Can't connect an arducam usb camera module to my raspberry pi model 4B
Camera : https://www.pricepulse.app/arducam-8mp- ... us_4698992
the camera is working with laptops fine, and on the raspberry pi other camera connected with usb is working.
Any idea?
raspberry pi B with arducam usb camera not working
Re: raspberry pi B with arducam usb camera not working
Have you checked the kernel logs for any errors? (Use "dmesg")
Does it create /dev/video0 (and /dev/video1) and then not stream, or do those devices not exist?
The dmesg messages are as shown on the image. In the devices there are some video devices shown (starting with 10 to 16), but the list does not change after I plug the camera in.
When I tried another camera (it's a Microsoft webcam), it connected successfully, and I was able to take pictures with
/dev/video10-16 are all memory to memory devices, either video codecs or image resizing. They are normal.
Not getting /dev/video0 when connecting the Arducam camera is abnormal, particularly if other webcams do work.
I would have expected something to be logged on connect/disconnect, even if something else happens to not load the uvcvideo driver.
Does "lsusb" report the device when connected? If so then the snippet from "lsusb -vv" for the webcam may help understand what's going on.
The lsusb command outputs this, doesn't matter to which USB port I plug the camera in. However, the indicator LED on the camera is lit up, so it must get power.6by9 wrote: ↑Mon Jun 21, 2021 11:29 am/dev/video10-16 are all memory to memory devices, either video codecs or image resizing. They are normal.
I checked the connections, also tried with another cable, but still nothing.
Is your Pi sensibly powered? Undervoltage may account for weird behaviour of USB peripherals. Or connect it via a powered USB hub.
Otherwise there's not much more to advise. It's probably worth asking on the Arducam forums - https://www.arducam.com/forum/
https://www.arducam.com/forums/topic/ge ... 0-cameras/ isn't far off your situation, and sounds like a power issue.
I am using the offical raspberry power supply which outputs the required 5V/3A, so that shouldn't be the problem. But I tried it out with a stronger power supply which one outputs 5V/5A and still it did not recognised the camera. But I will ask this issue in the Arducam forum as well, thank you for your help!6by9 wrote: ↑Mon Jun 21, 2021 2:40 pmIs your Pi sensibly powered? Undervoltage may account for weird behaviour of USB peripherals. Or connect it via a powered USB hub.
