fanoush
Re: Dynamode USB Wifi Dongle issues
Sun Dec 28, 2014 3:25 pm
claytonc wrote:Do I need to build the kernel to integrate the necessary wireless driver? Can't I just compile the driver and install it? Can someone guide me through this process please?
No you don't need to build the kernel if you have matching linux-headers. I just did it like this:
I got the driver source from https://github.com/porjo/mt7601.git - it looks like there are some additional driver fixes not present in mediatek source
git clone https://github.com/porjo/mt7601.git
Then I got matching linux-headers from http://www.niksula.hut.fi/~mhiienka/Rpi ... aders-rpi/ (many thanks for this, these should really be part of raspibian for every kernel but for some reason they are not!)
wget http://www.niksula.hut.fi/~mhiienka/Rpi/linux-headers-rpi/linux-headers-3.12.35%2b_3.12.35%2b-2_armhf.deb
sudo dpkg -i linux-headers-3.12.35+_3.12.35+-2_armhf.deb
then it told me it needs gcc-4.7 so I installed it
sudo apt-get install gcc-4.7 cpp-4.7
then I could finally compile the driver
cd mt7601/src/
sudo make
sudo make install
Then I applied udev name fix to have network interface to be named wlan0 instead of ra0
sudo nano /etc/udev/rules.d/95-ralink.rules
and entered
ACTION=="add", SUBSYSTEM=="net", ATTR{type}=="1", KERNEL=="ra*", NAME="wlan0"
then I plugged in the dongle and it just worked like my other one I used previously :-)
onetelcomms
Sun Jan 04, 2015 5:25 am
If you still having issues, please see topic below:
http://blog.petrockblock.com/forums/topic/wifi-dongle-setup-retropie-148f7601-ralink-technology/
:D
sodae
Sun Jan 04, 2015 10:40 am
alfonder: thank you so much! It works :-)
alfonder
Sun Jan 04, 2015 11:35 am
wilferraciolli, fanoush, symlink to sources should be created automatically if you install kernel headers from official package (not from external repo).
Moreover, I'd avoid installing packages from unknown repos like niksula.hut.fi because of security concerns.
To support me, register Dropbox account via invitation https://db.tt/xrV5BqTf
fanoush
Tue Jan 06, 2015 8:29 pm
alfonder wrote:wilferraciolli, fanoush, symlink to sources should be created automatically if you install kernel headers from official package (not from external repo).
and which package exactly it is? I did not find one matching current kernel. apt-get install linux-headers suggested only very old ones (for kernels 3.2, 3.6, 3.10) nothing for 3.12.35+ or even only 3.12.
srinivas
Wed Jan 07, 2015 3:56 am
Thanks a lot alfonder, for taking time to build these drivers. Much appreciated. I am able to set up my router with ease.
LamarrCZ
Thu Jan 15, 2015 6:57 pm
Hello, can anybody compile for me these drivers for MT7601 for the latest kernel 3.17.7? (I'm using OpenELEC).
cancunia
Sat Jan 17, 2015 8:22 pm
I've read so many posts on this subject, I cannot remember exactly how I came across this one, it's in German, but the code is very easy to copy & paste.
It worked a treat on my Rpi B+. Many thanks to Thomas Wenzlaff for documenting it!
http://blog.wenzlaff.de/?p=4805
daming99
Tue Jan 20, 2015 12:24 pm
@onetelcomms, I did all what you have said and process smoothly, but after I plugged the dongle on pi, I can't still use wifi to connect the Internet, is there anything I've missed or what should I do to make sure that what I did is on the right way, thank you for your help!
Matthyeux
Sun Jan 25, 2015 11:07 am
Hi everybody,
I also bought one of these wifi usb and I can't succeed in the compilation of the MT7601U driver. (I run into 3.18.3+ and as far as i can see, nobody made these working for this version)
Here are serveral steps that i follow with no success:
lsusb give me this output:
Bus 001 Device 004: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
I downloaded the lastest kernel release on github and extracted it:
https://github.com/raspberrypi/linux/rpi-3.18.y.tar.gz
made these instructions into rpi-linux-3.18 folder with no errors
make mrproper
zcat /proc/config.gz > .config
cp .config .config.org
sed -i 's/^CONFIG_CROSS_COMPILE.*/CONFIG_CROSS_COMPILE=""/' .config
make modules_prepare
wget https://raw.github.com/raspberrypi/firmware/master/extra/Module.symvers
then I got the MTU7601U driver from MediaTek (file : DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.bz2 )
extracted it then proceed to make && make install.
In my first attempts i couldn't run correctly make because of an error with a struct in the rt_linux.h
error: incompatible types when assigning to type ‘int’ from type ‘kuid_t’
error: incompatible types when assigning to type ‘int’ from type ‘kgid_t’
so i made a patch in this file by replacing int by kuid_t and kgid_t respectively (maybe the driver doesn't work cause of it ?)
Then i make && make install once again and (with lot of warnings) the driver compiled.
I installed by run:
sudo insmod /lib/modules/3.18.3/kernel/drivers/net//wireless/mt7601Usta.ko
And reboot my rpi.. But when i plug my usb wifi dongle i get this error:
[  642.853612] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[  642.965765] usb 1-1.4: New USB device found, idVendor=148f, idProduct=7601
[  642.965809] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  642.965830] usb 1-1.4: Product: 802.11 n WLAN
[  642.965849] usb 1-1.4: Manufacturer: MediaTek
[  642.965866] usb 1-1.4: SerialNumber: 1.0
[b][  643.149300] Unable to handle kernel paging request at virtual address 7e319b54
[  643.164074] pgd = d0660000
[  643.166813] [7e319b54] *pgd=00000000
[  643.170516] Internal error: Oops: 5 [#1] PREEMPT ARM
[  643.175482] Modules linked in: mt7601Usta(O+) snd_soc_pcm512x_i2c snd_soc_tas5713 snd_soc_pcm512x regmap_i2c i2c_dev i2c_bcm2708 snd_bcm2835 snd_soc_bcm2708_i2s regmap_mmio snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_seq snd_seq_device snd_timer snd
[  643.198715] CPU: 0 PID: 2517 Comm: modprobe Tainted: G           O   3.18.3+ #738
[  643.206190] task: ca412880 ti: d70a8000 task.ti: d70a8000
[  643.211610] PC is at load_module+0x1948/0x1f1c
[  643.216056] LR is at load_module+0x1934/0x1f1c
[  643.220502] pc : [<c008927c>]    lr : [<c0089268>]    psr: 30000013
[  643.220502] sp : d70a9e88  ip : bf1a85d8  fp : d70a9f44
[  643.231964] r10: bf1a8470  r9 : 00000000  r8 : bf1a847c
[  643.237182] r7 : c0561368  r6 : d065a2e0  r5 : 7e319b40  r4 : d70a9f48
[  643.243699] r3 : 00000000  r2 : 00000000  r1 : d064c5a0  r0 : c0824000
[  643.250219] Flags: nzCV  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  643.257345] Control: 00c5387d  Table: 10660008  DAC: 00000015
[  643.263086] Process modprobe (pid: 2517, stack limit = 0xd70a81b0)[/b]
[  643.269258] Stack: (0xd70a9e88 to 0xd70aa000)
[  643.273619] 9e80:                   bf1a847c 00007fff c00862c0 c0300708 00000013 00000000
[  643.281794] 9ea0: da0aa000 d70a9f7c d70a9f50 d70a9eb8 00000000 bf1a847c d70a8008 bf1a84b8
[  643.289969] 9ec0: bf1a85d8 00000000 b6d30000 d70a8000 00002db0 00000000 00000000 bf1715bc
[  643.298141] 9ee0: 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  643.306314] 9f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000080 000f6b01
[  643.314488] 9f20: b6c49000 b6f64948 00000080 c000eb44 d70a8000 00000000 d70a9fa4 d70a9f48
[  643.322664] 9f40: c008993c c0087940 da0aa000 000f6b01 da15ff1c da15fd1a da198394 000b3634
[  643.330837] 9f60: 000c36c4 00000000 00000000 00000000 00000030 00000031 00000026 0000002a
[  643.339011] 9f80: 00000016 00000000 00000000 00000000 00060000 b7422678 00000000 d70a9fa8
[  643.347185] 9fa0: c000e8c0 c008985c 00000000 00060000 b6c49000 000f6b01 b6f64948 b6c49000
[  643.355359] 9fc0: 00000000 00060000 b7422678 00000080 b7421cf8 000f6b01 b6f64948 00000000
[  643.363534] 9fe0: 00000000 bebc890c b6f5bfb4 b6ec6ac4 60000010 b6c49000 00040014 68c08002
[  643.371730] [<c008927c>] (load_module) from [<c008993c>] (SyS_init_module+0xec/0x100)
[  643.379577] [<c008993c>] (SyS_init_module) from [<c000e8c0>] (ret_fast_syscall+0x0/0x48)
[  643.387671] Code: e51bc084 e15c0005 e2455008 0a000009 (e5953014)
[  643.677498] ---[ end trace 83e75e278f1e0439 ]---
I tried to recompile again and again but this issue come over.
Anyone know how to compile this driver for my version or know what have I done wrong (or maybe have the driver ready-to :P) ?
P.S: Sorry for my bad english.
Matthyeux
Thu Jan 29, 2015 8:43 am
Bump ? :)
doomy86
Thu Jan 29, 2015 8:34 pm
Im on kernel 3.18.4+ had the same problem with compiling..
Then i used the modified source from https://github.com/porjo/mt7601.git
This compiled ok but i when i try to load the driver i get:
[22538.501691] Unable to handle kernel paging request at virtual address 7e3e7800
[22538.526110] pgd = d95c0000
[22538.531116] [7e3e7800] *pgd=00000000
[22538.539090] Internal error: Oops: 5 [#1] PREEMPT ARM
[22538.546222] Modules linked in: mt7601Usta(O+) rfcomm bnep snd_bcm2835 snd_pcm snd_seq snd_seq_device snd_timer snd ecb btusb bluetooth rfkill uio_pdrv_genirq uio
[22538.565115] CPU: 0 PID: 8608 Comm: insmod Tainted: G           O   3.18.4+ #743
[22538.574512] task: db2a8000 ti: d958a000 task.ti: d958a000
[22538.581989] PC is at load_module+0x1948/0x1f1c
[22538.588500] LR is at load_module+0x1934/0x1f1c
[22538.594975] pc : [<c0089278>]    lr : [<c0089264>]    psr: 30000013
[22538.594975] sp : d958be88  ip : bf205178  fp : d958bf44
[22538.610564] r10: bf205010  r9 : 00000000  r8 : bf20501c
[22538.617863] r7 : c05613a8  r6 : d94caae0  r5 : 7e3e77ec  r4 : d958bf48
[22538.626482] r3 : 00000000  r2 : 00000000  r1 : db3e4af0  r0 : c0824120
[22538.635098] Flags: nzCV  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[22538.644320] Control: 00c5387d  Table: 195c0008  DAC: 00000015
[22538.652120] Process insmod (pid: 8608, stack limit = 0xd958a1b0)
[22538.660194] Stack: (0xd958be88 to 0xd958c000)
[22538.666611] be80:                   bf20501c 00007fff c00862bc c02fe3e8 00000013 00000000
[22538.678994] bea0: de2ea000 d958bf7c d958bf50 d958beb8 00000000 bf20501c d958a008 bf205058
[22538.691625] bec0: bf205178 00000000 b6da0000 d958a000 00002db0 00000000 00000000 bf1e26bc
[22538.704321] bee0: 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[22538.717242] bf00: 00000000 00000000 00000000 00000000 00000000 00000000 00000080 000bb0fa
[22538.730370] bf20: b6ce5000 b6f0b948 00000080 c000eb44 d958a000 00000000 d958bfa4 d958bf48
[22538.743535] bf40: c0089938 c008793c de2ea000 000bb0fa de371ae8 de37192e de39d428 000851d4
[22538.756823] bf60: 00093414 00000000 00000000 00000000 0000002b 0000002c 00000021 00000025
[22538.770398] bf80: 00000014 00000000 00000000 bea086ac 00000000 b75a3048 00000000 d958bfa8
[22538.784169] bfa0: c000e8c0 c0089858 bea086ac 00000000 b6ce5000 000bb0fa b6f0b948 b6ce5000
[22538.798135] bfc0: bea086ac 00000000 b75a3048 00000080 b75a2f78 000bb0fa b6f0b948 00000000
[22538.812223] bfe0: 00000000 bea08654 b6f02fb4 b6e6dac4 60000010 b6ce5000 00000000 00000000
[22538.826499] [<c0089278>] (load_module) from [<c0089938>] (SyS_init_module+0xec/0x100)
[22538.837519] [<c0089938>] (SyS_init_module) from [<c000e8c0>] (ret_fast_syscall+0x0/0x48)
[22538.851754] Code: e51bc084 e15c0005 e2455008 0a000009 (e5953014)
[22538.873242] ---[ end trace 6a64808ea47e8872 ]---
fanoush
Thu Jan 29, 2015 8:50 pm
Did you try compiling this https://github.com/porjo/mt7601 ?
Matthyeux
Thu Jan 29, 2015 8:59 pm
Yes I tried this today and I get the same issue when i run the command
insmod os/linux/mt7601Usta.ko
has given me
[ 2443.969818] Internal error: Oops: 5 [#1] PREEMPT ARM
alfonder
Tue Feb 03, 2015 9:49 pm
Eventually, I'm back from those soooo long New Year holidays :D . Now it's time to update.
Here is the driver for kernel 3.18.5+ #746.
How to install
Ssh to your RaspberryPi and enter the following commands (better copy-paste to avoid typos):
cd /tmp
wget https://dl.dropboxusercontent.com/u/67643651/mt7601_3.18.5_746.tar.gz
sudo tar xf mt7601_3.18.5_746.tar.gz -C /
sudo depmod 3.18.5+
sudo reboot
nishchay
Wed Feb 04, 2015 10:51 am
i too was having the same problem for almost a month now the device 7601 ralink tech was not recognized. but as instructed in your post i downloaded the driver for 3.18.5+ and rebooted immediately the ra0 was up.
Thanks :D
alfonder
Wed Feb 04, 2015 8:42 pm
nishchay wrote: immediately the ra0 was up.
Thanks :D
Glad to know it helped.
For those, who prefer to compile the driver by themselves, I can post the patch, which makes Ralink's driver 3.0.0.4 compatible with kernel 3.18+
MrEngman
Wed Feb 04, 2015 9:40 pm
Thanks :D
Yes, please.
MrEngman
amazon83
Thu Feb 05, 2015 3:46 pm
Hi alfonder,
I'm using xiaomi wifi, using driver DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.bz2 , i follow your instruction my wifi usb was not working, possible to add in below command to /common/rtusb_dev_id.c and compile again?
{USB_DEVICE(0x2717,0x4106)}, /* Xiaomi Wifi */
fburton
Thu Feb 05, 2015 9:11 pm
I have tried to install the driver following the last post. No issue to report in the actual installation process, but it's not working.
Details on my Pi:
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 148f:761a Ralink Technology, Corp.
Bus 001 Device 005: ID 045e:00b0 Microsoft Corp. Digital Media Pro Keyboard
lsmodpi@raspberrypi ~ $ lsmod
Module Size Used by
snd_bcm2835 21342 0
snd_pcm 93100 1 snd_bcm2835
snd_seq 61097 0
snd_seq_device 7209 1 snd_seq
snd_timer 23007 2 snd_pcm,snd_seq
snd 67211 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
joydev 9766 0
evdev 11000 2
uio_pdrv_genirq 3666 0
uio 9897 1 uio_pdrv_genirq
root@raspberrypi:/home/pi# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.5+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #748 PREEMPT Wed Feb 4 21:24:41 GMT 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B+
[ 0.000000] cma: Reserved 8 MiB at 0x1b800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c084d794, node_mem_map db474000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2708.boardrev=0x10 bcm2708.serial=0x1333b35 smsc95xx.macaddr=B8:27:EB:33:3B:35 bcm2708_fb.fbswap=1 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437208K/458752K available (5926K kernel code, 358K rwdata, 1876K rodata, 340K init, 734K bss, 21544K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07a6a9c (7803 kB)
[ 0.000000] .init : 0xc07a7000 - 0xc07fc000 ( 340 kB)
[ 0.000000] .data : 0xc07fc000 - 0xc085582c ( 359 kB)
[ 0.000000] .bss : 0xc085582c - 0xc090d0c8 ( 735 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000026] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000078] Switching to timer-based delay loop, resolution 1000ns
[ 0.000359] Console: colour dummy device 80x30
[ 0.001430] console [tty1] enabled
[ 0.001478] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001553] pid_max: default: 32768 minimum: 301
[ 0.001931] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001995] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003010] Initializing cgroup subsys memory
[ 0.003100] Initializing cgroup subsys devices
[ 0.003159] Initializing cgroup subsys freezer
[ 0.003213] Initializing cgroup subsys net_cls
[ 0.003263] Initializing cgroup subsys blkio
[ 0.003389] CPU: Testing write buffer coherency: ok
[ 0.003503] ftrace: allocating 19477 entries in 58 pages
[ 0.111310] Setting up static identity map for 0x55cbf8 - 0x55cc54
[ 0.114131] devtmpfs: initialized
[ 0.131694] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.134886] pinctrl core: initialized pinctrl subsystem
[ 0.137534] NET: Registered protocol family 16
[ 0.143069] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.171093] cpuidle: using governor ladder
[ 0.201152] cpuidle: using governor menu
[ 0.201668] bcm2708.uart_clock = 3000000
[ 0.204760] No ATAGs?
[ 0.204825] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.204888] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.204951] mailbox: Broadcom VideoCore Mailbox driver
[ 0.205117] bcm2708_vcio: mailbox at f200b880
[ 0.205265] bcm_power: Broadcom power driver
[ 0.205312] bcm_power_open() -> 0
[ 0.205341] bcm_power_request(0, 8)
[ 0.706091] bcm_mailbox_read -> 00000080, 0
[ 0.706138] bcm_power_request -> 0
[ 0.706333] Serial: AMBA PL011 UART driver
[ 0.706568] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.100824] console [ttyAMA0] enabled
[ 1.173896] SCSI subsystem initialized
[ 1.177999] usbcore: registered new interface driver usbfs
[ 1.183813] usbcore: registered new interface driver hub
[ 1.189324] usbcore: registered new device driver usb
[ 1.196532] Switched to clocksource stc
[ 1.228749] FS-Cache: Loaded
[ 1.232057] CacheFiles: Loaded
[ 1.252212] NET: Registered protocol family 2
[ 1.258152] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.265332] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.272117] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.278639] TCP: reno registered
[ 1.281906] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.287831] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.294535] NET: Registered protocol family 1
[ 1.299622] RPC: Registered named UNIX socket transport module.
[ 1.305592] RPC: Registered udp transport module.
[ 1.310431] RPC: Registered tcp transport module.
[ 1.315163] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.322883] bcm2708_dma: DMA manager at f2007000
[ 1.327911] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.337812] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 1.344077] audit: initializing netlink subsys (disabled)
[ 1.349796] audit: type=2000 audit(1.100:1): initialized
[ 1.370643] VFS: Disk quotas dquot_6.5.2
[ 1.374982] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.384512] FS-Cache: Netfs 'nfs' registered for caching
[ 1.391697] NFS: Registering the id_resolver key type
[ 1.397006] Key type id_resolver registered
[ 1.401223] Key type id_legacy registered
[ 1.406781] msgmni has been set to 869
[ 1.413102] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.421120] io scheduler noop registered
[ 1.425104] io scheduler deadline registered (default)
[ 1.430839] io scheduler cfq registered
[ 1.437465] BCM2708FB: allocated DMA memory 5bc00000
[ 1.442537] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.472049] Console: switching to colour frame buffer device 222x59
[ 1.496404] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.504423] uart-pl011 dev:f1: no DMA platform data
[ 1.510370] vc-cma: Videocore CMA driver
[ 1.514427] vc-cma: vc_cma_base = 0x00000000
[ 1.519382] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.524908] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.544675] brd: module loaded
[ 1.555286] loop: module loaded
[ 1.559156] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.567515] Loading iSCSI transport class v2.0-870.
[ 1.574127] usbcore: registered new interface driver smsc95xx
[ 1.580470] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.786826] Core Release: 2.80a
[ 1.790086] Setting default values for core params
[ 1.795027] Finished setting default values for core params
[ 2.001045] Using Buffer DMA mode
[ 2.004475] Periodic Transfer Interrupt Enhancement - disabled
[ 2.010478] Multiprocessor Interrupt Enhancement - disabled
[ 2.016187] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.020696] Dedicated Tx FIFOs mode
[ 2.024718] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 2.034860] FIQ FSM acceleration enabled for :
[ 2.034860] Non-periodic Split Transactions
[ 2.034860] Periodic Split Transactions
[ 2.034860] High-Speed Isochronous Endpoints
[ 2.061769] dwc_otg: Microframe scheduler enabled
[ 2.061967] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc0400d70
[ 2.072989] WARN::hcd_init_fiq:413: FIQ ASM at 0xc0401048 length 36
[ 2.084272] WARN::hcd_init_fiq:438: MPHI regs_base at 0xdc806000
[ 2.095182] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.105204] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.117638] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.128129] Init: Port Power? op_state=1
[ 2.137166] Init: Power Port (0)
[ 2.145799] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.157797] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.170126] usb usb1: Product: DWC OTG Controller
[ 2.179806] usb usb1: Manufacturer: Linux 3.18.5+ dwc_otg_hcd
[ 2.190598] usb usb1: SerialNumber: bcm2708_usb
[ 2.201424] hub 1-0:1.0: USB hub found
[ 2.210316] hub 1-0:1.0: 1 port detected
[ 2.219979] dwc_otg: FIQ enabled
[ 2.220004] dwc_otg: NAK holdoff enabled
[ 2.220017] dwc_otg: FIQ split-transaction FSM enabled
[ 2.220100] Module dwc_common_port init
[ 2.220676] usbcore: registered new interface driver usb-storage
[ 2.232337] mousedev: PS/2 mouse device common for all mice
[ 2.243890] bcm2835-cpufreq: min=700000 max=700000
[ 2.254304] sdhci: Secure Digital Host Controller Interface driver
[ 2.265729] sdhci: Copyright(c) Pierre Ossman
[ 2.275341] DMA channels allocated for the MMC driver
[ 2.316831] Load BCM2835 MMC driver
[ 2.330558] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.349629] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.360973] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.376106] usbcore: registered new interface driver usbhid
[ 2.386879] usbhid: USB HID core driver
[ 2.398395] TCP: cubic registered
[ 2.406851] Initializing XFRM netlink socket
[ 2.417507] Indeed it is in host mode hprt0 = 00021501
[ 2.429730] NET: Registered protocol family 17
[ 2.446829] Key type dns_resolver registered
[ 2.464478] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.478997] registered taskstats version 1
[ 2.499052] mmc0: new high speed SDHC card at address 0002
[ 2.509992] vc-sm: Videocore shared memory driver
[ 2.536622] [vc_sm_connected_init]: start
[ 2.546762] mmcblk0: mmc0:0002 00000 7.32 GiB
[ 2.568501] [vc_sm_connected_init]: end - returning 0
[ 2.580645] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.614734] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.628417] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 2.642042] devtmpfs: mounted
[ 2.651886] Freeing unused kernel memory: 340K (c07a7000 - c07fc000)
[ 2.706859] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.719470] Indeed it is in host mode hprt0 = 00001101
[ 2.937176] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.951239] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.965179] hub 1-1:1.0: USB hub found
[ 2.974515] hub 1-1:1.0: 5 ports detected
[ 3.256968] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.387215] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.411826] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.440026] smsc95xx v1.0.4
[ 3.524820] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:33:3b:35
[ 3.636946] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.793142] usb 1-1.3: New USB device found, idVendor=148f, idProduct=761a
[ 3.816781] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.845510] usb 1-1.3: Product: WiFi
[ 3.866760] usb 1-1.3: Manufacturer: MediaTek
[ 3.885913] usb 1-1.3: SerialNumber: 1.0
[ 4.146872] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
[ 4.328182] usb 1-1.5: New USB device found, idVendor=045e, idProduct=00b0
[ 4.356745] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.386727] usb 1-1.5: Product: Microsoft\xffffffc2\xffffffae\xffffffae Digital Media Pro Keyboard
[ 4.403521] usb 1-1.5: Manufacturer: Microsoft
[ 4.457937] input: Microsoft Microsoft\xffffffc2\xffffffae\xffffffae Digital Media Pro Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:00B0.0001/input/input0
[ 4.482595] hid-generic 0003:045E:00B0.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft\xffffffc2\xffffffae\xffffffae Digital Media Pro Keyboard] on usb-bcm2708_usb-1.5/input0
[ 4.551442] input: Microsoft Microsoft\xffffffc2\xffffffae\xffffffae Digital Media Pro Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:045E:00B0.0002/input/input1
[ 4.587819] hid-generic 0003:045E:00B0.0002: input,hidraw1: USB HID v1.11 Device [Microsoft Microsoft\xffffffc2\xffffffae\xffffffae Digital Media Pro Keyboard] on usb-bcm2708_usb-1.5/input1
[ 4.722957] udevd[159]: starting version 175
[ 7.401507] random: nonblocking pool is initialized
[ 11.612889] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 12.107194] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 22.497591] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 24.014208] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 31.857808] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Any ideas on what could be wrong??
ginner159
Fri Feb 06, 2015 12:00 am
Well that last one seemed to compile for me with 3.2 ... for ras pi a+ onwards but im getting
association request to the driver failed
in wpa gui
MrEngman
Fri Feb 06, 2015 12:48 am
fburton wrote:I have tried to install the driver following the last post. No issue to report in the actual installation process, but it's not working.
Details on my Pi:
Module Size Used by
snd_bcm2835 21342 0
snd_seq 61097 0
joydev 9766 0
evdev 11000 2
The driver is not loading and I assume it is because it doesn't recognise the wifi module.
Looking at the mt7601 driver source codes I have the USB ID for your module is not included in any of them so is it included in the source you have and are you sure this is the right driver to use.
If it is the right driver and the USB ID is not included you could try adding the USB ID and re-compiling the driver. Looks like the file you need to edit is common/rtusb_dev_id.c.
MrEngman
amazon83
Fri Feb 06, 2015 1:13 am
I try all github mt7601u compile with https://github.com/raspberrypi/linux/ar ... 8.y.tar.gz
after make && sudo make install when run sudo modprobe mt7601Usta
I try to reboot but it fail, it just stuck in "loading kernel module snd-bcm2835"
Please help, how to make xiaomi wifi to support 3.18.5+ kernel?
It just show below:
Message from syslogd@leepi at Feb 6 08:57:53 ...
kernel:[ 6193.073823] Internal error: Oops: 5 [#1] PREEMPT ARM
kernel:[ 6193.182576] Process modprobe (pid: 9645, stack limit = 0xc3d221b0)
kernel:[ 6193.190549] Stack: (0xc3d23e88 to 0xc3d24000)
kernel:[ 6193.196655] 3e80: bf19cdcc 00007fff c00862f4 c02fe1a8 00000013 00000000
kernel:[ 6193.208291] 3ea0: de1e8000 c3d23f7c c3d23f50 c3d23eb8 00000000 bf19cdcc c3d22008 bf19ce08
kernel:[ 6193.220158] 3ec0: bf19cf28 00000000 b6d20000 c3d22000 00002db0 00000000 00000000 bf1665b8
kernel:[ 6193.232100] 3ee0: 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
kernel:[ 6193.244064] 3f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000080 000f64a0
kernel:[ 6193.256137] 3f20: b6c2d000 b6f4b948 00000080 c000eb44 c3d22000 00000000 c3d23fa4 c3d23f48
kernel:[ 6193.268456] 3f40: c0089970 c0087974 de1e8000 000f64a0 de29d898 de29d696 de2d5d20 000b2f84
kernel:[ 6193.280927] 3f60: 000c3014 00000000 00000000 00000000 00000030 00000031 00000026 0000002a
kernel:[ 6193.293556] 3f80: 00000016 00000000 00000000 00000000 00040000 b7ebac88 00000000 c3d23fa8
kernel:[ 6193.306271] 3fa0: c000e8c0 c0089890 00000000 00040000 b6c2d000 000f64a0 b6f4b948 b6c2d000
kernel:[ 6193.319091] 3fc0: 00000000 00040000 b7ebac88 00000080 b7ebad68 000f64a0 b6f4b948 00000000
kernel:[ 6193.331988] 3fe0: 00000000 bed7140c b6f42fb4 b6eae0d4 60000010 b6c2d000 00000000 0160e030
kernel:[ 6193.370380] Code: e51bc084 e15c0005 e2455008 0a000009 (e5953014)
ilovemipi
Sat Feb 07, 2015 12:39 pm
alfonder wrote:Eventually, I'm back from those soooo long New Year holidays :D . Now it's time to update.
How to install
cd /tmp
sudo depmod 3.18.5+
sudo reboot
alfonder could you please make the driver for the latest update (3.18.5+ 748) available?
ginner159
Mon Feb 09, 2015 1:47 pm
Any chance you can compile it for the a+ and pi 2
