Si3Ste
Full config.txt options for RPi2 with default value
Fri Feb 13, 2015 3:44 pm
I am looking for all default values for parameters of RPi 2.
Got it for RPI 1 here :
http://www.raspberrypi.org/documentatio ... fig-txt.md
but can't find for RPi 2. for exemple, I can't find default value of gpu_freq for RPi2.
expandables
Re: Full config.txt options for RPi2 with default value
Fri Feb 13, 2015 4:14 pm
The gpu of the raspberry pi 2 is the same as the B+ so the gpu_freq is still 250
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
jdb
Fri Feb 13, 2015 7:44 pm
The options for Pi2 are exactly the same. Note that a future firmware update will allow a single config.txt to specify options for a Pi2 *and* a Pi1 independently.
The only changes are to the default settings - on Pi 2 arm_freq is 900MHz by default and sdram_freq is 450MHz by default.
Rockets are loud.
https://astro-pi.org
sbp
Thu Feb 19, 2015 1:59 pm
jdb wrote: Note that a future firmware update will allow a single config.txt to specify options for a Pi2 *and* a Pi1 independently.
Thanks for the info, will this allow us to have two different initramfs one for RPI2 and another for all the "older" RPi's?
And then a common field in cmdline.txt like: "initramfs initramfs.gz followkernel" should load both the initramfs at the correct place?
Could you please give an indication whether this change is coming anytime soon?
Steen
piCorePlayer webpage: https://sites.google.com/site/picoreplayer/home
