Try updating:Max wrote:Seems your "rootwait" parameter is being ignored, as with that enabled it is supposed to wait an eternity for the device to appear, instead of 2 seconds.bleep42 wrote:Code: Select all
coherent_pool=2M cma=2M smsc95xx.turbo_mode=N dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/sda2 rootfstype=ext4 elevator=deadline rootwait
Try if it works better if you move it before your other parameters, to make sure there is not some kind of character limit truncating the cmdline.txt parameters.
sudo rpi-update d27ca5e5f1c3a94a0a1311e4c0dd86644f0acacc
