not sure if you still need input - just in case: I run an external 7.1 soundbox directly connected to the Pi (no hub, no other USB devices) and have stuttering audio recording (playback is fine). Here is the data:
uname -a
Linux pi 3.6.11+ #512 PREEMPT Sat Jul 27 19:08:54 BST 2013 armv6l GNU/Linux
sudo lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x9514
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 41
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 1 Single TT
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 5
wHubCharacteristic 0x000d
Per-port power switching
Compound device
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 1 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0103 power enable connect
Port 3: 0000.0100 power
Port 4: 0000.0100 power
Port 5: 0000.0100 power
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.06
iManufacturer 3 Linux 3.6.11+ dwc_otg_hcd
iProduct 2 DWC OTG Controller
iSerial 1 bcm2708_usb
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0008
Ganged power switching
bPwrOn2PwrGood 1 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idProduct 0xec00
bcdDevice 2.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 39
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
bInterfaceProtocol 255
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 4
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
Self Powered
Bus 001 Device 004: ID 0d8c:0102 C-Media Electronics, Inc. CM106 Like Sound Device
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0d8c C-Media Electronics, Inc.
idProduct 0x0102 CM106 Like Sound Device
bcdDevice 0.10
iManufacturer 0
iProduct 2 USB Sound Device
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 534
bNumInterfaces 4
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
iInterface 0
AudioControl Interface Descriptor:
bLength 10
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 1.00
wTotalLength 200
bInCollection 2
baInterfaceNr( 0) 1
baInterfaceNr( 1) 2
bLength 12
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bNrChannels 8
wChannelConfig 0x063f
Left Front (L)
Right Front (R)
Center Front (C)
Low Freqency Enhancement (LFE)
Left Surround (LS)
Right Surround (RS)
Side Left (SL)
Side Right (SR)
iChannelNames 0
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 4
wTerminalType 0x0201 Microphone
bAssocTerminal 0
bNrChannels 2
wChannelConfig 0x0003
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 10
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 8
bSourceID 4
bControlSize 1
bmaControls( 0) 0x01
Mute Control
bmaControls( 1) 0x02
Volume Control
bmaControls( 2) 0x02
Volume Control
iFeature 0
bLength 10
bDescriptorType 36
bUnitID 9
bSourceID 4
bControlSize 1
Mute Control
Volume Control
Volume Control
iFeature 0
bLength 25
bDescriptorType 36
bDescriptorSubtype 4 (MIXER_UNIT)
bUnitID 12
bNrInPins 3
baSourceID( 0) 1
baSourceID( 1) 9
baSourceID( 2) 11
bNrChannels 8
Left Front (L)
Right Front (R)
Center Front (C)
Left Surround (LS)
Right Surround (RS)
Side Left (SL)
Side Right (SR)
iChannelNames 0
bmControls 0x00
bmControls 0x00
bmControls 0x00
iMixer 0
junk at descriptor end: 00 00 00 00 00 00 00 00 00
bLength 16
bDescriptorType 36
bUnitID 13
bSourceID 12
bControlSize 1
Mute Control
Volume Control
Volume Control
bmaControls( 3) 0x02
Volume Control
bmaControls( 4) 0x02
Volume Control
bmaControls( 5) 0x02
Volume Control
bmaControls( 6) 0x02
Volume Control
bmaControls( 7) 0x02
Volume Control
bmaControls( 8) 0x02
Volume Control
iFeature 0
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 13
iTerminal 0
bLength 13
bDescriptorType 36
bUnitID 17
bNrInPins 2
baSourceID( 0) 9
baSourceID( 1) 11
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
bmControls 0x00
iMixer 0
bLength 9
bDescriptorType 36
bTerminalID 10
bAssocTerminal 0
bSourceID 7
iTerminal 0
bLength 10
bDescriptorType 36
bDescriptorSubtype 5 (SELECTOR_UNIT)
bUnitID 7
bNrInPins 4
baSource( 0) 8
baSource( 1) 15
baSource( 2) 16
baSource( 3) 2
iSelector 0
bLength 12
bDescriptorType 36
bTerminalID 6
wTerminalType 0x0603 Line Connector
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 10
bDescriptorType 36
bUnitID 15
bSourceID 6
bControlSize 1
Mute Control
Volume Control
Volume Control
iFeature 0
bLength 10
bDescriptorType 36
bUnitID 11
bSourceID 6
bControlSize 1
Mute Control
Volume Control
Volume Control
iFeature 0
bLength 12
bDescriptorType 36
bTerminalID 5
wTerminalType 0x0605 SPDIF interface
bAssocTerminal 0
bNrChannels 2
Left Front (L)
Right Front (R)
iChannelNames 0
iTerminal 0
bLength 10
bDescriptorType 36
bUnitID 2
bSourceID 17
bControlSize 1
Mute Control
Volume Control
Volume Control
iFeature 0
bLength 10
bDescriptorType 36
bUnitID 16
bSourceID 5
bControlSize 1
Mute Control
bmaControls( 1) 0x00
bmaControls( 2) 0x00
iFeature 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
AudioStreaming Interface Descriptor:
bLength 7
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bNrChannels 8
bSubframeSize 2
bBitResolution 16
bSamFreqType 2 Discrete
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 9
Transfer Type Isochronous
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0310 1x 784 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
AudioControl Endpoint Descriptor:
bLength 7
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x01
Sampling Frequency
bLockDelayUnits 0 Undefined
wLockDelay 0 Undefined
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x00c4 1x 196 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 4
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0188 1x 392 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 6
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
wMaxPacketSize 0x0248 1x 584 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 1
bDelay 1 frames
wFormatTag 1 PCM
bLength 11
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
bSamFreqType 1 Discrete
tSamFreq[ 0] 48000
bLength 9
bDescriptorType 5
bmAttributes 9
Synch Type Adaptive
Usage Type Data
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 36
bTerminalLink 10
bDelay 1 frames
wFormatTag 1 PCM
bLength 14
bDescriptorType 36
bNrChannels 2
bSubframeSize 2
bBitResolution 16
tSamFreq[ 0] 44100
tSamFreq[ 1] 48000
bLength 9
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 5
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bRefresh 0
bSynchAddress 0
bLength 7
bDescriptorType 37
bmAttributes 0x01
Sampling Frequency
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 50
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0003 1x 3 bytes
bInterval 1
Device Status: 0x0000
(Bus Powered)
dmesg
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #512 PREEMPT Sat Jul 27 19:08:54 BST 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 17000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c053d894, node_mem_map c05e7000
[ 0.000000] Normal zone: 768 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 97536 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=1200 bcm2708.boardrev=0xe bcm2708.serial=0xbf78f372 smsc95xx.macaddr=B8:27:EB:78:F3:72 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 dwc_otg.fiq_split_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB = 384MB total
[ 0.000000] Memory: 367232k/367232k available, 25984k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04e74d8 (4990 kB)
[ 0.000000] .init : 0xc04e8000 - 0xc0508f44 ( 132 kB)
[ 0.000000] .data : 0xc050a000 - 0xc053e0c0 ( 209 kB)
[ 0.000000] .bss : 0xc053e0e4 - 0xc05e6d18 ( 676 kB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001015] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060125] pid_max: default: 32768 minimum: 301
[ 0.060455] Mount-cache hash table entries: 512
[ 0.061217] Initializing cgroup subsys cpuacct
[ 0.061274] Initializing cgroup subsys devices
[ 0.061307] Initializing cgroup subsys freezer
[ 0.061336] Initializing cgroup subsys blkio
[ 0.061425] CPU: Testing write buffer coherency: ok
[ 0.061758] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.061899] Setting up static identity map for 0x39e658 - 0x39e6b4
[ 0.063397] devtmpfs: initialized
[ 0.074141] NET: Registered protocol family 16
[ 0.080630] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081754] bcm2708.uart_clock = 0
[ 0.083144] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083199] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083234] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083330] bcm2708_vcio: mailbox at f200b880
[ 0.083430] bcm_power: Broadcom power driver
[ 0.083468] bcm_power_open() -> 0
[ 0.083493] bcm_power_request(0, 8)
[ 0.584179] bcm_mailbox_read -> 00000080, 0
[ 0.584219] bcm_power_request -> 0
[ 0.584246] Serial: AMBA PL011 UART driver
[ 0.584388] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.910651] console [ttyAMA0] enabled
[ 0.934484] bio: create slab <bio-0> at 0
[ 0.939374] SCSI subsystem initialized
[ 0.943460] usbcore: registered new interface driver usbfs
[ 0.949040] usbcore: registered new interface driver hub
[ 0.954636] usbcore: registered new device driver usb
[ 0.961000] Switching to clocksource stc
[ 0.965236] FS-Cache: Loaded
[ 0.968368] CacheFiles: Loaded
[ 0.983251] NET: Registered protocol family 2
[ 0.988530] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.996270] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.003059] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.009664] TCP: reno registered
[ 1.012916] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.018815] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.025390] NET: Registered protocol family 1
[ 1.030254] RPC: Registered named UNIX socket transport module.
[ 1.036296] RPC: Registered udp transport module.
[ 1.041017] RPC: Registered tcp transport module.
[ 1.045762] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.052900] bcm2708_dma: DMA manager at f2007000
[ 1.057686] bcm2708_gpio: bcm2708_gpio_probe c0517d98
[ 1.063146] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.072287] audit: initializing netlink socket (disabled)
[ 1.077881] type=2000 audit(0.930:1): initialized
[ 1.200192] VFS: Disk quotas dquot_6.5.2
[ 1.204228] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.211288] FS-Cache: Netfs 'nfs' registered for caching
[ 1.217038] NFS: Registering the id_resolver key type
[ 1.222237] Key type id_resolver registered
[ 1.226532] Key type id_legacy registered
[ 1.230894] msgmni has been set to 749
[ 1.236428] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.244134] io scheduler noop registered
[ 1.248180] io scheduler deadline registered (default)
[ 1.253362] io scheduler cfq registered
[ 1.284026] Console: switching to colour frame buffer device 200x75
[ 1.305834] kgdb: Registered I/O driver kgdboc.
[ 1.311105] vc-cma: Videocore CMA driver
[ 1.315187] vc-cma: vc_cma_base = 0x00000000
[ 1.319982] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.325505] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.340283] brd: module loaded
[ 1.348544] loop: module loaded
[ 1.352150] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.359992] Loading iSCSI transport class v2.0-870.
[ 1.366043] usbcore: registered new interface driver smsc95xx
[ 1.372159] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.583373] Core Release: 2.80a
[ 1.586689] Setting default values for core params
[ 1.591609] Finished setting default values for core params
[ 1.802389] Using Buffer DMA mode
[ 1.805822] Periodic Transfer Interrupt Enhancement - disabled
[ 1.811759] Multiprocessor Interrupt Enhancement - disabled
[ 1.817458] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.821901] Dedicated Tx FIFOs mode
[ 1.826510] dwc_otg: Microframe scheduler enabled
[ 1.826938] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.831989] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.839484] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.845169] Init: Port Power? op_state=1
[ 1.849170] Init: Power Port (0)
[ 1.852558] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.859588] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.866981] usb usb1: Product: DWC OTG Controller
[ 1.871777] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.877653] usb usb1: SerialNumber: bcm2708_usb
[ 1.883073] hub 1-0:1.0: USB hub found
[ 1.887010] hub 1-0:1.0: 1 port detected
[ 1.891367] dwc_otg: FIQ enabled
[ 1.891382] dwc_otg: NAK holdoff enabled
[ 1.891391] dwc_otg: FIQ split fix disabled
[ 1.891411] Module dwc_common_port init
[ 1.891641] Initializing USB Mass Storage driver...
[ 1.896919] usbcore: registered new interface driver usb-storage
[ 1.903045] USB Mass Storage support registered.
[ 1.907941] usbcore: registered new interface driver libusual
[ 1.914085] mousedev: PS/2 mouse device common for all mice
[ 1.920568] bcm2835-cpufreq: min=700000 max=850000 cur=700000
[ 1.926583] bcm2835-cpufreq: switching to governor powersave
[ 1.932348] bcm2835-cpufreq: switching to governor powersave
[ 1.938154] cpuidle: using governor ladder
[ 1.947348] cpuidle: using governor menu
[ 1.956249] sdhci: Secure Digital Host Controller Interface driver
[ 1.967399] sdhci: Copyright(c) Pierre Ossman
[ 1.976732] sdhci: Enable low-latency mode
[ 2.025295] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.038359] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.051398] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.067905] usbcore: registered new interface driver usbhid
[ 2.078568] usbhid: USB HID core driver
[ 2.089631] Indeed it is in host mode hprt0 = 00021501
[ 2.102603] TCP: cubic registered
[ 2.125121] Initializing XFRM netlink socket
[ 2.145161] NET: Registered protocol family 17
[ 2.165311] Key type dns_resolver registered
[ 2.187403] mmc0: read SD Status register (SSR) after 2 attempts
[ 2.174926] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.225767] registered taskstats version 1
[ 2.237221] mmc0: new high speed SDHC card at address 59b4
[ 2.256066] Waiting for root device /dev/mmcblk0p2...
[ 2.267114] mmcblk0: mmc0:59b4 SDC 7.34 GiB
[ 2.278378] mmcblk0: p1 p2
[ 2.385698] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.397987] Indeed it is in host mode hprt0 = 00001101
[ 2.447618] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.475152] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.504120] devtmpfs: mounted
[ 2.512913] Freeing init memory: 128K
[ 2.635800] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.648586] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.665310] hub 1-1:1.0: USB hub found
[ 2.674574] hub 1-1:1.0: 5 ports detected
[ 2.965468] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.075841] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.093691] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.113857] smsc95xx v1.0.4
[ 3.190067] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:78:f3:72
[ 3.305382] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.418890] usb 1-1.2: New USB device found, idVendor=0d8c, idProduct=0102
[ 3.431497] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.444266] usb 1-1.2: Product: USB Sound Device
[ 3.467344] input: USB Sound Device as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.3/input/input0
[ 3.484822] hid-generic 0003:0D8C:0102.0001: input,hidraw0: USB HID v1.00 Device [USB Sound Device ] on usb-bcm2708_usb-1.2/input3
[ 4.177230] udevd[154]: starting version 175
[ 5.712977] Registered led device: led0
[ 7.746470] usbcore: registered new interface driver snd-usb-audio
[ 11.197355] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.725716] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 20.184620] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 20.243793] nf_conntrack version 0.5.0 (5996 buckets, 23984 max)
[ 20.368214] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 23.284505] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 25.600043] bcm2835-cpufreq: switching to governor ondemand
[ 25.600074] bcm2835-cpufreq: switching to governor ondemand
[ 27.657227] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:507900k SS
Thanks for your continuous efforts!!!
