jdb
Re: Call for beta testers: FIQ_FSM USB driver rewrite
Sat Apr 12, 2014 5:40 pm
FLYFISH TECHNOLOGIES wrote:Hi,
I can send you this USB board to have it on your desk and debug/monitor/observe the behavior.
Best wishes, Ivan Zilic.
I love people sending me random stuff.
Please PM me with the details.
Rockets are loud.
https://astro-pi.org
andrea.iob
Mon Apr 14, 2014 5:34 pm
jdb wrote: It's highly odd that simply playing FLAC breaks things.
I've also found some MP3 files that sound distorted. Inspecting the /proc/asound/card0/stream0 file it turns out that the working files are played as S24_3LE files with a "Packet Size" of 336, whereas the distorted files are played as S16_LE files with a "Packet Size" of 224 (I've doubled checked and it is NOT the other way around).
/proc/asound/card0/stream0 for working files
www.hirestech.com 2013 REV 3.0 Music Streamer II+ at usb-bcm2708_usb-1.3.4, ful : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 336
    Momentary freq = 44000 Hz (0x2c.0000)
    Feedback Format = 10.14
  Interface 1
    Altset 1
    Format: S24_3LE
    Channels: 2
    Endpoint: 1 OUT (ASYNC)
    Rates: 96000, 88200, 48000, 44100, 32000
  Interface 1
    Altset 2
    Format: S16_LE
    Channels: 2
/proc/asound/card0/stream0 for distorted files
Playback:
  Status: Running
    Interface = 1
    Altset = 2
    Packet Size = 224
    Momentary freq = 44500 Hz (0x2c.8000)
  Interface 1
    Altset 1
    Format: S24_3LE
    Channels: 2
  Interface 1
    Altset 2
    Format: S16_LE
    Channels: 2
That's quite strange because all the files I'm playing are 16bit / 44Hz.
Among the Linux 3.13 commits I've found the patch ALSA: improve buffer size computations for USB PCM audio. Do you think it could help? If it is the case could it be possible to update the kernel in the next branch to include this patch?
Mon Apr 14, 2014 11:32 pm
Just a heads up.
sudo BRANCH=next rpi-update
has been updated to 3.12.17 (the default firmware will follow).
The FIQ FSM patches are still in place.
Let us know if there are any new problems.
GrayShade
Tue Apr 15, 2014 5:37 am
dom wrote:Let us know if there are any new problems.
Well, mine doesn't boot anymore :).
tuxx
Tue Apr 15, 2014 9:09 am
Mine doesn't boot either after latest firmware upgrade.
Tue Apr 15, 2014 10:52 am
dom wrote:Just a heads up.
Started with a fresh install of Wheezy (not Nobs) and works AOK except the screen resolution has become lower, on 19" DVi 4:3 screen it was like 1024×768 now looks more like 640×480, at least can read the screen without glasses ROFL
Tue Apr 15, 2014 12:46 pm
tuxx wrote:Mine doesn't boot either after latest firmware upgrade.
I've just ran:
and it boots fine:
$ uname -a
Linux raspberrypi 3.12.17+ #668 PREEMPT Mon Apr 14 23:22:04 BST 2014 armv6l GNU/Linux
I'll need more details. Where does it get to? Do you get rainbow splash image? Any activity on LEDs? Do you get any kernel boot messages?
Anyone successfully updated?
Tue Apr 15, 2014 12:48 pm
I don't believe this was caused by the kernel update (it has no control over HDMI resolution). Most likely a previous firmware update.
Can you run:
sudo rpi-update e8d2ad3c208f374f1df5b059a5cb15cfccd874e1
Which is the previous 3.10 FIQ FSM firmware and report if that has the same resolution?
GrayShade
Tue Apr 15, 2014 1:03 pm
dom wrote:I'll need more details. Where does it get to? Do you get rainbow splash image? Any activity on LEDs? Do you get any kernel boot messages?
I can't give you more details because I don't have a display or a serial cable. The SD card LED blinks, then only power stays on. USB doesn't appear to get initialized and my systemd journal log stops at the previous shut down (although I don't remember being able to diagnose boot issues even from the syslog files on Raspbian).
I believe I was getting the same behavior when (because of SD card corruption issues and the fsck prompt) it wasn't able to mount the root fs, although this is hardly the only reason for a boot to fail.
tuxx
Tue Apr 15, 2014 1:04 pm
I've just ran:
and it boots fine:
$ uname -a
I just ran:
SKIP_BACKUP=1 BRANCH=next rpi-update
With regards to the leds, only the red PWR is on.
Distribution is an up to date ArchlinuxARM and unfortunately it's headless at the moment and I can't see where it's stuck. I will come back with details ASAP.
redhawk
Tue Apr 15, 2014 1:12 pm
Works fine for me too (Pi Model B rev1 with Hynix RAM)
root@raspberrypi:~# uname -a
Richard S.
Tue Apr 15, 2014 1:13 pm
Can you run:
This has happened before on another install, as stated this was a fresh install Jan 2014 Raspbian Wheezy image, not using Noobs, with no updates what-so-ever.
On a fresh install have black border all around, made no changes just ran the rpi-update and now no black borders but screen resolution is physically smaller, hence text size bigger.
I am using a HDMi Cable and a HDMi to DVi adaptor on the HannsG 4:3 Monitor.
Will try the command later and post back results
Tue Apr 15, 2014 1:47 pm
fruitoftheloom wrote:This has happened before on another install, as stated this was a fresh install Jan 2014 Raspbian Wheezy image, not using Noobs, with no updates what-so-ever.
Yes, it is likely you have a broken EDID (try tvservice -d edid.dat as see if it writes zero bytes).
We used to default to 720p60 in this case, but were advised not to by the hdmi guy here.
720p60 is not manditory, so may not work, whereas VGA is manditory, so we should use that in this case. You will need to use hdmi_group/hdmi_mode to choose a suitable resolution in this case.
Tue Apr 15, 2014 2:18 pm
Not very good to suddenly find that the options one has choosen for screen size go out of the window (pardon the pun), the only changes I needed to make was -60 on L, R, T, B and left the rest of the config.txt as standard, now will have to mess around to get the resolution to where it was.....
EDIT: Actually srenn resolution turned out easier than before update to configur now solved. No side issue from kernel update so happy.....
Last edited by fruitoftheloom on Wed Apr 16, 2014 1:47 pm, edited 1 time in total.
Tue Apr 15, 2014 3:13 pm
fruitoftheloom wrote:Not very good to suddenly find that the options one has choosen for screen size go out of the window (pardon the pun), the only changes I needed to make was -60 on L, R, T, B and left the rest of the config.txt as standard, now will have to mess around to get the resolution to where it was.....
I beleve these would be the options it was using previously:
hdmi_group=1
hdmi_mode=4
hdmi_drive= 1
But we're off topic for this thread. Create a new thread or a github firmware issue if you have more comments on this.
Tue Apr 15, 2014 3:38 pm
.........yes apologies for going off-topic, it is not a USB issue, just a side effect of updates. Thanks for pointers though !
jdb
Tue Apr 15, 2014 8:21 pm
Update:
BRANCH=next rpi-update firmware now has improvements in error handling in the case of random bus errors.
Previously over an extended period, network dropouts could occur if sufficient numbers of errors accumulated.
Rockets are loud.
fabriced
Tue Apr 15, 2014 9:40 pm
Dear,
Could you also backport this into 3.10.y-next ?
Kind regards,
Fabrice
jdb
Tue Apr 15, 2014 10:09 pm
fabriced wrote:Dear,
Kind regards,
Fabrice
Is there any reason why you can't use the 3.12 kernel?
Rockets are loud.
fabriced
Tue Apr 15, 2014 10:25 pm
I have USB issues with for example bluetooth dongles so I am expecting a lot from this new driver.
I have to thank you a lot, the system seems more stable. Bluetooth dongle has less disconnection.
But with Huawei modem, I have still issues with some models. There is no FSM trace in the syslog so I think it is more the fault of the modem, anyway I do not have usable information to give you back on this thread. But other USB devices on the hub begin to act weirdly, loadavg goes higher, etc... Sometimes I plug the modem and lost a WiFi dongle (having suddenly lots of debug traces from rt2x00), timeout on hci command to the bluetooth dongle, ...
I have some RPI that I have to deploy next week. There are running and updated continuously with your updates since the begin of this thread. I have no problem to test your fix but I am a little afraid to change of major version of the kernel, to many risk on side effect and I could not have time to manage and fix these before next week.
Tomorrow I could also watch if I can backport the commit myself on my local repo so I understand if you do not have time for this...
Wed Apr 16, 2014 2:35 pm
Kind regards,
Fabrice
I have updated rpi-3.10.y-next tree, but you will have to build yourself.
BRANCH=next builds will come from 3.12 tree.
tvjon
Wed Apr 16, 2014 6:30 pm
I've just updated to next, & run guvcview to check sound & video, & it failed to run. The only "sound card" is the eye-toy camera.
pi@ddrp3 ~ $ guvcview
guvcview 1.5.3
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4720:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
FATAL: cannot locate cpu MHz in /proc/cpuinfo
pi@ddrp3 ~ $ cat  /proc/cpuinfo
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
Features	: swp half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 100000e
Serial		: 00000000bbb8cfd3
pi@ddrp3 ~ $
dmesg:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.12.17+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #670 PREEMPT Tue Apr 15 18:15:44 BST 2014
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 98304
[    0.000000] free_area_init_node: node 0, pgdat c05faf88, node_mem_map c06ab000
[    0.000000]   Normal zone: 768 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 98304 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97536
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708.boardrev=0x100000e bcm2708.serial=0x6f9aafe0 smsc95xx.macaddr=B8:27:EB:9A:AF:E0 bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 382860K/393216K available (4372K kernel code, 230K rwdata, 1340K rodata, 143K init, 699K bss, 10356K reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xd8800000 - 0xff000000   ( 616 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd8000000   ( 384 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc059c44c   (5714 kB)
[    0.000000]       .init : 0xc059d000 - 0xc05c0c14   ( 144 kB)
[    0.000000]       .data : 0xc05c2000 - 0xc05fbaa0   ( 231 kB)
[    0.000000]        .bss : 0xc05fbaac - 0xc06aa8b8   ( 700 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Switching to timer-based delay loop
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.001270] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[    0.001333] pid_max: default: 32768 minimum: 301
[    0.001805] Mount-cache hash table entries: 512
[    0.002641] Initializing cgroup subsys memory
[    0.002748] Initializing cgroup subsys devices
[    0.002788] Initializing cgroup subsys freezer
[    0.002820] Initializing cgroup subsys blkio
[    0.002959] CPU: Testing write buffer coherency: ok
[    0.003417] Setting up static identity map for 0xc0426770 - 0xc04267cc
[    0.005268] devtmpfs: initialized
[    0.017684] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.018366] NET: Registered protocol family 16
[    0.023455] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.024119] cpuidle: using governor ladder
[    0.024169] cpuidle: using governor menu
[    0.024748] bcm2708.uart_clock = 0
[    0.026595] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.026654] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.026691] mailbox: Broadcom VideoCore Mailbox driver
[    0.026790] bcm2708_vcio: mailbox at f200b880
[    0.026899] bcm_power: Broadcom power driver
[    0.026937] bcm_power_open() -> 0
[    0.026963] bcm_power_request(0, 8)
[    0.527679] bcm_mailbox_read -> 00000080, 0
[    0.527724] bcm_power_request -> 0
[    0.527933] Serial: AMBA PL011 UART driver
[    0.528078] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[    0.892150] console [ttyAMA0] enabled
[    0.920119] bio: create slab <bio-0> at 0
[    0.925433] SCSI subsystem initialized
[    0.929431] usbcore: registered new interface driver usbfs
[    0.935128] usbcore: registered new interface driver hub
[    0.940686] usbcore: registered new device driver usb
[    0.947436] Switched to clocksource stc
[    0.951667] FS-Cache: Loaded
[    0.954822] CacheFiles: Loaded
[    0.970668] NET: Registered protocol family 2
[    0.976150] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.983556] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.990129] TCP: Hash tables configured (established 4096 bind 4096)
[    0.996578] TCP: reno registered
[    0.999877] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.005748] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.012488] NET: Registered protocol family 1
[    1.017413] RPC: Registered named UNIX socket transport module.
[    1.023477] RPC: Registered udp transport module.
[    1.028236] RPC: Registered tcp transport module.
[    1.032958] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.040480] bcm2708_dma: DMA manager at f2007000
[    1.045224] bcm2708_gpio: bcm2708_gpio_probe c05cfed0
[    1.050781] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.060427] audit: initializing netlink socket (disabled)
[    1.065915] type=2000 audit(0.900:1): initialized
[    1.231591] VFS: Disk quotas dquot_6.5.2
[    1.235859] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.244933] FS-Cache: Netfs 'nfs' registered for caching
[    1.251977] NFS: Registering the id_resolver key type
[    1.257140] Key type id_resolver registered
[    1.261457] Key type id_legacy registered
[    1.266254] msgmni has been set to 747
[    1.272242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.280091] io scheduler noop registered
[    1.284051] io scheduler deadline registered (default)
[    1.289661] io scheduler cfq registered
[    1.293892] BCM2708FB: allocated DMA memory 57970000
[    1.299040] BCM2708FB: allocated DMA channel 0 @ f2007000
[    1.330164] Console: switching to colour frame buffer device 240x67
[    1.352976] uart-pl011 dev:f1: no DMA platform data
[    1.358070] kgdb: Registered I/O driver kgdboc.
[    1.363349] vc-cma: Videocore CMA driver
[    1.367371] vc-cma: vc_cma_base      = 0x00000000
[    1.372232] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.377823] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.393578] brd: module loaded
[    1.402517] loop: module loaded
[    1.406059] vchiq: vchiq_init_state: slot_zero = 0xd8804000, is_master = 0
[    1.413935] Loading iSCSI transport class v2.0-870.
[    1.420216] usbcore: registered new interface driver smsc95xx
[    1.426355] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.632691] Core Release: 2.80a
[    1.635934] Setting default values for core params
[    1.640935] Finished setting default values for core params
[    1.846695] Using Buffer DMA mode
[    1.850134] Periodic Transfer Interrupt Enhancement - disabled
[    1.856080] Multiprocessor Interrupt Enhancement - disabled
[    1.861786] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.866234] Dedicated Tx FIFOs mode
[    1.870089] WARN::dwc_otg_hcd_init:1040: FIQ DMA bounce buffers: virt = 0xd8c20000 dma = 0x579d8000 len=9024
[    1.880164] FIQ FSM acceleration enabled for :
[    1.880164] Non-periodic Split Transactions
[    1.880164] Periodic Split Transactions
[    1.892850] dwc_otg: Microframe scheduler enabled
[    1.892908] WARN::hcd_init:473: FIQ at 0xc0307164
[    1.897827] WARN::hcd_init:474: FIQ ASM at 0xc03073e0 length 36
[    1.903870] WARN::hcd_init:500: MPHI regs_base at 0xd8c1a000
[    1.909694] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.914713] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.922157] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.927816] Init: Port Power? op_state=1
[    1.931819] Init: Power Port (0)
[    1.940149] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.951750] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.963723] usb usb1: Product: DWC OTG Controller
[    1.973143] usb usb1: Manufacturer: Linux 3.12.17+ dwc_otg_hcd
[    1.983697] usb usb1: SerialNumber: bcm2708_usb
[    1.993845] hub 1-0:1.0: USB hub found
[    2.002467] hub 1-0:1.0: 1 port detected
[    2.011729] dwc_otg: FIQ enabled
[    2.011750] dwc_otg: NAK holdoff enabled
[    2.011762] dwc_otg: FIQ split-transaction FSM enabled
[    2.011783] Module dwc_common_port init
[    2.012256] usbcore: registered new interface driver usb-storage
[    2.023562] mousedev: PS/2 mouse device common for all mice
[    2.034720] bcm2835-cpufreq: min=700000 max=1000000 cur=700000
[    2.045621] bcm2835-cpufreq: switching to governor powersave
[    2.056094] bcm2835-cpufreq: switching to governor powersave
[    2.066516] sdhci: Secure Digital Host Controller Interface driver
[    2.077376] sdhci: Copyright(c) Pierre Ossman
[    2.086422] sdhci: Enable low-latency mode
[    2.137506] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.150338] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.161155] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.173653] ledtrig-cpu: registered to indicate activity on CPUs
[    2.191872] hidraw: raw HID events driver (C) Jiri Kosina
[    2.202369] usbcore: registered new interface driver usbhid
[    2.215051] Indeed it is in host mode hprt0 = 00021501
[    2.227078] usbhid: USB HID core driver
[    2.240702] TCP: cubic registered
[    2.267472] Initializing XFRM netlink socket
[    2.276427] NET: Registered protocol family 17
[    2.307744] Key type dns_resolver registered
[    2.318629] mmc0: read SD Status register (SSR) after 2 attempts
[    2.338882] registered taskstats version 1
[    2.357565] mmc0: new high speed SDHC card at address b368
[    2.378646] Waiting for root device /dev/mmcblk0p2...
[    2.389336] mmcblk0: mmc0:b368       7.45 GiB
[    2.403466]  mmcblk0: p1 p2
[    2.517624] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.529966] Indeed it is in host mode hprt0 = 00001101
[    2.576514] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.607548] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.628976] devtmpfs: mounted
[    2.637345] Freeing unused kernel memory: 140K (c059d000 - c05c0000)
[    2.788011] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.800289] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.813317] hub 1-1:1.0: USB hub found
[    2.822266] hub 1-1:1.0: 5 ports detected
[    3.107763] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.218036] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.246251] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.270690] smsc95xx v1.0.4
[    3.342754] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:9a:af:e0
[    3.437739] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.578322] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[    3.603254] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.623931] usb 1-1.3: Product: USB 2.0 Hub
[    3.638544] hub 1-1.3:1.0: USB hub found
[    3.651224] hub 1-1.3:1.0: 4 ports detected
[    3.937753] usb 1-1.3.4: new high-speed USB device number 5 using dwc_otg
[    4.058297] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[    4.087629] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.108044] usb 1-1.3.4: Product: USB 2.0 Hub
[    4.127290] hub 1-1.3.4:1.0: USB hub found
[    4.136941] hub 1-1.3.4:1.0: 4 ports detected
[    4.432362] udevd[156]: starting version 175
[    4.442195] usb 1-1.3.4.1: new full-speed USB device number 6 using dwc_otg
[    4.620448] usb 1-1.3.4.1: New USB device found, idVendor=0a12, idProduct=0001
[    4.657252] usb 1-1.3.4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.506084] Bluetooth: Core ver 2.16
[    5.743558] NET: Registered protocol family 31
[    5.905932] Bluetooth: HCI device and connection manager initialized
[    6.033598] Bluetooth: HCI socket layer initialized
[    6.094425] Bluetooth: L2CAP socket layer initialized
[    6.237696] Bluetooth: SCO socket layer initialized
[    6.459298] usbcore: registered new interface driver btusb
[    7.059107] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[   13.663027] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   14.175772] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   20.275015] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   23.630575] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   25.140456] bcm2835-cpufreq: switching to governor ondemand
[   25.140468] bcm2835-cpufreq: switching to governor ondemand
[   25.465539] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   27.371731] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
[  107.711453] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
[  107.821925] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b
[  107.821960] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  107.821978] usb 1-1.2: Product: USB Receiver
[  107.821992] usb 1-1.2: Manufacturer: Logitech
[  107.846139] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
[  107.846560] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input0
[  107.877830] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
[  107.879063] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input1
[  107.912255] hid-generic 0003:046D:C52B.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input2
jdb
Wed Apr 16, 2014 7:26 pm
Fatal: cannot locate cpu MHz in /proc/cpuinfo
Guvcview is broken because of this line.
I have no idea why the BogoMIPS value in /proc/cpuinfo is so critical to its operation.
Edit:
This is the patch that removed BogoMIPS from /proc/cpuinfo:
http://lists.infradead.org/pipermail/li ... 78645.html
Rockets are loud.
GrayShade
Wed Apr 16, 2014 8:07 pm
FWIW, I just got this on 3.10.36+ #665 PREEMPT Wed Apr 9 15:01:53 BST 2014 armv6l GNU/Linux:
[23608.771517] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23608.780869] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23608.796173] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23613.801549] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23613.810902] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23613.821644] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23619.831525] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23619.840817] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23619.853175] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23624.861499] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23624.870923] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23624.882582] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23626.060791] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23631.101502] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23634.211489] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23635.211492] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23636.211516] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23637.111517] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23637.211499] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23638.211495] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23638.218888] hub 1-1.2:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[23639.231495] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[23640.231494] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23641.231582] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[23641.914202] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23642.141656] usb 1-1.2.3: reset high-speed USB device number 6 using dwc_otg
[23643.500172] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[23669.851521] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23669.860434] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23669.870598] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23674.871527] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23674.880589] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23674.890411] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23680.901509] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23680.910417] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23680.923180] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23685.931517] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23685.940604] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23685.950941] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23687.069257] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23692.101522] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23698.111513] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23701.954804] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23703.486228] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[23735.921521] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23735.930430] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23735.942091] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23740.941513] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23740.950433] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23740.960854] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23746.971515] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23746.980417] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23746.991039] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23752.001516] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23752.010378] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23752.025039] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23753.153534] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23758.191512] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23761.984728] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23762.021687] usb 1-1.2.3: reset high-speed USB device number 6 using dwc_otg
[23763.569529] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[23908.062967] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23908.072176] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23908.083913] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23913.092972] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23913.102158] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23913.112723] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23919.122973] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23919.132257] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23919.143159] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23924.152994] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23924.162324] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23924.174065] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23925.230922] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23930.272973] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23936.282987] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[23942.105877] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23943.694683] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[23976.758666] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23976.767605] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23976.779673] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23981.778655] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23981.787608] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23981.797836] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23987.798659] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23987.807562] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23987.818840] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23992.828659] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[23992.837517] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[23992.854535] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[23993.976922] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[23999.018654] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24002.131378] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[24003.724667] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[24080.392939] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[24080.407120] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[24080.417196] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[24085.423145] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[24085.432052] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[24085.449330] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[24091.452732] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[24091.461820] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[24091.478747] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[24096.482736] smsc95xx 1-1.1:1.0 eth0: Failed to read reg index 0x00000114: -110
[24096.499748] smsc95xx 1-1.1:1.0 eth0: Error reading MII_ACCESS
[24096.509812] smsc95xx 1-1.1:1.0 eth0: MII is busy in smsc95xx_mdio_read
[24097.641664] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[24102.682715] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24107.242713] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24108.242720] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24108.692718] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24109.242704] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24110.242714] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24111.242715] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24111.249923] hub 1-1.2:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[24112.262712] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[24113.262716] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24114.262714] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24114.702730] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24115.262715] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24116.262715] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24117.262725] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24117.269860] hub 1-1.2:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[24118.282720] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[24119.282714] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24120.282716] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24120.712729] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24121.282716] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24122.282714] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24123.282716] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24123.289943] hub 1-1.2:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[24124.292714] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[24125.292721] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24126.292721] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24126.722727] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24127.292723] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24128.292721] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24129.292721] hub 1-1.2:1.0: cannot reset port 3 (err = -110)
[24129.299702] hub 1-1.2:1.0: Cannot enable port 3.  Maybe the USB cable is bad?
[24130.312717] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[24131.312723] hub 1-1.2:1.0: cannot disable port 3 (err = -110)
[24131.320106] sd 0:0:0:0: Device offlined - not ready after error recovery
[24131.333247] sd 0:0:0:0: [sda] Unhandled error code
[24131.339509] sd 0:0:0:0: [sda]
[24131.348190] Result: hostbyte=0x05 driverbyte=0x00
[24131.355506] sd 0:0:0:0: [sda] CDB:
[24131.360392] cdb[0]=0x28: 28 00 00 91 48 20 00 00 20 00
[24131.369626] end_request: I/O error, dev sda, sector 9521184
[24131.378702] sd 0:0:0:0: rejecting I/O to offline device
[24131.385398] sd 0:0:0:0: [sda] killing request
[24131.391111] sd 0:0:0:0: rejecting I/O to offline device
[24131.397736] Buffer I/O error on device sda1, logical block 88113260
[24131.405411] EXT4-fs warning (device sda1): ext4_end_bio:286: I/O error writing to inode 22020153 (offset 0 size 4096 starting block 88113517)
[24131.420919] sd 0:0:0:0: rejecting I/O to offline device
[24131.427822] sd 0:0:0:0: [sda] Unhandled error code
[24131.434193] sd 0:0:0:0: [sda]
[24131.438785] Result: hostbyte=0x01 driverbyte=0x00
[24131.445000] sd 0:0:0:0: [sda] CDB:
[24131.450036] cdb[0]=0x2a: 2a 00 2a 04 0b 58 00 00 08 00
[24131.457067] end_request: I/O error, dev sda, sector 704908120
[24131.464350] Buffer I/O error on device sda1, logical block 88113259
[24131.472204] EXT4-fs warning (device sda1): ext4_end_bio:286: I/O error writing to inode 22020132 (offset 0 size 4096 starting block 88113516)
[24132.732733] smsc95xx 1-1.1:1.0 eth0: Failed to write reg index 0x00000014: -110
[24136.312717] hub 1-1.2:1.0: hub_port_status failed (err = -110)
[24136.565453] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[24137.183039] sd 0:0:0:0: rejecting I/O to offline device
[24137.190260] Aborting journal on device sda1-8.
[24137.199595] sd 0:0:0:0: rejecting I/O to offline device
[24137.208804] JBD2: Error -5 detected when updating journal superblock for sda1-8.
[24138.153912] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
It's a bit funny because playing sound over my USB DAC makes it hang for a while.
andrea.iob
Wed Apr 16, 2014 11:06 pm
The new kernel works, but now I hear noise on all the files I play.
The files that sounded distorted with the previous version are still distorted in the same way and for those files I get the usual "FIQ reported NYET" errors. Whereas if I play the files that sounded good with the previous version now I hear a lot of noise but I get no errors from dmesg.
I've tried to downgrade to the commit of March 19th but I get this error:
pi@volumio:~$ sudo BRANCH=next rpi-update 5a22a878a2fd5509d39d3de0c4bac0cdfd520c2d
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   135  100   135    0     0    215      0 --:--:-- --:--:-- --:--:--   280
100  7026  100  7026    0     0   8682      0 --:--:-- --:--:-- --:--:--  8682
 *** Relaunching after update
 *** Downloading specific firmware revision (this will take a few minutes)
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
gzip: stdin: not in gzip format
tar: Child died with signal 13
tar: Error is not recoverable: exiting now
This is the new dmesg:
[    0.000000] On node 0 totalpages: 126976
[    0.000000]   Normal zone: 992 pages used for memmap
[    0.000000]   Normal zone: 126976 pages, LIFO batch:31
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125984
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x3d291570 smsc95xx.macaddr=B8:27:EB:29:15:70 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1fa00000 vc_mem.mem_size=0x20000000  force_turbo=1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p3 elevator=noop rootfstype=ext4 rootwait smsc95xx.turbo_mode=N dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x7
[    0.000000] Memory: 496652K/507904K available (4372K kernel code, 230K rwdata, 1340K rodata, 143K init, 699K bss, 11252K reserved)
[    0.000000]     vmalloc : 0xdf800000 - 0xff000000   ( 504 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdf000000   ( 496 MB)
[    0.001273] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[    0.001335] pid_max: default: 32768 minimum: 301
[    0.001808] Mount-cache hash table entries: 512
[    0.002647] Initializing cgroup subsys memory
[    0.002755] Initializing cgroup subsys devices
[    0.002793] Initializing cgroup subsys freezer
[    0.002825] Initializing cgroup subsys blkio
[    0.002964] CPU: Testing write buffer coherency: ok
[    0.003427] Setting up static identity map for 0xc0426770 - 0xc04267cc
[    0.005273] devtmpfs: initialized
[    0.017850] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.018528] NET: Registered protocol family 16
[    0.023675] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.024340] cpuidle: using governor ladder
[    0.024392] cpuidle: using governor menu
[    0.025024] bcm2708.uart_clock = 0
[    0.026870] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.026930] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.026968] mailbox: Broadcom VideoCore Mailbox driver
[    0.027066] bcm2708_vcio: mailbox at f200b880
[    0.027172] bcm_power: Broadcom power driver
[    0.027211] bcm_power_open() -> 0
[    0.027237] bcm_power_request(0, 8)
[    0.527946] bcm_mailbox_read -> 00000080, 0
[    0.527990] bcm_power_request -> 0
[    0.528200] Serial: AMBA PL011 UART driver
[    0.528346] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[    0.892862] console [ttyAMA0] enabled
[    0.920900] bio: create slab <bio-0> at 0
[    0.926225] SCSI subsystem initialized
[    0.930218] usbcore: registered new interface driver usbfs
[    0.935916] usbcore: registered new interface driver hub
[    0.941475] usbcore: registered new device driver usb
[    0.948280] Switched to clocksource stc
[    0.952511] FS-Cache: Loaded
[    0.955665] CacheFiles: Loaded
[    0.971513] NET: Registered protocol family 2
[    0.977000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.984405] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.990977] TCP: Hash tables configured (established 4096 bind 4096)
[    0.997427] TCP: reno registered
[    1.000725] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.006596] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.013334] NET: Registered protocol family 1
[    1.018257] RPC: Registered named UNIX socket transport module.
[    1.024318] RPC: Registered udp transport module.
[    1.029079] RPC: Registered tcp transport module.
[    1.033800] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.041376] bcm2708_dma: DMA manager at f2007000
[    1.046120] bcm2708_gpio: bcm2708_gpio_probe c05cfed0
[    1.051673] vc-mem: phys_addr:0x00000000 mem_base=0x1fa00000 mem_size:0x20000000(512 MiB)
[    1.061323] audit: initializing netlink socket (disabled)
[    1.066811] type=2000 audit(0.900:1): initialized
[    1.232561] VFS: Disk quotas dquot_6.5.2
[    1.236835] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.245923] FS-Cache: Netfs 'nfs' registered for caching
[    1.252960] NFS: Registering the id_resolver key type
[    1.258135] Key type id_resolver registered
[    1.262455] Key type id_legacy registered
[    1.267247] msgmni has been set to 970
[    1.273229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.281076] io scheduler noop registered (default)
[    1.285906] io scheduler deadline registered
[    1.290653] io scheduler cfq registered
[    1.294879] BCM2708FB: allocated DMA memory 5e970000
[    1.300024] BCM2708FB: allocated DMA channel 0 @ f2007000
[    1.324222] Console: switching to colour frame buffer device 82x26
[    1.334374] uart-pl011 dev:f1: no DMA platform data
[    1.340807] kgdb: Registered I/O driver kgdboc.
[    1.347337] vc-cma: Videocore CMA driver
[    1.352670] vc-cma: vc_cma_base      = 0x00000000
[    1.358734] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.365380] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.381833] brd: module loaded
[    1.391653] loop: module loaded
[    1.396297] vchiq: vchiq_init_state: slot_zero = 0xdf804000, is_master = 0
[    1.405182] Loading iSCSI transport class v2.0-870.
[    1.412499] usbcore: registered new interface driver smsc95xx
[    1.419742] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.626870] Core Release: 2.80a
[    1.631346] Setting default values for core params
[    1.637350] Finished setting default values for core params
[    1.844275] Using Buffer DMA mode
[    1.848849] Periodic Transfer Interrupt Enhancement - disabled
[    1.855923] Multiprocessor Interrupt Enhancement - disabled
[    1.862754] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.868410] Dedicated Tx FIFOs mode
[    1.873346] WARN::dwc_otg_hcd_init:1040: FIQ DMA bounce buffers: virt = 0xdfc20000 dma = 0x5e9b0000 len=9024
[    1.885768] FIQ FSM acceleration enabled for :
[    1.885768] Non-periodic Split Transactions
[    1.885768] Periodic Split Transactions
[    1.885768] High-Speed Isochronous Endpoints
[    1.907653] dwc_otg: Microframe scheduler enabled
[    1.907711] WARN::hcd_init:473: FIQ at 0xc0307164
[    1.913804] WARN::hcd_init:474: FIQ ASM at 0xc03073e0 length 36
[    1.921126] WARN::hcd_init:500: MPHI regs_base at 0xdfc1a000
[    1.928117] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.934371] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.943019] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.949886] Init: Port Power? op_state=1
[    1.955091] Init: Power Port (0)
[    1.959859] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.967980] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.976550] usb usb1: Product: DWC OTG Controller
[    1.982580] usb usb1: Manufacturer: Linux 3.12.17+ dwc_otg_hcd
[    1.989743] usb usb1: SerialNumber: bcm2708_usb
[    1.996396] hub 1-0:1.0: USB hub found
[    2.001593] hub 1-0:1.0: 1 port detected
[    2.007232] dwc_otg: FIQ enabled
[    2.007250] dwc_otg: NAK holdoff enabled
[    2.007260] dwc_otg: FIQ split-transaction FSM enabled
[    2.007278] Module dwc_common_port init
[    2.007709] usbcore: registered new interface driver usb-storage
[    2.015439] mousedev: PS/2 mouse device common for all mice
[    2.023039] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    2.030270] bcm2835-cpufreq: switching to governor powersave
[    2.037189] bcm2835-cpufreq: switching to governor powersave
[    2.044176] sdhci: Secure Digital Host Controller Interface driver
[    2.051638] sdhci: Copyright(c) Pierre Ossman
[    2.057301] sdhci: Enable low-latency mode
[    2.108340] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.118881] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.126126] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.133303] ledtrig-cpu: registered to indicate activity on CPUs
[    2.142945] hidraw: raw HID events driver (C) Jiri Kosina
[    2.157308] usbcore: registered new interface driver usbhid
[    2.164386] usbhid: USB HID core driver
[    2.174293] TCP: cubic registered
[    2.181070] Initializing XFRM netlink socket
[    2.188795] NET: Registered protocol family 17
[    2.194816] Key type dns_resolver registered
[    2.203886] Indeed it is in host mode hprt0 = 00021501
[    2.215057] registered taskstats version 1
[    2.229494] Waiting for root device /dev/mmcblk0p3...
[    2.268372] mmc0: new high speed SDHC card at address aaaa
[    2.275852] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    2.289899]  mmcblk0: p1 p3
[    2.353904] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[    2.365100] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    2.383239] devtmpfs: mounted
[    2.388101] Freeing unused kernel memory: 140K (c059d000 - c05c0000)
[    2.418429] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.427250] Indeed it is in host mode hprt0 = 00001101
[    2.628734] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.637301] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.647525] hub 1-1:1.0: USB hub found
[    2.652981] hub 1-1:1.0: 3 ports detected
[    2.938568] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.048849] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.057674] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.069620] smsc95xx v1.0.4
[    3.133786] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:29:15:70
[    3.258572] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.390238] usb 1-1.2: New USB device found, idVendor=0b05, idProduct=17ab
[    3.399474] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.408578] usb 1-1.2: Product: 802.11n WLAN Adapter
[    3.415125] usb 1-1.2: Manufacturer: Realtek
[    3.421016] usb 1-1.2: SerialNumber: 00e04c000001
[    3.528580] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[    3.660184] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
[    3.678473] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.687386] usb 1-1.3: Product: USB2.0 Hub
[    3.707987] hub 1-1.3:1.0: USB hub found
[    3.718939] hub 1-1.3:1.0: 4 ports detected
[    4.008791] usb 1-1.3.1: new high-speed USB device number 6 using dwc_otg
[    4.078562] udevd[156]: starting version 175
[    4.580726] usb 1-1.3.1: New USB device found, idVendor=090c, idProduct=1000
[    4.603647] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.635859] usb 1-1.3.1: Product: USB DISK
[    4.658451] usb 1-1.3.1: Manufacturer: SMI Corporation
[    4.679299] usb-storage 1-1.3.1:1.0: USB Mass Storage device detected
[    4.708144] scsi0 : usb-storage 1-1.3.1:1.0
[    4.798792] usb 1-1.3.3: new high-speed USB device number 7 using dwc_otg
[    4.919789] usb 1-1.3.3: New USB device found, idVendor=1058, idProduct=0704
[    4.936621] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.973723] usb 1-1.3.3: Product: External HDD
[    4.995683] usb 1-1.3.3: Manufacturer: Western Digital
[    5.004141] bcm2708_i2c_init_pinmode(0,0)
[    5.013856] usb 1-1.3.3: SerialNumber: 575843363038413039313933
[    5.031356] usb-storage 1-1.3.3:1.0: USB Mass Storage device detected
[    5.052043] usb-storage 1-1.3.3:1.0: Quirks match for vid 1058 pid 0704: 8000
[    5.068734] scsi1 : usb-storage 1-1.3.3:1.0
[    5.108447] bcm2708_i2c_init_pinmode(0,1)
[    5.114434] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[    5.158897] usb 1-1.3.4: new full-speed USB device number 8 using dwc_otg
[    5.290003] usb 1-1.3.4: New USB device found, idVendor=4852, idProduct=0006
[    5.306234] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.328469] usb 1-1.3.4: Product: Music Streamer II+
[    5.335178] usb 1-1.3.4: Manufacturer: www.hirestech.com 2013 REV 3.0
[    5.358240] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[    5.381269] hid-generic 0003:4852:0006.0001: hiddev0,hidraw0: USB HID v1.00 Device [www.hirestech.com 2013 REV 3.0 Music Streamer II+] on usb-bcm2708_usb-1.3.4/input2
[    5.420279] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[    5.627647] bcm2708_i2c_init_pinmode(1,2)
[    5.662718] bcm2708_i2c_init_pinmode(1,3)
[    5.759383] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[    5.821283] scsi 0:0:0:0: Direct-Access     SMI      USB DISK         1100 PQ: 0 ANSI: 0 CCS
[    5.845565] sd 0:0:0:0: [sda] 3932160 512-byte logical blocks: (2.01 GB/1.87 GiB)
[    5.866577] sd 0:0:0:0: [sda] Write Protect is off
[    5.879783] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    5.880644] sd 0:0:0:0: [sda] No Caching mode page found
[    5.887689] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.921095] sd 0:0:0:0: [sda] No Caching mode page found
[    5.928094] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.949792]  sda: sda1
[    5.963082] sd 0:0:0:0: [sda] No Caching mode page found
[    5.976350] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.992893] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.069406] scsi 1:0:0:0: Direct-Access     WD       2500BEV External 1.05 PQ: 0 ANSI: 4
[    6.098050] sd 1:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[    6.118794] sd 1:0:0:0: [sdb] Write Protect is off
[    6.125256] sd 1:0:0:0: [sdb] Mode Sense: 21 00 00 00
[    6.137574] sd 1:0:0:0: [sdb] No Caching mode page found
[    6.148444] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    6.164155] sd 1:0:0:0: [sdb] No Caching mode page found
[    6.178460] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    6.232516]  sdb: sdb1
[    6.243438] sd 1:0:0:0: [sdb] No Caching mode page found
[    6.258445] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    6.266021] sd 1:0:0:0: [sdb] Attached SCSI disk
[    6.579959] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[    7.463375] usbcore: registered new interface driver rtl8192cu
[    7.546375] pcm512x 1-004c: Failed to reset device: -5
[    7.618566] pcm512x: probe of 1-004c failed with error -5
[    7.708747] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.744155] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    7.961736] usbcore: registered new interface driver snd-usb-audio
[    9.202641] FAT-fs (sda1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[    9.257654] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   14.047506] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[   14.084656] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   16.548672] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[   16.991111] EXT4-fs (mmcblk0p3): Mount option "nouser_xattr" will be removed by 3.5
[   16.991111] Contact linux-ext4@vger.kernel.org if you think we should keep it.
[   16.991111]
[   17.016232] EXT4-fs (mmcblk0p3): re-mounted. Opts: nouser_xattr,errors=remount-ro
[   22.659902] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   25.205178] NET: Registered protocol family 10
[   25.774860] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.925982] ip_tables: (C) 2000-2006 Netfilter Core Team
[   26.026617] nf_conntrack version 0.5.0 (7762 buckets, 31048 max)
[   26.323538] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   26.333114] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   28.111015] smsc95xx 1-1.1:1.0 eth0: link up, 10Mbps, half-duplex, lpa 0x4021
[   28.122906] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   33.637095] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   39.715708] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   66.819895] bcm2835-cpufreq: switching to governor performance
[   66.828785] bcm2835-cpufreq: switching to governor performance
[  113.195837] usb 1-1.2: USB disconnect, device number 4
[  113.204848] rtw_cmd_thread: DriverStopped(1) SurpriseRemoved(1) break at line 482
[  630.468984] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.500984] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.532983] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.596980] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.660994] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.724988] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  630.852978] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  631.108976] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  631.172975] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  631.204983] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.620997] dwc_otg_hcd_handle_hc_fsm: 92 callbacks suppressed
[  635.630218] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.652992] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.716988] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.812987] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.844990] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.876988] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  635.972988] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  636.004991] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  636.036990] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  636.068991] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.677010] dwc_otg_hcd_handle_hc_fsm: 93 callbacks suppressed
[  640.686277] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.709003] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.741004] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.773003] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.869004] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.901008] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.933009] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.965008] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  640.997008] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  641.029003] Transfer to device 8 endpoint 0x2 failed - FIQ reported NYET. Data may have been lost.
[  645.733014] dwc_otg_hcd_handle_hc_fsm: 104 callbacks suppressed
