sav25
Authorised Reseller
Authorised Reseller
Re: Audio activation causes webcam to freeze
Fri Feb 19, 2021 5:51 pm
I've added the output of those commands below for you.
Re returns - no problem at all, just let us know via our ticket system and mention "forum conversation with Rich" and I'll make sure the team sort that out for you.
I'll test an 8GB board next, will be good to have a clear picture on how all boards are behaving here.
Re firmware, there's a post here that might help?
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
VL805 firmware in bootloader EEPROM
Checking for updates in /lib/firmware/raspberrypi/bootloader/default
Use raspi-config to select either the default-production release or latest update.
BOOTLOADER: up-to-date
CURRENT: Thu 03 Sep 2020 12:11:43 PM UTC (1599135103)
 LATEST: Thu 03 Sep 2020 12:11:43 PM UTC (1599135103)
RELEASE: default
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
and
pi@raspberrypi:~ $ lsusb -v
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0003 3.0 root hub
  bcdDevice            5.10
  iManufacturer           3
  iProduct                2
  iSerial                 1
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
        bMaxBurst               0
Bus 001 Device 005: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x093a Pixart Imaging, Inc.
  idProduct          0x2510 Optical Mouse
  bcdDevice            1.00
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      52
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Bus 001 Device 006: ID 04d9:0006 Holtek Semiconductor, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x04d9 Holtek Semiconductor, Inc.
  idProduct          0x0006
  bcdDevice            1.40
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x003b
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      65
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      59
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0005  1x 5 bytes
        bInterval              10
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           32.98
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Bus 001 Device 003: ID 09da:2691 A4Tech Co., Ltd.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.01
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x09da A4Tech Co., Ltd.
  idProduct          0x2691
  bcdDevice            1.00
  iManufacturer           2
  iProduct                1
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x02f7
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass         14 Video
      bFunctionSubClass       3 Video Interface Collection
      bFunctionProtocol       0
      iFunction               5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass        14 Video
      bInterfaceSubClass      1 Video Control
      iInterface              5
      VideoControl Interface Descriptor:
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdUVC               1.00
        wTotalLength       0x006c
        dwClockFrequency       15.000000MHz
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             5
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               4
        iTerminal               0
        bLength                28
        bDescriptorType        36
        bDescriptorSubtype      6 (EXTENSION_UNIT)
        bUnitID                 3
        guidExtensionCode         {28f03370-6311-4a2e-ba2c-6890eb334016}
        bNumControl            24
        bNrPins                 1
        baSourceID( 0)          2
        bControlSize            3
        bmControls( 0)       0xff
        bmControls( 1)       0xff
        bmControls( 2)       0xff
        iExtension              0
        bLength                29
        bDescriptorType        36
        bUnitID                 4
        guidExtensionCode         {bd5321b4-d635-ca45-b203-4e0149b301bc}
        bNumControl            32
        bNrPins                 1
        baSourceID( 0)          3
        bControlSize            4
        bmControls( 0)       0x03
        bmControls( 1)       0x80
        bmControls( 2)       0x3f
        bmControls( 3)       0x9f
        iExtension              0
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Camera Sensor
        bAssocTerminal          0
        iTerminal               0
        wObjectiveFocalLengthMin      0
        wObjectiveFocalLengthMax      0
        wOcularFocalLength            0
        bControlSize                  3
        bmControls           0x0002002e
          Auto-Exposure Mode
          Auto-Exposure Priority
          Exposure Time (Absolute)
          Focus (Absolute)
          Focus, Auto
        bLength                11
        bDescriptorType        36
        bDescriptorSubtype      5 (PROCESSING_UNIT)
      Warning: Descriptor too short
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier          0
        bControlSize            2
        bmControls     0x0000177f
          Brightness
          Contrast
          Hue
          Saturation
          Sharpness
          Gamma
          White Balance Temperature
          Backlight Compensation
          Gain
          Power Line Frequency
          White Balance Temperature, Auto
        iProcessing             0
        bmVideoStandards     0x21
          None
          PAL - 525/60
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               6
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceSubClass      2 Video Streaming
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               1
        INTERFACE CLASS:  0f 24 01 02 df 01 82 00 05 00 00 00 01 00 00
        INTERFACE CLASS:  0b 24 06 01 07 00 01 00 00 00 00
        INTERFACE CLASS:  1e 24 07 01 00 80 07 38 04 00 80 53 3b 00 80 53 3b 4d                                    4a 3f 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 02 00 00 05 d0 02 00 00 5e 1a 00 00 5e 1a 4d                                    22 1c 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 03 00 00 04 00 03 00 00 80 16 00 00 80 16 4d                                    02 18 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 04 00 20 03 58 02 00 a0 bb 0d 00 a0 bb 0d 4d                                    a8 0e 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 05 00 80 02 e0 01 00 00 ca 08 00 00 ca 08 4d                                    62 09 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 06 00 60 01 20 01 00 80 e6 02 00 80 e6 02 4d                                    1a 03 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 07 07 00 40 01 f0 00 00 80 32 02 00 80 32 02 4d                                    5a 02 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1b 24 04 02 07 59 55 59 32 00 00 10 00 80 00 00 aa 00                                    38 9b 71 10 01 00 00 00 00
        INTERFACE CLASS:  1e 24 05 01 00 80 02 e0 01 00 00 ca 08 00 00 ca 08 00                                    60 09 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 05 02 00 80 07 38 04 00 40 e3 09 00 40 e3 09 00                                    48 3f 00 80 84 1e 00 01 80 84 1e 00
        INTERFACE CLASS:  1e 24 05 03 00 00 05 d0 02 00 00 ca 08 00 00 ca 08 00                                    20 1c 00 40 42 0f 00 01 40 42 0f 00
        INTERFACE CLASS:  1e 24 05 04 00 00 04 00 03 00 00 80 07 00 00 80 07 00                                    00 18 00 40 42 0f 00 01 40 42 0f 00
        INTERFACE CLASS:  1e 24 05 05 00 20 03 58 02 00 a0 bb 0d 00 a0 bb 0d 00                                    a6 0e 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 05 06 00 60 01 20 01 00 80 e6 02 00 80 e6 02 00                                    18 03 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  1e 24 05 07 00 40 01 f0 00 00 80 32 02 00 80 32 02 00                                    58 02 00 15 16 05 00 01 15 16 05 00
        INTERFACE CLASS:  06 24 0d 01 01 04
      bLength                 8
      bDescriptorType        11
      bFirstInterface         2
      bInterfaceCount         2
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      iInterface              4
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x002b
        bInCollection           1
        baInterfaceNr(0)        3
        bLength                12
        bDescriptorType        36
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             2
        wChannelConfig     0x0000
        iChannelNames           0
        iTerminal               0
        bLength                13
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 2
        bSourceID               1
        bControlSize            2
        bmaControls(0)     0x0001
          Mute Control
        bmaControls(1)     0x0002
          Volume Control
        bmaControls(2)     0x0002
          Volume Control
        iFeature                0
        bLength                 9
        bDescriptorType        36
        bTerminalID             3
        bAssocTerminal          0
        bSourceID               2
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              4
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           3
        bDelay                  1 frames
        wFormatTag         0x0001 PCM
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            3 Discrete
        tSamFreq[ 0]        16000
        tSamFreq[ 1]        44100
        tSamFreq[ 2]        48000
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x00c0  1x 192 bytes
        bInterval               4
        bRefresh                0
        bSynchAddress           0
        AudioStreaming Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x01
            Sampling Frequency
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x2109 VIA Labs, Inc.
  idProduct          0x3431 Hub
  bcdDevice            4.21
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            5.10
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
sav25
Authorised Reseller
Authorised Reseller
Fri Feb 19, 2021 5:52 pm
BCM2711 detected
RELEASE: default
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
and
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         3
  bMaxPacketSize0         9
  bcdDevice            5.10
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  bcdDevice            1.00
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idProduct          0x0006
  bcdDevice            1.40
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x003b
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice           32.98
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0029
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.01
  bDeviceSubClass         2
  bMaxPacketSize0        64
  idProduct          0x2691
  bcdDevice            1.00
  iManufacturer           2
  iProduct                1
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x02f7
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionProtocol       0
      iFunction               5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              5
        bLength                13
        bDescriptorType        36
        bcdUVC               1.00
        wTotalLength       0x006c
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                 9
        bDescriptorType        36
        bTerminalID             5
        bAssocTerminal          0
        bSourceID               4
        iTerminal               0
        bLength                28
        bDescriptorType        36
        bUnitID                 3
        bNumControl            24
        bNrPins                 1
        baSourceID( 0)          2
        bControlSize            3
        bmControls( 0)       0xff
        bmControls( 1)       0xff
        bmControls( 2)       0xff
        iExtension              0
        bLength                29
        bDescriptorType        36
        bUnitID                 4
        bNumControl            32
        bNrPins                 1
        baSourceID( 0)          3
        bControlSize            4
        bmControls( 0)       0x03
        bmControls( 1)       0x80
        bmControls( 2)       0x3f
        bmControls( 3)       0x9f
        iExtension              0
        bLength                18
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        iTerminal               0
        bControlSize                  3
          Auto-Exposure Mode
          Focus (Absolute)
          Focus, Auto
        bLength                11
        bDescriptorType        36
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier          0
        bControlSize            2
          Brightness
          Contrast
          Hue
          Saturation
          Sharpness
          Gamma
          Gain
        iProcessing             0
          None
          PAL - 525/60
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               6
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 8
      bDescriptorType        11
      bFirstInterface         2
      bInterfaceCount         2
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x002b
        bInCollection           1
        baInterfaceNr(0)        3
        bLength                12
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bNrChannels             2
        iChannelNames           0
        iTerminal               0
        bLength                13
        bDescriptorType        36
        bUnitID                 2
        bSourceID               1
        bControlSize            2
          Mute Control
          Volume Control
          Volume Control
        iFeature                0
        bLength                 9
        bDescriptorType        36
        bTerminalID             3
        bAssocTerminal          0
        bSourceID               2
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              4
        bLength                 7
        bDescriptorType        36
        bTerminalLink           3
        bDelay                  1 frames
        bLength                17
        bDescriptorType        36
        bNrChannels             2
        bSubframeSize           2
        bBitResolution         16
        tSamFreq[ 0]        16000
        tSamFreq[ 1]        44100
        tSamFreq[ 2]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
          wLockDelay         0x0000
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            4.21
  iManufacturer           0
  iProduct                1
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            5.10
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
sav25
Authorised Reseller
Authorised Reseller
Fri Feb 19, 2021 6:23 pm
2GB test complete. ~1 hour with no issues. 8GB board is now up and running.
Murple
Fri Feb 19, 2021 6:25 pm
I think we may have something here! (He says for the millionth time but hopefully I'm not wrong this time :) )
So I'm not able to check just yet but it looks like your webcam has a different device ID...
And if we look here https://www.spinics.net/lists/linux-med ... 83558.html
It seems that the module needs a quirk to get it working.
This may have been upstreamed so it happens automatically for your device, but not mine with a different ID.
Maybe, will check later tonight or over the weekend.
Adding
uvcvideo.quirks=0x80
to kernel options would be the way to test. Perhaps the 0x80 needs to be converted to decimal ie uvcvideo.quirks=128.
sav25
Authorised Reseller
Authorised Reseller
Fri Feb 19, 2021 7:01 pm
Adding
Out of interest, did your camera come in a plastic blister pack or a small cardboard box? I know the packaging changed in the time we've stocked them, but the same model should be inside.
FYI our 8GB is still running fine so I'm not seeing any obvious issues tonight (apart from avoiding the 1GB boards - updating the product to mention that now).
I'd be very interested in the results of your further tests re the device ID/version.
Murple
Fri Feb 19, 2021 7:50 pm
My camera came in a bubble wrap bag in a cardboard box.
My device ID is the same as Nick's, which is different from yours.
09da:2691 (yours)
09da:2695 (mine and Nick's)
Perhaps they are the same but with different IDs, or they may be different hardware inside.
I would wager if you found a recently returned one it would have the same ID as mine (if you run lsusb you can see the ID easily).
There may be other issues at play of course, but this seems like a big clue as to the problem.
Are you able to test out another camera? Perhaps the newer stock are all this different model number?
NicknDi
Fri Feb 19, 2021 9:07 pm
Just dropped back in to see if any progress and delighted to see this development. Feel somewhat out of my depth re the detail but certainly follow the gist. Great stuff! Would like to try the quirks addition over the weekend, but first need to get my head round where to add it! Too tired now. (It's an hour later over here in France!)
Cheers!
PS My camera too came in a bubble wrap bag in a small cardboard box.
Murple
Sat Feb 20, 2021 12:54 am
I've just flashed a fresh piOS image onto a new sd card, everything fully up to date, and the camera workings perfectly in zoom. Like amazingly well, running for 45 minutes now and still going strong.
So either there has been a very recent update that fixed this issue...
Or I am a massive idiot who shouldn't be allowed near computers in any capacity?
Edit:
So I think this boils down to crap SD cards and an incompatibility with my usb hdd. It seems there is a lot of hdd activity when using zoom and perhaps this has been the issue all along?
NicknDi
Sat Feb 20, 2021 9:58 am
Edit:
Wow - that's amazing! You must have finally gone to bed a happy bunny!
But as you'll know from my OP, I've been working from a freshly flashed sd card ( Sandisk 128GB, not brand new but little used) all along (as well as a custom install of Ununtu Mate 20.10 booting and running from an ssd). Will now try re-flashing latest piOS and see if I can replicate your success...
Incidentally, I'm wondering if the recent fairly rapid increase in the number of views of this thread is indicative of what you were surmising: that problems will crop up in greater numbers as people update. On the other hand, Rich's tests and your analysis - up until late last night! - seem to point to a bad batch of cameras. I wonder if Rich has info on the number of cameras included in that batch.
valentim
Sat Feb 20, 2021 10:33 am
"I've spent hours trying to get a functioning video chat setup on a RPi4B (Rev 1.4) using a usb webcam and analogue audio out."
Have you tried using HDMI sound output instead?
I am asking because I am experiencing a similar problem with a Creative Live! Cam Sync 1080p - which I have reported here, ascribing it to the Kernel update, but without actually being sure of the cause...
In my case, webcam + HDMI sound works fine, while choosing analog sound output makes the all system lag to a halt.
NicknDi
Sat Feb 20, 2021 2:46 pm
Thanks for this suggestion. I believe in the early stages I did have sound output set to HDMI, simply because that was the default and I hadn't altered it. But I've just tried again, and you're right: it has prevented the camera from freezing or cutting out (though it's quite a laggy stream). The trouble is, the monitors I'm using don't have speakers, in fact they're not HDMI but DVI-D and I use an HDMI > DVI-D cable .....
OMG! Could that be the problem all along? Until this moment I'd completely forgotten that they're not HDMI screens. Cripes! Please can someone tell me it couldn't be that! .... Come to think of it, I'm using identical screens with my current main linux desktop (running Manjaro Gnome) without any webcam (or other video) issues, apart from the A4Tech webcam that started this thread off.
NicknDi
Sat Feb 20, 2021 3:25 pm
I'm pretty well at my wits' end.
This morning I tried a fresh install of Buster on a different SD card, but nothing changed.
I tried adding the quirks parameter, which made no difference (but maybe I didn't execute it correctly - I followed the procedure given in the Microsoft Lifecam Studio/Cinema section here: https://wiki.archlinux.org/index.php/Webcam_setup , making the possibly false assumption that though for Arch it would probably work in other linux distros).
As mentioned above in response to @valentim it does help to switch back from analogue out to HDMI, in that the camera no longer freezes, but in my setup I need to use the analogue out...
I tried the Chrome Media Edition too, but saw little difference - with audio out to HDMI (the only way to prevent camera freezing or shutting down) the stream seemed just as laggy.
Just hoping Rich comes up with something, even if it's an RMA, when he's back on the case.
Murple
Sat Feb 20, 2021 4:02 pm
When it works I can attest it works well, so you should not see any lag. The difference is night and day, believe me.
Are either of you using a USB soundcard for output? Cos using either hdmi/on board stereo shouldn't make any difference..? Weird
I found the quirks improved things when running off the usb hard drive, so you are welcome to try to see if it helps. But I'm thinking they just alleviate the problem, not remove it
Edit /boot/cmdline.txt and add to the end of the line...
uvcvideo.quirks=1152
(This applies two quirks, 0x80 and 0x400)
You should see a kernel message from boot saying the quirks were applied.
With the quirks applied the camera ran well for about 10minutes, but the camera would cut out eventually. The whole usb stack falls over. But I'm beginning to think it's the usb hardrive that caused it, even though I had tested with all usb devices disconnected so I'm not sure what was going on there
Now I have it working on an SD card I will reintroduce things until it breaks again
NicknDi
Sat Feb 20, 2021 6:55 pm
Thanks for the quirks clarification. Sadly no noticeable change.
No, not using a soundcard. Just now in order to test the quirks addition I started up with the sound output set to HDMI so as to be sure to get a video stream, found it was still quite laggy, then changed the audio out setting from HDMI to analogue and immediately the camera shut down. As you say: "weird!"
I've had enough for now. Going to spend the evening watching a film on the living room av system that WORKS WELL!
Murple
Sun Feb 21, 2021 9:58 am
I tried to do a zoom call again yesterday from the fresh PiOS install on Sd card. No changes made either in software or peripherals plugged in. I hadn't even touched it.
Anyway as soon as I tried to turn the microphone on I was back to a lagging locked up system.
The sound is HDMI out btw, always has been.
Bored now.
NicknDi
Sun Feb 21, 2021 10:36 am
Bored now.
Oh how frustrating! What the HELL is causing this? It must surely be something either in the hardware of firmware, that's behaving inconsistently when nothing else has changed - equivalent, in an analogue system, to a faulty connection?
sav25
Authorised Reseller
Authorised Reseller
Mon Feb 22, 2021 10:47 am
Just checking in to see if any progress was made over the weekend. Seems we're still not quite there yet.
I think the next best test would be for me to try one of the cameras from our recent batches (and make sure it has the same ID as both of your cameras) to see if that changes anything. If it still works, we'll know it's not the camera ID/version causing this.,
I was previously considering your slightly non-standard setups as the issue (using Ubuntu, USB drives etc) but it sounds like you've tested a more vanilla setup on RPi OS since then. Did we get to the bottom of the board firmware changes you'd made?
I'll test the new camera tomorrow as I'm working from home today (we're trying to limit bodies in the office as much as possible).
NicknDi
Mon Feb 22, 2021 12:52 pm
Hi Rich, good to have you back on the case!
Yes, makes sense to test a camera with the same ID as ours. Will await results of that tomorrow.
As far as the firmware goes, I've been reluctant to make changes as my wife relies on the Pi4 for her desktop, and apart from the webcam problem, it's running the loboris Ubuntu mate image superbly, booting and running from a USB SSD.. It was when we ran into the camera probs that I then flashed a standard Raspbian image to an SD card for the purposes of troubleshooting. So in effect, every time I try a new tweak, I test it on both systems. And one of the interesting things is that I get much the same behaviour from both.
The current firmware and bootloader are as follows@
BCM2711 detected
CURRENT: Sat 16 Jan 14:10:13 UTC 2021 (1610806213)
 LATEST: Thu  3 Sep 12:11:43 UTC 2020 (1599135103)
RELEASE: default
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000138a1
pi@raspberrypi:~ $ vcgencmd bootloader_version
Jan 16 2021 14:10:13
version d1be7b5ba3adb192b6192ea2561584aa5c7be6bd (release)
timestamp 1610806213
update-time 1611834982
capabilities 0x0000001f
Do you see any anomalies there?
Murple
Mon Feb 22, 2021 3:05 pm
You are on the STABLE/LATEST branch of firmware. The reason the latest version appears older than the installed one is because your pi is configured to use the CRITICAL/DEFAULT (production) firmware. It won't downgrade automatically, so it just sticks with the newer version.
You can edit change this setting by
sudo nano /etc/default/rpi-eeprom-update
or using raspi-config.
I am on the same firmware as you. It appears there is updated BETA and STABLE firmware landing soon, but it doesn't look like anything relavent to us has been changed (https://github.com/raspberrypi/rpi-eepr ... e-notes.md)
Downgrading the firmware to DEFAULT (September 3rd 2020) is definately worth a test. This may or may not also downgrade the firmware for the USB controller for you (8gb pi model), as it depends on what version of the VL805 firmware is bundled with the rest of the firmware. I will downgrade the firmware on mine, test it, and then look and downgrading the VL805 firmware too if that hasn't helped.
PS You need to manually downgrade the firmware, it won't do it sutomatically if the installed version is newer that the one you want to flash. I haven't looked to see how to do this yet but I suspect you just point rpi-eeprom-update to the correct firmware file(s). These are located in /lib/firmware/raspberrypi/bootloader/ where there is a folder for each branch. the 'default' and 'latest' folders are just symlinks to the 'critical' and 'stable' folders respectively (ie they are the same thing)
Murple
Mon Feb 22, 2021 7:39 pm
So from the looks of it, rolling back to default is simple.
sudo raspi-config
Option 6 Advanced Options
A7 Bootloader options
Select default
Haven't tested the camera yet
Edit: it made no difference, but at least it's comparing an identical system to the pihut setup.
Edit 2: downgraded the vl805 firmware if it's possible it actually made things worse.
Updated the firmware all the way up to the current beta release. same issue persists, camera appears to work ok until the microphone kicks in. Although at this stage I don't know if that's even relevent.
I wonder if the issue with selecting HDMI causes a side effect that gets pulseaudio to activate the microphone. The microphone is put in a suspend mode when it's first registered, and changing any pulseaudio setting may trigger it becoming active? Dunno, clutching at straws here. I would say we should try ALSA but I *really* cannot be bothered with that.
valentim
Tue Feb 23, 2021 9:43 am
"I wonder if the issue with selecting HDMI causes a side effect that gets pulseaudio to activate the microphone."
A testing procedure you might want to try is to use guvcview with "portaudio" instead of pulseaudio as input sound system.
Mind you, on the video side, full HD webcam resolution (1920x1080) is too much for the Pi; need to reduce to half HD or 800x600 for the stream to be smooth.
I do suspect something to do with pulseaudio (based on high loads of the process when the camera hangs) but can't really grasp the details.
NicknDi
Tue Feb 23, 2021 12:19 pm
sudo raspi-config
Select default
I went a slightly different route and used the eeprom boot recovery files from 16-04-20 (https://github.com/raspberrypi/rpi-eeprom/releases), but same result: no improvement.
Just far too much time getting eaten up on this!
fivenote
Tue Feb 23, 2021 1:16 pm
The lag problem with zoom is also reported here...
viewtopic.php?f=63&t=297921
I experience this with chromium and a number of different USB webcams. When the webcam and audio (analog out) are activated, mouse/keyboard/screen freeze on and off. This happens for me on all OS's I've tried... Raspberry Pi OS 32-bit and 64-bit, and Ubuntu 20.10.
It started after the 2021-01-07 kernel upgrade.
Murple
Tue Feb 23, 2021 3:06 pm
Thanks this is really helpful. I think we may find this is an interaction of a couple of things.
Anyway I will try rolling back chromium and the kernel to see if we can find a working setup.
Two problems however, Nick was using 5.4 kernel I seem to remember (but that doesn't been a regression wasn't introduced to both kernel branches).
And Richard from PiHut has got it working with at least one type of webcam, which suggests it isn't as simple a problem as we might think.
sav25
Authorised Reseller
Authorised Reseller
Tue Feb 23, 2021 3:59 pm
Hi all
I grabbed a new unit from stock today and have undertaken some testing. It has the same device ID as both of your models (the cameras which came in the smaller cardboard box).
When I first tried it (exact same basic test on Zoom) the microphone didn't work (in a USB 3.0 port). I then tried it in USB 2.0 and still no joy. Then Zoom showed a little red "!!" on the mic section and suggested I allow access.
So I clicked the Chrome settings and checked that access was permitted. Everything was already in place, so I decided to reboot as I wanted to go back to USB 3.0 for further tests.
After the reboot the mic seems to work fine...but I've since rebooted again and the mic simply won't work (no falling over of Chrome, just no mic).
So I think this shows that 'something' has changed since the packaging change, and it's clearly not working as easily as it used to.
For now I'm removing all of our remaining units from stock and will get in touch with our supplier to see if there's something that can be done (or whether we can get a batch of the previous device ID instead).
Sorry for the inconvenience caused through all of this. Whilst it's sometimes fun to troubleshoot, it's not fun when we don't land at a win at the end of it :( If you would like to return your camera for a refund, please send a message to https://support.thepihut.com/hc/en-us and we'll help with that ASAP.
Here's the lsusb -v output FYI:
Bus 001 Device 007: ID 09da:2695 A4Tech Co., Ltd.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         2
  bMaxPacketSize0        64
  idProduct          0x2695
  bcdDevice            1.00
  iManufacturer           2
  iProduct                1
  iSerial                 3
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x03ad
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionProtocol       0
      iFunction               5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              5
        bLength                13
        bDescriptorType        36
        bcdUVC               1.00
        wTotalLength       0x004f
        bInCollection           1
        baInterfaceNr( 0)       1
        bLength                 9
        bDescriptorType        36
        bTerminalID             4
        bAssocTerminal          0
        bSourceID               3
        iTerminal               0
        bLength                28
        bDescriptorType        36
        bUnitID                 3
        bNumControl            24
        bNrPins                 1
        baSourceID( 0)          2
        bControlSize            3
        bmControls( 0)       0x9f
        bmControls( 1)       0x00
        bmControls( 2)       0x07
        iExtension              0
        bLength                18
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        iTerminal               0
        bControlSize                  3
        bmControls           0x0000000e
          Auto-Exposure Mode
        bLength                11
        bDescriptorType        36
        bUnitID                 2
        bSourceID               1
        wMaxMultiplier          0
        bControlSize            2
          Brightness
          Contrast
          Hue
          Saturation
          Sharpness
          Gamma
          Gain
        iProcessing             0
        bmVideoStandards     0x00
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               6
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      VideoStreaming Interface Descriptor:
        bLength                            15
        bDescriptorType                    36
        bDescriptorSubtype                  1 (INPUT_HEADER)
        bNumFormats                         2
        wTotalLength                   0x024f
        bEndPointAddress                  129
        bmInfo                              0
        bTerminalLink                       4
        bStillCaptureMethod                 0
        bTriggerSupport                     0
        bTriggerUsage                       0
        bControlSize                        1
        bmaControls( 0)                     0
        bmaControls( 1)                     0
        bLength                            11
        bDescriptorType                    36
        bDescriptorSubtype                  6 (FORMAT_MJPEG)
        bFormatIndex                        1
        bNumFrameDescriptors                7
        bFlags                              0
          Fixed-size samples: No
        bDefaultFrameIndex                  1
        bAspectRatioX                       0
        bAspectRatioY                       0
        bmInterlaceFlags                 0x00
          Interlaced stream or variable: No
          Fields per frame: 1 fields
          Field 1 first: No
          Field pattern: Field 1 only
        bCopyProtect                        0
        bLength                            30
        bDescriptorType                    36
        bDescriptorSubtype                  7 (FRAME_MJPEG)
        bFrameIndex                         1
        bmCapabilities                   0x00
          Still image unsupported
        wWidth                           1920
        wHeight                          1080
        dwMinBitRate                995328000
        dwMaxBitRate                995328000
        dwMaxVideoFrameBufferSize     4147789
        dwDefaultFrameInterval         333333
        bFrameIntervalType                  1
        dwFrameInterval( 0)            333333
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x00
        wWidth                           1280
        wHeight                           800
        dwMinBitRate                491520000
        dwMaxBitRate                491520000
        dwMaxVideoFrameBufferSize     2048589
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         3
        bmCapabilities                   0x00
        wWidth                           1280
        wHeight                           720
        dwMinBitRate                 73728000
        dwMaxBitRate                442368000
        dwMaxVideoFrameBufferSize     1843789
        bFrameIntervalType                  5
        dwFrameInterval( 1)            500000
        dwFrameInterval( 2)            666666
        dwFrameInterval( 3)           1000000
        dwFrameInterval( 4)           2000000
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         4
        bmCapabilities                   0x00
        wWidth                            800
        wHeight                           600
        dwMinBitRate                 38400000
        dwMaxBitRate                230400000
        dwMaxVideoFrameBufferSize      960589
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         5
        bmCapabilities                   0x00
        wWidth                            640
        wHeight                           480
        dwMinBitRate                 24576000
        dwMaxBitRate                147456000
        dwMaxVideoFrameBufferSize      614989
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         6
        bmCapabilities                   0x00
        wWidth                            320
        wHeight                           240
        dwMinBitRate                  6144000
        dwMaxBitRate                 36864000
        dwMaxVideoFrameBufferSize      154189
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         7
        bmCapabilities                   0x00
        wWidth                           1920
        wHeight                          1080
        bLength                            27
        bDescriptorType                    36
        bDescriptorSubtype                  4 (FORMAT_UNCOMPRESSED)
        bFormatIndex                        2
        guidFormat                            {32595559-0000-0010-8000-00aa00389b71}
        bBitsPerPixel                      16
        bAspectRatioX                       0
        bAspectRatioY                       0
          Fields per frame: 2 fields
          Field 1 first: No
        bCopyProtect                        0
        bLength                            30
        bDescriptorType                    36
        bDescriptorSubtype                  5 (FRAME_UNCOMPRESSED)
        bFrameIndex                         1
        bmCapabilities                   0x00
        wWidth                           1920
        wHeight                          1080
        dwMinBitRate                165888000
        dwMaxBitRate                165888000
        dwMaxVideoFrameBufferSize     4147200
        dwDefaultFrameInterval        2000000
        dwFrameInterval( 0)           2000000
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                         2
        bmCapabilities                   0x00
        wWidth                           1280
        wHeight                           800
        dwMinBitRate                 81920000
        dwMaxBitRate                163840000
        dwMaxVideoFrameBufferSize     2048000
        dwDefaultFrameInterval        1000000
        bFrameIntervalType                  2
        dwFrameInterval( 0)           1000000
        dwFrameInterval( 1)           2000000
        bLength                            34
        bDescriptorType                    36
        bFrameIndex                         3
        bmCapabilities                   0x00
        wWidth                           1280
        wHeight                           720
        dwMaxVideoFrameBufferSize     1843200
        bLength                            38
        bDescriptorType                    36
        bFrameIndex                         4
        bmCapabilities                   0x00
        wWidth                            800
        wHeight                           600
        dwMaxBitRate                115200000
        dwMaxVideoFrameBufferSize      960000
        dwDefaultFrameInterval         666666
        bFrameIntervalType                  3
        dwFrameInterval( 0)            666666
        dwFrameInterval( 1)           1000000
        dwFrameInterval( 2)           2000000
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         5
        bmCapabilities                   0x00
        wWidth                            640
        wHeight                           480
        dwMaxVideoFrameBufferSize      614400
        bLength                            46
        bDescriptorType                    36
        bFrameIndex                         6
        bmCapabilities                   0x00
        wWidth                            320
        wHeight                           240
        dwMaxVideoFrameBufferSize      153600
        bLength                            30
        bDescriptorType                    36
        bFrameIndex                         7
        bmCapabilities                   0x00
        wWidth                           1920
        wHeight                          1080
        bLength                             6
        bDescriptorType                    36
        bDescriptorSubtype                 13 (COLORFORMAT)
        bColorPrimaries                     1 (BT.709,sRGB)
        bTransferCharacteristics            1 (BT.709)
        bMatrixCoefficients                 4 (SMPTE 170M (BT.601))
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0080  1x 128 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0100  1x 256 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0320  1x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x0b20  2x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1320  3x 800 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x1400  3x 1024 bytes
        bInterval               1
      bLength                 8
      bDescriptorType        11
      bFirstInterface         2
      bInterfaceCount         2
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0029
        bInCollection           1
        baInterfaceNr(0)        3
        bLength                12
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bNrChannels             1
        iChannelNames           0
        iTerminal               0
        bLength                11
        bDescriptorType        36
        bUnitID                 2
        bSourceID               1
        bControlSize            2
          Mute Control
          Volume Control
        iFeature                0
        bLength                 9
        bDescriptorType        36
        bTerminalID             3
        bAssocTerminal          0
        bSourceID               2
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              4
        bLength                 7
        bDescriptorType        36
        bTerminalLink           3
        bDelay                  1 frames
        bLength                29
        bDescriptorType        36
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            7 Discrete
        tSamFreq[ 0]         8000
        tSamFreq[ 1]        11025
        tSamFreq[ 2]        16000
        tSamFreq[ 3]        22050
        tSamFreq[ 4]        24000
        tSamFreq[ 5]        44100
        tSamFreq[ 6]        48000
        bLength                 9
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               4
        bRefresh                0
        bSynchAddress           0
          bLength                 7
          bDescriptorType        37
          bmAttributes         0x01
            Sampling Frequency
          wLockDelay         0x0000
