Nickcn
deleted
Sat Mar 05, 2016 9:02 pm
deleted
GTR2Fan
Re: New to Pi, and my Pi 3 setup
Sat Mar 05, 2016 10:17 pm
DirkS
Sat Mar 05, 2016 10:24 pm
I like your desktop background.
Did you make a backup of your SD card yet?
It would be a shame if you had to do it all over again...
sudo modprobe snd_bcm2835
sudo amixer cset numid=3 1
I think that you can get rid of the first line here is you enable sound in the Raspi config utility (Menu / preferences).
Sat Mar 05, 2016 10:30 pm
Just one point max_usb_current=1 is actually the default for new install of Raspbian Jessie on a RPi 3B ;)
Nickcn
Sat Mar 05, 2016 10:33 pm
deleted
GTR2Fan
Sat Mar 05, 2016 10:39 pm
QBall1977
Re: (optimized Pi 3)New to Pi, and my Pi 3 setup
Mon Mar 07, 2016 12:52 am
I always learn stuff from reading these posts.
I have done similar, but am currently annoying my wife with XScreensaver, messing with MyPaint, Scribus and Audacious.
Can you get sound via BT when using OMXPlayer as it won't play to USB Speaker! Boo.
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
Nickcn
Mon Mar 07, 2016 3:01 am
deleted
gkreidl
Re: My Pi3 optimized and overclocked
Mon Mar 28, 2016 6:42 am
oxmplayer sends audio directly to the hardware, so there is not support for USB/Bluetooth or whatever additional audio.
It might work with a hardware accelerated version of VLC (but I haven't tried it yet).
viewtopic.php?f=66&t=59814
Minimal Kiosk Browser (kweb)
Nickcn
Mon Mar 28, 2016 3:40 pm
deleted.
Whiznot
Re: My Desktop Pi3 fan cooled, optimized and overclocked
Wed Apr 06, 2016 7:35 pm
Very interesting post, Nickcn.
I'm running Raspbian Jessee on a RP3. Today I went from a plastic case and a aluminum heatsink to a Flirc case. The Flirc case lowered idle temps from 54 degrees to 39 degrees. I think my passive setup with the Flirc case is good enough to give your overclock a go but I'm hesitant.
Nickcn
Wed Apr 06, 2016 7:40 pm
deleted
bananapeal
Re: Pi3 fan cooled, optimized and overclocked
Thu Apr 14, 2016 3:55 am
Hello
your sdbench.sh continually says must be run as root even though i am sudoing.
pi@raspberrypi:~ $ sudo ./sdbench.sh
./sdbench.sh: 9: [: root: unexpected operator
Must be run as root!
might you all know why this happens? i've chmoded to 777 just in case and still no go.
Nickcn
Thu Apr 14, 2016 2:38 pm
deleted
