I was having wi-fi issues with a new Raspberry Pi 3 (with latest Raspbian, just downloaded yesterday). It'd be fine initially, but after a few minutes sitting idle, the Pi often wasn't reachable from other machines on the local network (for ping, ssh, vnc, etc). It seems that the wi-fi module has quite aggressive power-saving enabled.
I looked around on the web and found a series of steps that fixed the issue for me. It might be that some of these are redundant, but they worked here, and should only take a couple of minutes (just once). You're welcome to try them.
You'll need to be logged into the Pi on the command line to proceed, either directly or via ssh from another machine. (You can get into your Pi via ssh on your local network by doing ssh pi@raspberrypi and entering the usual password.)
Also, I use the nano editor in these steps. Feel free to substitute whatever you prefer.
Assumption: your wi-fi interface is wlan0. Check first by doing
iwconfig
As a temporary fix while you're following these steps, do this:
sudo iwconfig wlan0 power off
Step 1
Do:
sudo nano /etc/modprobe.d/8192cu.conf
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=1
Step 2
Do:
sudo nano /etc/rc.local
sleep 10
Do:
sudo nano /etc/systemd/system/root-resume.service
[Unit]
Description=Turn of wlan power management
After=suspend.target
[Service]
Type=simple
ExecStartPre= /bin/sleep 10
ExecStart= /sbin/iwconfig wlan0 power off
[Install]
WantedBy=suspend.target
sudo systemctl enable root-resume
Finally, reboot the Pi (sudo reboot). That's it.
Check that it worked
To check it worked, once you've rebooted, do:
iwconfig
Hope that helps.
-M
