDMI:0]
hdmi_drive=1
hdmi_group=2
hdmi_mode=82
EDIT: I also uninstalled xcompmgr last month (after which 1080p youtube playback was a lot smoother)
M.aD
Sat May 30, 2020 6:58 pm
The issue occurred to me after the update came out and after that i tried a clean install with the new image but stil the problem exists. The video playback issue happens when windowed and fullscreen in Chromium. The screen resolution is 1920 x 1080 and the Raspberry Pi 4 4GB is connected with Micro HDMI -> HDMI.
processor	: 0
model name	: ARMv7 Processor rev 3 (v7l)
BogoMIPS	: 108.00
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 1
BogoMIPS	: 108.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 2
BogoMIPS	: 108.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 3
BogoMIPS	: 108.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
Hardware	: BCM2835
Revision 	: c03112
Serial		: 10000000477bb51c
billybangleballs
Sat May 30, 2020 7:21 pm
Hardware : BCM2835
Revision : c03112
Serial : 10000000e30d88b9
Linux sane4 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
Running a fully updated 2020-02-13-raspbian-buster on a 4GB Raspberry Pi 4 Model B Rev 1.2
Using the legacy driver and one HD monitor @ 1920x1080x60Hz
All running off a 32GB sdcard
The bootloader is stock, I have no fancy applications other than the ones that came in the image and subsequent upgrades.
Raspberry Pi reference 2020-02-13
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 5f884374b6ac6e155330c58caa1fb7249b8badf1, stage4
I did apt-get full-upgrade yesterday (Friday) morning, and since then I have suffered a series of crashes.
The screen goes black, and no logging occurs until after I pull the plug and replace it.
It seems to be when I click an embedded youtube video in chromium.
The most recent occurrence was an embedded video in https://hackaday.com/2020/05/29/creatin ... -learning/, the debug info is :-
  "ns": "yt",
  "el": "embedded",
  "cpn": "2uLP522VdEzA1u9i",
  "docid": "xu4m9_3HcHY",
  "ver": 2,
  "cmt": "0",
  "ei": "zKXSXqDTGOqOxgK76Lu4Dg",
  "fs": "0",
  "rt": "0.001",
  "euri": "https://hackaday.com/2020/05/29/creating-surreal-short-films-from-machine-learning/",
  "lact": 22,
  "cl": "313467982",
  "mos": 0,
  "state": "40",
  "volume": 100,
  "c": "WEB_EMBEDDED_PLAYER",
  "cver": "20200529",
  "cplayer": "UNIPLAYER",
  "cbr": "Chrome",
  "cbrver": "78.0.3904.108",
  "cos": "X11",
  "hl": "en_GB",
  "cr": "GB",
  "len": "261",
  "fexp": "23744176,23804281,23837040,23837993,23839597,23856950,23857950,23859802,23876458,23880389,23882503,23884386,23886825,23891856,23898053,23900839,23901904,23902105,23905291,23906756,23907595,23908963,9406175,9449243",
  "size": "449:799",
  "inview": "1",
  "vct": "0.000",
  "vd": "NaN",
  "vpl": "",
  "vbu": "",
  "vpa": "1",
  "vsk": "0",
  "ven": "0",
  "vpr": "1",
  "vrs": "0",
  "vns": "0",
  "vec": "null",
  "vemsg": "",
  "vvol": "1",
  "vdom": "1",
  "vsrc": "0",
  "vw": 799,
  "vh": 449,
  "relative_loudness": "NaN",
  "user_qual": "auto",
  "debug_videoId": "xu4m9_3HcHY",
  "0sz": false,
  "op": "",
  "yof": true,
  "dis": "",
  "gpu": "llvmpipe_(LLVM_9.0.1,_128_bits)",
  "cgr": true,
  "debug_playbackQuality": "unknown",
  "debug_date": "Sat May 30 2020 19:59:21 GMT+0100 (British Summer Time)"
I have since watched the video with no issues, so I don't think it is the fault of youtube.
The LEDs on the network jack continue to flicker and flash, but the Raspberry Pi does not respond to pings from other machines on the network and is completely unresponsive.
It is set up to log to a remote syslog machine, but nothing appears in these logs once the screen goes black.
This has never happened in the past, it is due to some change that occurred when I upgraded yesterday morning.
2020-05-29 11:35:17 startup archives unpack
2020-05-29 11:35:17 install libaio1:armhf <none> 0.3.112-3
2020-05-29 11:35:17 status triggers-pending libc-bin:armhf 2.28-10+rpi1
2020-05-29 11:35:17 status half-installed libaio1:armhf 0.3.112-3
2020-05-29 11:35:17 status unpacked libaio1:armhf 0.3.112-3
2020-05-29 11:35:17 install libglusterfs0:armhf <none> 5.5-3
2020-05-29 11:35:17 status half-installed libglusterfs0:armhf 5.5-3
2020-05-29 11:35:18 status unpacked libglusterfs0:armhf 5.5-3
2020-05-29 11:35:18 install libgfxdr0:armhf <none> 5.5-3
2020-05-29 11:35:18 status half-installed libgfxdr0:armhf 5.5-3
2020-05-29 11:35:18 status unpacked libgfxdr0:armhf 5.5-3
2020-05-29 11:35:18 install libgfrpc0:armhf <none> 5.5-3
2020-05-29 11:35:18 status half-installed libgfrpc0:armhf 5.5-3
2020-05-29 11:35:18 status unpacked libgfrpc0:armhf 5.5-3
2020-05-29 11:35:18 install libgfapi0:armhf <none> 5.5-3
2020-05-29 11:35:18 status half-installed libgfapi0:armhf 5.5-3
2020-05-29 11:35:19 status unpacked libgfapi0:armhf 5.5-3
2020-05-29 11:35:19 install libibverbs1:armhf <none> 22.1-1
2020-05-29 11:35:19 status half-installed libibverbs1:armhf 22.1-1
2020-05-29 11:35:19 status unpacked libibverbs1:armhf 22.1-1
2020-05-29 11:35:19 install libnuma1:armhf <none> 2.0.12-1
2020-05-29 11:35:19 status half-installed libnuma1:armhf 2.0.12-1
2020-05-29 11:35:19 status unpacked libnuma1:armhf 2.0.12-1
2020-05-29 11:35:19 install libboost-regex1.67.0:armhf <none> 1.67.0-13+deb10u1
2020-05-29 11:35:19 status half-installed libboost-regex1.67.0:armhf 1.67.0-13+deb10u1
2020-05-29 11:35:19 status unpacked libboost-regex1.67.0:armhf 1.67.0-13+deb10u1
2020-05-29 11:35:19 install librados2:armhf <none> 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:19 status half-installed librados2:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:20 status unpacked librados2:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:20 install librbd1:armhf <none> 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:20 status half-installed librbd1:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:21 status unpacked librbd1:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:21 install librdmacm1:armhf <none> 22.1-1
2020-05-29 11:35:21 status half-installed librdmacm1:armhf 22.1-1
2020-05-29 11:35:21 status unpacked librdmacm1:armhf 22.1-1
2020-05-29 11:35:21 install fio:armhf <none> 3.12-2
2020-05-29 11:35:21 status half-installed fio:armhf 3.12-2
2020-05-29 11:35:21 status triggers-pending systemd:armhf 241-7~deb10u4+rpi1
2020-05-29 11:35:21 status triggers-pending man-db:armhf 2.8.5-2
2020-05-29 11:35:21 status unpacked fio:armhf 3.12-2
2020-05-29 11:35:21 install agnostics:armhf <none> 0.4
2020-05-29 11:35:21 status half-installed agnostics:armhf 0.4
2020-05-29 11:35:21 status triggers-pending gnome-menus:armhf 3.31.4-3
2020-05-29 11:35:22 status triggers-pending desktop-file-utils:armhf 0.23-4
2020-05-29 11:35:22 status triggers-pending mime-support:all 3.62
2020-05-29 11:35:22 status unpacked agnostics:armhf 0.4
2020-05-29 11:35:22 upgrade binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi1 2.31.1-16+rpi2
2020-05-29 11:35:22 status half-configured binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi1
2020-05-29 11:35:22 status unpacked binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi1
2020-05-29 11:35:22 status half-installed binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi1
2020-05-29 11:35:22 status unpacked binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi2
2020-05-29 11:35:22 upgrade libbinutils:armhf 2.31.1-16+rpi1 2.31.1-16+rpi2
2020-05-29 11:35:22 status half-configured libbinutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status unpacked libbinutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status half-installed libbinutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status unpacked libbinutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:23 upgrade binutils:armhf 2.31.1-16+rpi1 2.31.1-16+rpi2
2020-05-29 11:35:23 status half-configured binutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status unpacked binutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status half-installed binutils:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status unpacked binutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:23 upgrade binutils-common:armhf 2.31.1-16+rpi1 2.31.1-16+rpi2
2020-05-29 11:35:23 status half-configured binutils-common:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status unpacked binutils-common:armhf 2.31.1-16+rpi1
2020-05-29 11:35:23 status half-installed binutils-common:armhf 2.31.1-16+rpi1
2020-05-29 11:35:24 status unpacked binutils-common:armhf 2.31.1-16+rpi2
2020-05-29 11:35:25 install libfl2:armhf <none> 2.6.4-6.2
2020-05-29 11:35:25 status half-installed libfl2:armhf 2.6.4-6.2
2020-05-29 11:35:25 status unpacked libfl2:armhf 2.6.4-6.2
2020-05-29 11:35:25 install ibverbs-providers:armhf <none> 22.1-1
2020-05-29 11:35:25 status half-installed ibverbs-providers:armhf 22.1-1
2020-05-29 11:35:25 status unpacked ibverbs-providers:armhf 22.1-1
2020-05-29 11:35:25 install lxplug-magnifier:armhf <none> 0.2
2020-05-29 11:35:25 status half-installed lxplug-magnifier:armhf 0.2
2020-05-29 11:35:25 status unpacked lxplug-magnifier:armhf 0.2
2020-05-29 11:35:25 install rpi.gpio-common:armhf <none> 0.7.0-0.1~bpo10+1
2020-05-29 11:35:25 status half-installed rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:25 status unpacked rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:26 upgrade python-rpi.gpio:armhf 0.7.0~buster-1 0.7.0-0.1~bpo10+1
2020-05-29 11:35:26 status half-configured python-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:26 status unpacked python-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:26 status half-installed python-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:26 status unpacked python-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:26 upgrade python3-rpi.gpio:armhf 0.7.0~buster-1 0.7.0-0.1~bpo10+1
2020-05-29 11:35:26 status half-configured python3-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:27 status unpacked python3-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:27 status half-installed python3-rpi.gpio:armhf 0.7.0~buster-1
2020-05-29 11:35:27 status unpacked python3-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:27 install rp-bookshelf:armhf <none> 0.3
2020-05-29 11:35:27 status half-installed rp-bookshelf:armhf 0.3
2020-05-29 11:35:27 status triggers-pending hicolor-icon-theme:all 0.17-2
2020-05-29 11:35:27 status unpacked rp-bookshelf:armhf 0.3
2020-05-29 11:35:27 upgrade raspberrypi-ui-mods:all 1.20200218 1.20200514
2020-05-29 11:35:27 status half-configured raspberrypi-ui-mods:all 1.20200218
2020-05-29 11:35:27 status unpacked raspberrypi-ui-mods:all 1.20200218
2020-05-29 11:35:27 status half-installed raspberrypi-ui-mods:all 1.20200218
2020-05-29 11:35:27 status triggers-pending shared-mime-info:armhf 1.10-1
2020-05-29 11:35:28 status unpacked raspberrypi-ui-mods:all 1.20200514
2020-05-29 11:35:28 startup packages configure
2020-05-29 11:35:28 configure libibverbs1:armhf 22.1-1 <none>
2020-05-29 11:35:28 status unpacked libibverbs1:armhf 22.1-1
2020-05-29 11:35:28 status half-configured libibverbs1:armhf 22.1-1
2020-05-29 11:35:29 status installed libibverbs1:armhf 22.1-1
2020-05-29 11:35:29 configure libboost-regex1.67.0:armhf 1.67.0-13+deb10u1 <none>
2020-05-29 11:35:29 status unpacked libboost-regex1.67.0:armhf 1.67.0-13+deb10u1
2020-05-29 11:35:29 status half-configured libboost-regex1.67.0:armhf 1.67.0-13+deb10u1
2020-05-29 11:35:29 status installed libboost-regex1.67.0:armhf 1.67.0-13+deb10u1
2020-05-29 11:35:29 configure ibverbs-providers:armhf 22.1-1 <none>
2020-05-29 11:35:29 status unpacked ibverbs-providers:armhf 22.1-1
2020-05-29 11:35:29 status half-configured ibverbs-providers:armhf 22.1-1
2020-05-29 11:35:29 status installed ibverbs-providers:armhf 22.1-1
2020-05-29 11:35:29 configure rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1 <none>
2020-05-29 11:35:29 status unpacked rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 status half-configured rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 status installed rpi.gpio-common:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 configure binutils-common:armhf 2.31.1-16+rpi2 <none>
2020-05-29 11:35:29 status unpacked binutils-common:armhf 2.31.1-16+rpi2
2020-05-29 11:35:29 status half-configured binutils-common:armhf 2.31.1-16+rpi2
2020-05-29 11:35:29 status installed binutils-common:armhf 2.31.1-16+rpi2
2020-05-29 11:35:29 configure python3-rpi.gpio:armhf 0.7.0-0.1~bpo10+1 <none>
2020-05-29 11:35:29 status unpacked python3-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 status half-configured python3-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 status installed python3-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:29 configure libglusterfs0:armhf 5.5-3 <none>
2020-05-29 11:35:29 status unpacked libglusterfs0:armhf 5.5-3
2020-05-29 11:35:29 status half-configured libglusterfs0:armhf 5.5-3
2020-05-29 11:35:29 status installed libglusterfs0:armhf 5.5-3
2020-05-29 11:35:29 configure lxplug-magnifier:armhf 0.2 <none>
2020-05-29 11:35:29 status unpacked lxplug-magnifier:armhf 0.2
2020-05-29 11:35:29 status half-configured lxplug-magnifier:armhf 0.2
2020-05-29 11:35:29 status installed lxplug-magnifier:armhf 0.2
2020-05-29 11:35:29 configure raspberrypi-ui-mods:all 1.20200514 <none>
2020-05-29 11:35:29 status unpacked raspberrypi-ui-mods:all 1.20200514
2020-05-29 11:35:30 status half-configured raspberrypi-ui-mods:all 1.20200514
2020-05-29 11:35:31 status installed raspberrypi-ui-mods:all 1.20200514
2020-05-29 11:35:31 configure libfl2:armhf 2.6.4-6.2 <none>
2020-05-29 11:35:31 status unpacked libfl2:armhf 2.6.4-6.2
2020-05-29 11:35:31 status half-configured libfl2:armhf 2.6.4-6.2
2020-05-29 11:35:31 status installed libfl2:armhf 2.6.4-6.2
2020-05-29 11:35:31 configure rp-bookshelf:armhf 0.3 <none>
2020-05-29 11:35:31 status unpacked rp-bookshelf:armhf 0.3
2020-05-29 11:35:31 status half-configured rp-bookshelf:armhf 0.3
2020-05-29 11:35:31 status installed rp-bookshelf:armhf 0.3
2020-05-29 11:35:31 configure libnuma1:armhf 2.0.12-1 <none>
2020-05-29 11:35:31 status unpacked libnuma1:armhf 2.0.12-1
2020-05-29 11:35:31 status half-configured libnuma1:armhf 2.0.12-1
2020-05-29 11:35:31 status installed libnuma1:armhf 2.0.12-1
2020-05-29 11:35:31 configure python-rpi.gpio:armhf 0.7.0-0.1~bpo10+1 <none>
2020-05-29 11:35:31 status unpacked python-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:31 status half-configured python-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:31 status installed python-rpi.gpio:armhf 0.7.0-0.1~bpo10+1
2020-05-29 11:35:31 configure libbinutils:armhf 2.31.1-16+rpi2 <none>
2020-05-29 11:35:31 status unpacked libbinutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status half-configured libbinutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status installed libbinutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 configure libaio1:armhf 0.3.112-3 <none>
2020-05-29 11:35:31 status unpacked libaio1:armhf 0.3.112-3
2020-05-29 11:35:31 status half-configured libaio1:armhf 0.3.112-3
2020-05-29 11:35:31 status installed libaio1:armhf 0.3.112-3
2020-05-29 11:35:31 configure binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi2 <none>
2020-05-29 11:35:31 status unpacked binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status half-configured binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status installed binutils-arm-linux-gnueabihf:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 configure libgfxdr0:armhf 5.5-3 <none>
2020-05-29 11:35:31 status unpacked libgfxdr0:armhf 5.5-3
2020-05-29 11:35:31 status half-configured libgfxdr0:armhf 5.5-3
2020-05-29 11:35:31 status installed libgfxdr0:armhf 5.5-3
2020-05-29 11:35:31 configure librdmacm1:armhf 22.1-1 <none>
2020-05-29 11:35:31 status unpacked librdmacm1:armhf 22.1-1
2020-05-29 11:35:31 status half-configured librdmacm1:armhf 22.1-1
2020-05-29 11:35:31 status installed librdmacm1:armhf 22.1-1
2020-05-29 11:35:31 configure librados2:armhf 12.2.11+dfsg1-2.1+rpi1 <none>
2020-05-29 11:35:31 status unpacked librados2:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 status half-configured librados2:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 status installed librados2:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 configure binutils:armhf 2.31.1-16+rpi2 <none>
2020-05-29 11:35:31 status unpacked binutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status half-configured binutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 status installed binutils:armhf 2.31.1-16+rpi2
2020-05-29 11:35:31 configure librbd1:armhf 12.2.11+dfsg1-2.1+rpi1 <none>
2020-05-29 11:35:31 status unpacked librbd1:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 status half-configured librbd1:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 status installed librbd1:armhf 12.2.11+dfsg1-2.1+rpi1
2020-05-29 11:35:31 configure libgfrpc0:armhf 5.5-3 <none>
2020-05-29 11:35:31 status unpacked libgfrpc0:armhf 5.5-3
2020-05-29 11:35:31 status half-configured libgfrpc0:armhf 5.5-3
2020-05-29 11:35:31 status installed libgfrpc0:armhf 5.5-3
2020-05-29 11:35:32 configure libgfapi0:armhf 5.5-3 <none>
2020-05-29 11:35:32 status unpacked libgfapi0:armhf 5.5-3
2020-05-29 11:35:32 status half-configured libgfapi0:armhf 5.5-3
2020-05-29 11:35:32 status installed libgfapi0:armhf 5.5-3
2020-05-29 11:35:32 configure fio:armhf 3.12-2 <none>
2020-05-29 11:35:32 status unpacked fio:armhf 3.12-2
2020-05-29 11:35:32 status half-configured fio:armhf 3.12-2
2020-05-29 11:35:32 status installed fio:armhf 3.12-2
2020-05-29 11:35:32 configure agnostics:armhf 0.4 <none>
2020-05-29 11:35:32 status unpacked agnostics:armhf 0.4
2020-05-29 11:35:32 status half-configured agnostics:armhf 0.4
2020-05-29 11:35:32 status installed agnostics:armhf 0.4
2020-05-29 11:35:32 trigproc man-db:armhf 2.8.5-2 <none>
2020-05-29 11:35:32 status half-configured man-db:armhf 2.8.5-2
2020-05-29 11:35:33 status installed man-db:armhf 2.8.5-2
2020-05-29 11:35:33 trigproc shared-mime-info:armhf 1.10-1 <none>
2020-05-29 11:35:33 status half-configured shared-mime-info:armhf 1.10-1
2020-05-29 11:35:43 status installed shared-mime-info:armhf 1.10-1
2020-05-29 11:35:43 trigproc desktop-file-utils:armhf 0.23-4 <none>
2020-05-29 11:35:43 status half-configured desktop-file-utils:armhf 0.23-4
2020-05-29 11:35:43 status installed desktop-file-utils:armhf 0.23-4
2020-05-29 11:35:43 trigproc mime-support:all 3.62 <none>
2020-05-29 11:35:43 status half-configured mime-support:all 3.62
2020-05-29 11:35:43 status installed mime-support:all 3.62
2020-05-29 11:35:43 trigproc hicolor-icon-theme:all 0.17-2 <none>
2020-05-29 11:35:43 status half-configured hicolor-icon-theme:all 0.17-2
2020-05-29 11:35:44 status installed hicolor-icon-theme:all 0.17-2
2020-05-29 11:35:44 trigproc gnome-menus:armhf 3.31.4-3 <none>
2020-05-29 11:35:44 status half-configured gnome-menus:armhf 3.31.4-3
2020-05-29 11:35:44 status installed gnome-menus:armhf 3.31.4-3
2020-05-29 11:35:44 trigproc libc-bin:armhf 2.28-10+rpi1 <none>
2020-05-29 11:35:44 status half-configured libc-bin:armhf 2.28-10+rpi1
2020-05-29 11:35:44 status installed libc-bin:armhf 2.28-10+rpi1
2020-05-29 11:35:44 trigproc systemd:armhf 241-7~deb10u4+rpi1 <none>
2020-05-29 11:35:44 status half-configured systemd:armhf 241-7~deb10u4+rpi1
2020-05-29 11:35:45 status installed systemd:armhf 241-7~deb10u4+rpi1
I usually apt-get upgrade about once a week
I had claws-mail, chromium, rdesktop and vlc open at the time of the last crash, and probably a PCManFM window or two.
It doesn't crash every time, and I can't force it to crash by following some sequence of clicking or typing.
I wish I could tell you more, but there is no more to tell.
Last edited by billybangleballs on Sat May 30, 2020 8:52 pm, edited 1 time in total.
Grumpy old man.
Ex-G0KAP - I'd rather be doing it than talking about it.
"When found, make a note of." - Captain Cuttle
kenkrsme
Sat May 30, 2020 7:56 pm
has happened on an upgraded install, and 2 seperate fresh installs after. noticed it usually windowed. it is currently overclocked as i have started to settle back in. but it happens overclocked or not.
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03111
Serial :
Model : Raspberry Pi 4 Model B Rev 1.1
Geeviz
Sat May 30, 2020 8:36 pm
I have it since a few monthts with this:
https://blog.vpetkov.net/2019/07/12/net ... -chromium/
with e.g. netflix videos... rarely .. let's say... once a week..
I am in the house :lol:
