ergerodr
Connecting to eduroam wifi network
Fri Sep 05, 2014 6:21 pm
I am attempting to connect to my university's eduroam network using a wpa_supplicant.conf file but can't seem to get it to work properly. I am on raspbian GNU/Linux 7 and I am using the EDIMAX EW-7811Un wifi adapter.
Straight from my university's website, I need to configure my device using these settings:
- Security: WPA2 Enterprise / 802.1xEAP
- EAP method: PEAP
- Phase 2 authentication: MSCHAPV2
- Download CA certificate
- Identity (username):
- Anonymous Identity:
- Password:
I have used the following two guides
Guide1: http://www.savagehomeautomation.com/pro ... dapte.html
Guide2: http://www.willprice.org/2014/03/17/edu ... ry-pi.html
to create the wpa_supplicant file which looks as follows.
network={
identity="my_identity"
password="my_password"
ca_cert="/etc/ssl/certs/my-cert-name"
eap=PEAP
anonymous_identity="anonymous@my_uni.edu"
phase2="auth=MSCHAPV2"
priority=999
disabled=0
ssid="eduroam"
scan_ssid=0
mode=0
auth_alg=OPEN
proto=WPA RSN
pairwise=CCMP TKIP
key_mgmt=WPA-EAP
proactive_key_caching=1
when I run wpa supplicant with the command "sudo wpa_supplicant -i wlan0 -c /path/to/wpa_supplicant.conf -B" I get the following error messages.
rfkill: cannot open RFKILL control device
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: invalid argument
What exactly does this mean and what can I do to fix it? I am at a loss.
Andresen
Re: Connecting to eduroam wifi network
Mon Oct 06, 2014 11:37 pm
Hi ergerodr
Have you tried to change the line:
proto=WPA RSN
to:
proto=WPA2
If that does not solve it, try to put this in your /etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
and then use
wpa_gui
to configure wpa_supplicant.
Regards,
Andresen
jm3220
Tue Oct 07, 2014 2:27 pm
Some eduroam sites have set up an automatic configuration tool for a variety of operating systems including Linux. See https://cat.eduroam.org/ for a list of Universities that have done this.
The Linux version downloads a shell script to configure various settings for specific institutions. I don't know if this will work with your o/s, but even if it doesn't, the script may give you some pointers as to how the config files should look.
Hope this is of some use.
Sruc
Fri Mar 31, 2017 9:57 am
A bit late to respond, but here's how I connected to eduroam, in case anyone finds this. Add this lines of code to /etc/wpa_supplicant/wpa_supplicant.conf:
network={
        ssid="eduroam"
        scan_ssid=1
        key_mgmt=WPA-EAP
        eap=PEAP
        identity="youridentity@youridentitydomain"
        password="yourpassword"
        phase1="peaplabel=0"
Substitute youridentity with your student username and youridentitydomain with the domain used by your university group of users (mine was @student.[universitydomain].edu). Substitute yourpassword with your university password.
hannespi
Sun Apr 30, 2017 12:09 pm
Hej,
I study in Umeå, a University which makes it extremely difficult to install eduroam, even on Win/Mac.
For Ubuntu there is a tutorial online:
http://support.its.umu.se/entry.jspa?ex ... goryID=251
but it doesn't work for Raspbian (Pixel) as I can't get the GUI-promt...
The settings above didn't work for me either, I think there are more certificates than usual, but I'm really no expert in this. Do you find a solution from what they use in the Ubuntu tutorial?
hannespi
Thu May 04, 2017 6:16 pm
No idea? :/ Then I guess I stick to the cable.. :lol:
lbiemans
Fri Oct 11, 2019 1:36 pm
I know this thread is from a couple of years ago but today I fixed it and so I guess maybe a reply helps others :-).
What I did is install the latest version of Raspbian and run the following commands:
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 7638D0442B90D010
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 04EE7237B7D453EC
echo "deb http://deb.debian.org/debian sid main" >> /etc/apt/sources.list.d/sid.list
echo "deb-src http://deb.debian.org/debian sid main" >> /etc/apt/sources.list.d/sid.list
echo "Package: *" >> /etc/apt/preferences
echo "Pin: release n=sid" >> /etc/apt/preferences
echo "Pin-Priority: 400" >> /etc/apt/preferences
apt clean && apt update
apt install -t sid wpasupplicant
If the above command complains try apt install -f.
Run wpa_supplicant -v to see if you have the new version. (In my case v2.9).
Edit your /etc/wpa_supplicant/wpa_supplicant.conf to look something like:
update_config=1
network={
ssid="eduroam"
scan_ssid=1
key_mgmt=WPA-EAP
eap=PEAP TTLS
identity="foo@bar.biz"
anonymous_identity="noreply@bar.biz"
password="YOURSUPERSECRETPASSWORD"
ca_cert="/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_CA.crt"
impaidk
Wed Dec 18, 2019 3:00 pm
Why did you run the above commands?
