paulfxh
/proc/cpuinfo reporting low BogoMIPS
Thu Jan 24, 2013 2:22 pm
I run Conky in all of the OSes (Raspbian, Gentoo, Arch) I use on my RPi to display a range of parameters including CPU frequency.
This latter I read from /proc/cpuinfo.
Since, the firmware rpi-update of 9/01/2013 and all subsequent updates, the number reported by BoGoMIPS (from /proc/cpuinfo) has reduced to exactly two-thirds of the true value.
In searching through this forum, I can find only a few oblique references (here and here) to this phenomenon but no suggestion of a solution.
In both links referenced above, the CPU frequency shown by BogoMIPS is again exactly two thirds of the true value.
In my case, the under-reporting is easily overcome by multiplying the BogoMIPS value by 1.5 in my Conky script.
However, I'm puzzled that this has not caused more concern in the RPi community.
Have I missed something?
RaTTuS
Re: /proc/cpuinfo reporting low BogoMIPS
Thu Jan 24, 2013 2:44 pm
if you have underclocked your RPi then the bogomigs will be wrong ,
see /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
Covfefe
paulfxh
Thu Jan 24, 2013 2:49 pm
Sorry, I forgot to mention that, in all OSes, I have OVERclocked the processor to 850 MHz.
BogoMIPS always indicated 845 MHz before 9/01/2013 but 564 MHz thereafter.
efflandt
Thu Jan 24, 2013 7:25 pm
How do you know that it was being properly calculated before? I have been using Linux for many years and I do not recall seeing bogomips directly match the same number as the frequency. I seem to remember my old 33DX386 (33 MHz) being about 26 bogomips. I don't have any arm computers to compare, but a quick look at regular PC's including the old Celeron below and newer PC's seem to show bogomips about double the frequency:
efflandt@realhost:~> cat /proc/cpuinfo
processor	: 0
vendor_id	: GenuineIntel
cpu family	: 6
model		: 6
model name	: Celeron (Mendocino)
stepping	: 0
cpu MHz		: 333.060
cache size	: 128 KB
fdiv_bug	: no
hlt_bug		: no
f00f_bug	: no
coma_bug	: no
fpu		: yes
fpu_exception	: yes
cpuid level	: 2
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 sep mtrr pge mca cmov pat pse36 mmx fxsr
bogomips	: 665.19
paulfxh
Thu Jan 24, 2013 8:10 pm
efflandt wrote:How do you know that it was being properly calculated before?
Thanks for your reply.
How do I know?
Well, I've been overclocking the cpu on my RPi, on several OSes, for the last six months and keep a close eye on the BogoMIPS displayed in /proc/cpuinfo (it's up in front of me all the time in Conky)
For all that time up till about two weeks ago, the BogoMIPS value displayed was invariably about 99.5% of the cpu_freq value I had input to /boot/config.txt
So as far as a mere human being can be certain of anything, I'm pretty sure what was being calculated before was not far off the mark.
efflandt wrote: quick look at regular PC's including the old Celeron below and newer PC's seem to show bogomips about double the frequency:
This is probably because the computers you've looked at have dual core processors which means twice the number of calculations per minute as a single core (which is what the RPi has) operating at the same speed.
ascent
Wed Jul 03, 2013 9:34 am
I'm actually experiencing the same with an unoverclocked Pi, but the strange thing is that with two different Pi's, the values differ:
Pi #1
[root@raspi /]# grep -i bogomips /proc/cpuinfo
BogoMIPS        : 464.48
Pi #2
BogoMIPS        : 697.95
Both Pi's run Pidora 18 but the slower one has a lower firmware (fromJun 6 2013 18:33:28) where the faster one has a newer one (Jun 29 2013 15:05:17). After running rpi-update on the "slower" Pi, they now both have the same bogomips value. Perhaps this is useful for anyone.
Wouter
