nravanelli
Tontec touchscreen help!!!
Fri Jan 23, 2015 4:02 pm
Hi all,
I have followed the directions as posted here: http://engineering-diy.blogspot.ca/2013 ... creen.html
However... This step is not working for me:
After this step you should run xinput_calibrator(from Xserver terminal console: first startx then open console and then run it).
xinput_calibrator
I keep getting Error: no calibratable devices found.
WHY??? I have it plugged in via USB...
pluggy
Re: Tontec touchscreen help!!!
Fri Jan 23, 2015 4:40 pm
Since the first step in the tutorial is to run lsusb, perhaps you doing that and posting the output would be a start...
nravanelli
Fri Jan 23, 2015 4:42 pm
it shows up: Bus 001 Device 007: ID 0eef:0001 D-WAV Scientific Co., Ltd eGalax TouchScreen
asavah
Fri Jan 23, 2015 6:15 pm
Did you build the kernel with eGalax touchscreen support enabled as stated in that post?
nravanelli
Fri Jan 23, 2015 6:18 pm
Frig. I am an uber idiot. I will start from the beginning. I figured if I just did as stipulated after Raspberry Pi I would be O.K..... Boy am I wrong.
