my PI arrived today and I got some problems with it
It seems like the HDMI-Output is broken, I managed to start Debian and have SSH to the pi, but I tested 2 different monitors with a HDMI->HDMI and a HDMI-DVI-cable, but none of them seems to give any output. The cables are tested and are working for other machines.
Here I attached dmesg-output:
Linux version 3.1.9+ (grayg@dc4-arm-01) (gcc version 4.5.1 (Broadcom-2708) ) #90 Wed Apr 18 18:23:05 BST 2012
CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: BCM2708
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 49152
free_area_init_node: node 0, pgdat c03b5660, node_mem_map c0402000
Normal zone: 384 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 48768 pages, LIFO batch:15
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0xb9005d9e smsc95xx.macaddr=B8:27:EB:00:5D:9E dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 192MB = 192MB total
Memory: 190720k/190720k available, 5888k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xcc800000 - 0xd8000000 ( 184 MB)
lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc037b000 (3532 kB)
.init : 0xc037b000 - 0xc0398000 ( 116 kB)
.data : 0xc0398000 - 0xc03b5ce0 ( 120 kB)
.bss : 0xc03b5d04 - 0xc0401198 ( 302 kB)
NR_IRQS:85
timer_set_mode: unhandled mode:1
timer_set_mode: unhandled mode:3
Console: colour dummy device 80x30
console [tty1] enabled
Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
NET: Registered protocol family 16
vc-mem: mm_vc_mem_phys_addr = 0x00000000
vc-mem: mm_vc_mem_size = 0x10000000 (256 MiB)
mailbox: Broadcom VideoCore Mailbox driver
bcm2708_vcio: mailbox at f200b880
bcm_power: Broadcom power driver
bcm_power_open() -> 0
bcm_power_request(0, 8)
bcm_mailbox_read -> 00000080, 0
bcm_power_request -> 0
Serial: AMBA PL011 UART driver
dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
console [ttyAMA0] enabled
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Switching to clocksource stc
FS-Cache: Loaded
CacheFiles: Loaded
Switched to NOHz mode on CPU #0
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
bcm2708_dma: DMA manager at cc808000
bcm2708_gpio: bcm2708_gpio_probe c039dd88
vc-mem: Videocore memory driver
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
FS-Cache: Netfs 'nfs' registered for caching
msgmni has been set to 372
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
BCM2708FB: registering framebuffer (656, 416)
bcm2708_fb_set_par info(cb888000) 656x416 (656x416), 0, 16
BCM2708FB: start = cc900000,4d384000 width=656, height=416, bpp=16, pitch=1312 size=545792 success=0
Console: switching to colour frame buffer device 82x26
BCM2708FB: register framebuffer (0)
brd: module loaded
loop: module loaded
vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
vcos: [1]: vchiq_init_state: called
vcos: [1]: vchiq: initialised - version 2 (min 2), device 253.0
usbcore: registered new interface driver smsc95xx
cdc_ncm: 04-Aug-2011
usbcore: registered new interface driver cdc_ncm
dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Core Release: 2.80a
Setting default values for core params
Finished setting default values for core params
cc840008 -> 1
Using Buffer DMA mode
Periodic Transfer Interrupt Enhancement - disabled
Multiprocessor Interrupt Enhancement - disabled
Dedicated Tx FIFOs mode
dwc_otg bcm2708_usb: DWC OTG Controller
dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Init: Port Power? op_state=1
Init: Power Port (0)
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
usb usb1: SerialNumber: bcm2708_usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Module dwc_common_port init
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
mousedev: PS/2 mouse device common for all mice
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
bcm_power_open() -> 1
Registered led device: mmc0::
mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
sdhci-pltfm: SDHCI platform and OF driver helper
Registered led device: led0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Waiting for root device /dev/mmcblk0p2...
mmc0: problem reading SD Status register.
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: p1 p2 p3
usb 1-1: new high speed USB device number 2 using dwc_otg
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
Freeing init memory: 116K
usb 1-1: New USB device found, idVendor=0424, idProduct=9512
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 3 ports detected
usb 1-1.1: new high speed USB device number 3 using dwc_otg
usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
smsc95xx v1.0.4
smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:00:5d:9e
EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
fuse init (API version 7.17)
smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
sshd (780): /proc/780/oom_adj is deprecated, please use /proc/780/oom_score_adj instead.
