IlTizio
HP LaserJet p1102 printer not recognized
Sun Nov 10, 2013 3:01 pm
Hello, I have an urgent problem with a HP LaserJet P1102
I'm using 2013-05-25-wheezy-raspbian
I disabled the printer windows smart-install feature
I installed cups and foo2zjs driver ( http://foo2zjs.rkkda.com/ )
(i downloaded and compiled the driver manually, without apt-get)
Cups doesn't see it, and lsusb either.
lsusb output:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
dmesg output:
[ 1563.855076] usb 1-1.3: new high-speed USB device number 119 using dwc_otg
[ 1565.645336] usb 1-1.3: new high-speed USB device number 126 using dwc_otg
[ 1565.905355] usb 1-1.3: new high-speed USB device number 127 using dwc_otg
[ 1568.205669] usb 1-1.3: new high-speed USB device number 12 using dwc_otg
[ 1568.465704] usb 1-1.3: new high-speed USB device number 13 using dwc_otg
[ 1568.965762] usb 1-1.3: new high-speed USB device number 15 using dwc_otg
[ 1569.225797] usb 1-1.3: new high-speed USB device number 16 using dwc_otg
[ 1570.245829] usb 1-1.3: new high-speed USB device number 20 using dwc_otg
[ 1571.275973] usb 1-1.3: new high-speed USB device number 24 using dwc_otg
[ 1571.536002] usb 1-1.3: new high-speed USB device number 25 using dwc_otg
[ 1572.046070] usb 1-1.3: new high-speed USB device number 27 using dwc_otg
[ 1573.326240] usb 1-1.3: new high-speed USB device number 32 using dwc_otg
[ 1575.886588] usb 1-1.3: new high-speed USB device number 42 using dwc_otg
[ 1576.146628] usb 1-1.3: new high-speed USB device number 43 using dwc_otg
[ 1578.957008] usb 1-1.3: new high-speed USB device number 54 using dwc_otg
[ 1579.467086] usb 1-1.3: new high-speed USB device number 56 using dwc_otg
[ 1580.487215] usb 1-1.3: new high-speed USB device number 60 using dwc_otg
(and it continues as long as the printer is plugged)
what could i do?
thank you for your time, and sorry for my bad english
MoosePi
Re: HP LaserJet p1102 printer not recognized
Sun Nov 10, 2013 5:31 pm
If it is not recognised by lsusb then no driver will make it work, you may need it plugged into a USB Powered Hub ?
With HP Printers and Raspbian Wheezzy all you need is to install the hplip-gui package, then plug in the printer and run the software
sudo apt-get update
sudo apt-get install hplip-gui
.....this will download all the dependencies required
According to http://hplipopensource.com/hplip-web/index.html your printer is supported !
You will obviously need to uninstall the drivers you have manually installed..
Pi Forum Search and Google yields answers to many questions
IlTizio
Mon Nov 11, 2013 2:38 pm
For the truth, i remember i managed to have it works succesfully (without needing an usb powered hub), but i forgot how i did.
I will try with hplip, but from what i know, hplip drivers for this printer are yes supported, but not for arm ( http://linux.subogero.com/1312/hp-laser ... 02-on-rpi/ )
IlTizio
Thu Nov 14, 2013 7:09 pm
no way.
hp-lip doesn't work. hp-setup doesn't detect the printer
MoosePi
Thu Nov 14, 2013 7:18 pm
IlTizio wrote:no way.
Is it recognized by lsusb now ? Last time the Printer was not recognized by Debian Wheezy and if it is not recognized no driver will find it !
subogero
Thu Nov 14, 2013 7:31 pm
If you find on the HPlip page that the printer is supported, you must check whether a proprietary plugin is required.
The HPlip framewok installs the plugin automatically.
The catch is this: HP compiles these plugins only for the x86 platform. So no luck on theRaspberry Pi, which is ARM.
IlTizio
Thu Nov 14, 2013 7:36 pm
no it isn't
i don't know what to do.. i remember i got it to work months agoo, but i forgot how i did :(
i remember the printer wasn't recognized by lsusb, then i installed "something" (including that foozjs driver) and it worked.
MoosePi
Thu Nov 14, 2013 7:41 pm
subogero wrote:If you find on the HPlip page that the printer is supported, you must check whether a proprietary plugin is required.
Disagree: I have a supported Printer and HPLIP installs the printer on Lubuntu x86-32 & x86-64 as well as Raspbian Wheezy with no extra plug-ins etc needed or required.
The problem the OP has is in the output of LSUSB did not show the printer, and still he has not confirmed whether or not it is now recognized by in the lsusb output.
So if Linux does not recognize a device is plugged in, a driver at this stage is actually immaterial and guesswork !!
IlTizio
Thu Nov 14, 2013 7:51 pm
MoosePi wrote: The problem the OP has is in the output of LSUSB did not show the printer, and still he has not confirmed whether or not it is now recognized by in the lsusb output.
IlTizio wrote: no it isn't
not recognized yet
IlTizio
Sun Nov 17, 2013 12:06 pm
seems like it works, using a powered hub. even if i'm sure it wasn't needed before
(and using foo2zjs driver. hplip doesn't work)
MoosePi
Sun Nov 17, 2013 1:47 pm
Glad you now have a working Printer, another issue solved !
Raspi_developer
Sat Sep 13, 2014 6:08 pm
Hello all,
I’ve been trying to get hp LaserJet P1102 printer working with raspberry Pi, tried all the ways found on internet but no Luck.
I got CUPS successfully installed on Pi; its web interface detects the printer and adds the printer as default. I am able to access the printer through command line using command lpstat –q, lpq, lpstat –d etc. I tried installing the driver recommended here http://linux.subogero.com/1312/hp-laser ... 02-on-rpi/ used USB powered hub too but nothing worked.
I have tried commands given here http://foo2zjs.rkkda.com/forum/read.php?68,3823,3823 all response seems ok. I also resumed printer using the command sudo cupsenable <printer_name>.
Everything seems ok except the printing activity. Please suggest me what might be going wrong, I am using Raspberry Pi Model B+ with Raspbian.
I need the printer working with Raspberry Pi, please suggest that could work for me.
thanks all.
Sat Sep 13, 2014 6:41 pm
Raspi_developer wrote:Hello all,
thanks all.
lnstall HPlip from Raspbian Wheezy repositories
sudo apt-get update
http://hplipopensource.com/hplip-web/mo ... p1102.html
Raspi_developer
Sun Sep 14, 2014 2:39 am
Thanks fruitoftheloom,
I'll be getting the printer back in 3-4 days will try it then and update here for sure. I hope it works.
Thanks again.
IlTizio
Sun Sep 14, 2014 3:00 pm
as for me i didn't need hplips (they don't provide drivers for this printer under linux). that's what i did (if i remember well):
apt-get install cups
wget -O foo2zjs.tar.gz http://foo2zjs.rkkda.com/foo2zjs.tar.gz
tar zxf foo2zjs.tar.gz
cd foo2zjs
make
make install
make cups
adduser pi lpadmin
http://localhost:631
add printer choosing foo2zjs driver
if it doesn't work, try using a usb hub (i discovered that even a non-powered one works, probably because usb hubs amplify signals)
good luck, i got mad trying to make it work
p.s.
Raspi_developer
Thu Sep 18, 2014 3:00 pm
Dear IlTizio and fruitoftheloom ,
Thanks a billion for your suggestion, today i finally got P1102 working with Model B+ :lol:
First print was just a surprise ;)
I must share what i did.
Executed following commands as suggested
sudo apt-get update
cd foo2zjs
make
make install
make cups
adduser pi lpadmin
added printer using HPLJ P1102 appearing with HPLIP
i dint find foo2zjs with HPLJ P1102 rather found with HPLJ 1020 just added this and continued with default page setup and it worked cool :)
Still i am confused why foo2zjs isn't appearing with HP LJ P1102.
Thanks guys for great help, thanks alot.
Good luck.
gkapou
Wed Aug 28, 2019 8:05 am
I followed the instructions of the above messg. It did not work. A woorkaround for me was to use cups interface and choose the relevant ppd file. The system gives an error but the printer works. thanx for the info guys.
