[ 369.412007] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W) dump-ftrace-buffer(Z)
Then I found out, that merely touching some pins with my finger generated the same error. I suspect it's one of the serial pins. Either GPIO 14 (TXD) or GPIO 15 (RXD), "but I can't quite put my finger on it" if you'll pardon the pun. If I'm stressing it a bit and generate a reasonable amount of errors, I'm being logged out, making LXDE seem to crash. Logging back in, the CPU bar in the bottom-right is filled up. 'top' however, shows 10-15% CPU for Xorg at most. Only a reboot calms everything down.
I'm running the april release of Debian, updated with Hexxeh's updater. Any ideas?
