I'm looking for a completely CLI-based way to configure a pi to connect to either a WEP network or a WPA network.[1]
I'm attempting to:
[*]Connect to different networks in different locations at different times
[*]One of those networks is WEP
[*]Another network is WPA
[*](This means that I can't just hardcode the connection information into /etc/network/interfaces)
Please don't:
[*]Tell me to change from WEP to WPA. Not an option
[*]Send a LMGTFY link - I've searched my eyeballs out and frustration has finally boiled over to a forum post. I've read more man pages than I ever care to - everything from wpa_cli to iwconfig and all in between. [I'm also horribly frustrated at the differences in versions, even in the Raspberry Pi forums, let alone once I get off the official pages. I used NOOBS 1.3.3 to install Raspbian. I found posts from <1 year ago with commands which won't even work on this version of software, which only further frustrates a new user!]
Things I've done...
I've edited /etc/network/interfaces (as follows currently)
pi@raspberrypi ~ $ sudo cat /etc/network/interfaces
#loopback interface
auto lo
iface lo inet loopback
#eth0 - physical adaptor (RJ-45 connector)
#iface eth0 inet dhcp
iface eth0 inet static
address 10.0.1.82
netmask 255.255.255.0
gateway 10.0.1.1
#wlan0 - wireless adapter
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
# This works at work, but doesn't get DHCP
#auto wlan0
#allow-hotplug wlan0
#iface wlan0 inet dhcp
# wireless-essid MYWiFi #no quotes works
# wireless-key 1234567890 #spelling error before
pi@raspberrypi ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="MYWiFi"
key_mgmt=NONE
auth_alg=OPEN
wep_key0=1234567890
network={
ssid="MYWiFi"
psk="1234567890"
network={
ssid = "MYWiFi"
key_mgmt= NONE
wep_key0 = "1234567890"
I know I have association
pi@raspberrypi ~ $ iwconfig
wlan0 IEEE 802.11bg ESSID:"MYWiFi" Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency:2.417 GHz Access Point: 00:33:00:00:AA:33
Bit Rate:54 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality=40/100 Signal level=40/100 Noise level=0/100
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 Link encap:Ethernet HWaddr 33:ff:33:cc:ee:aa
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:452 errors:0 dropped:156 overruns:0 frame:0
TX packets:28 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:106153 (103.6 KiB) TX bytes:14424 (14.0 KiB)
sudo dhclient wlan0
... again, with no results!! Can anyone tell me a WEP setup that works without entering the info into /etc/network/interfaces, and NO, I don't have the option to just change the security to WPA.
[1] I use only SSH.[2]
[2] I have a display, but no, it isn't HDMI-capable.[3]
[3] I haven't found the GUI to reliably display on NTSC monitors (RCA out to projector through multi-connector video switch). [4]
[4] Right now I connect only through SSH, since I have no wired network hubs, switches, or routers. I would install VNC, but the RJ-45 connector is my only way in (through SSH) at the moment, and I can't get the wifi adapter to connect to the network, so I can't install using apt-get, since I can't connect to the internet and SSH in at the same time.
... and here I thought this thing would be new and fun - I didn't expect it to be easy, but I didn't expect it to be this incredibly frustrating either!!
