VascoFerraz
Predicable names on stretch are confusing me
Mon Oct 02, 2017 11:13 am
I made a fresh stretch install on a RPi-3.
Shouldn't I get something like enx000 or wlx000 instead of eth0, wlan0 and wlan1?
/etc/network/interfaces is empty.
If I do: sudo ifdown wlan0
I get: ifdown: unknown interface wlan0
Vasco Ferraz
SurferTim
Re: Predicable names on stretch are confusing me
Mon Oct 02, 2017 11:17 am
The newest version of Stretch (2017-09-07) uses the "old" names. The earlier version uses the predictable names.
You can change that with rpi-config. After running update and upgrade, run raspi-config and select 7 and then A7.
With Stretch, ifup and ifdown no longer work. Use these:
sudo ip link set wlan0 up
sudo ip link set wlan0 down
My advice applies to RaspiOS only. Please mention if you use another OS.
B.Goode
Mon Oct 02, 2017 11:19 am
At the time of writing on 2 October 2017 there have been two releases of Raspbian Stretch. The first had Predictable Interface Names enabled by default. The second, current release has Predictable Interface Names disabled.
VascoFerraz
Mon Oct 02, 2017 11:31 am
Thank you so much for both replies.
For further reference I downloaded and installed the image yesterday (1st of October).
Version: September 2017
Release date: 2017-09-07
Kernel version: 4.9
SHA-256: a64d742bc525b548f0435581fac5876b50a4e9ba1d1cd6433358b4ab6c7a770b
Vasco Ferraz
VascoFerraz
Mon Oct 02, 2017 11:40 am
Second question :)
With your help, I realised that I have the old scheme name interface but the "75-persistent-net-generator.rules" file missing.
I copied the file from a running Jessie version into "/lib/udev/rules.d", added the "wlanx" to the white list...
...but the "70-persistent-net.rules" didn't show at "/etc/udev/rules.d".
What am I missing?
Vasco Ferraz
Mon Oct 02, 2017 9:07 pm
sudo raspi-config advanced menu has a switch for old names versus predictable names. All of my raspberries are using predictable names.
VascoFerraz
Tue Oct 03, 2017 11:20 am
I installed the version with predictable names enabled by default but the "75-persistent-net-generator.rules" file is still missing.
"/etc/network/interfaces" is empty.
I only added my network to the "/etc/wpa_supplicant/wpa_supplicant.conf"
Installed, samba, changed default ssh ports, edited fstab... and everything works as expected.
I am not sure if this is a bug or a feature.
Vasco Ferraz
ShiftPlusOne
Tue Oct 03, 2017 11:38 am
What's the problem exactly?
"75-persistent-net-generator.rules" is from Jessie, not Stretch.
/etc/network/interfaces should be empty if you're using dhcpcd
VascoFerraz
Wed Oct 04, 2017 8:33 am
I have two wlan cards and I want to make sure that wlan0 is fixed for IP x.x.x.x and MAC aa:aa:aa:aa:aa:aa and wlan1 is fixed for IP y.y.y.y and MAC bb:bb:bb:bb:bb:bb
On Jessie I used "75-persistent-net-generator.rules" and "70-persistent-net.rules for that.
On Stretch I don't know how to do it.
Vasco Ferraz
ShiftPlusOne
Wed Oct 04, 2017 9:58 am
It works a bit differently on stretch.
In raspi-config, enable predictable interface names, under advanced options.
Read up on it here:
https://www.freedesktop.org/wiki/Softwa ... faceNames/
If that doesn't suit your needs, you can try disabling it and copying the old persistent interface names udev rules in from Jessie.
VascoFerraz
Wed Oct 04, 2017 10:40 am
Read up on it here:
Vasco Ferraz
VascoFerraz
Wed Oct 04, 2017 10:46 am
I have predicables names enabled but wlan0 is still using old name scheme?!
What am I missing?
Vasco Ferraz
ShiftPlusOne
Wed Oct 04, 2017 12:45 pm
It looks like the predictable names don't apply to the onboard wifi, so it should always come up as wlan0. Off the top of my head, I don't know why. Possibly because it's connected via SDIO rather than USB.
SurferTim
Wed Oct 04, 2017 12:49 pm
Just to add to the conversation: It doesn't always come up as wlan0 if you don't use predictable names. If you have a usb wireless dongle connected, the onboard wifi occasionally comes up as wlan1.
ShiftPlusOne
Wed Oct 04, 2017 1:07 pm
*sigh*... lovely.
Perhaps it's time to look into why the predictable interface names don't apply to onboard wifi and fix it then.
SurferTim
Wed Oct 04, 2017 1:11 pm
If you use predictable names, the onboard wifi always comes up as wlan0. The usb dongle will come up with the wlx12345 name. i like the new raspi-config option of changing the interface naming scheme. Now I have an option if I am using two wifi interfaces.
ShiftPlusOne
Wed Oct 04, 2017 1:19 pm
Ah sorry, I misread. I thought you said that onboard wifi sometimes comes up at wlan1 even with predictable names enabled.
SurferTim
Wed Oct 04, 2017 1:34 pm
That is exactly why I wanted to make that clear. Stretch has been a network challenge. I use two wifi interfaces now and then, and how they are set up are different, since you can't assign different wpa_supplicant.conf files in /etc/network/interfaces. Now you must name the wpa_supplicant.conf files with the network name appended, like
/etc/wpa_supplicant/wpa_supplicant-wlan0.conf
/etc/wpa_supplicant/wpa_supplicant-wlx12345.conf
Fri Oct 06, 2017 8:38 pm
That's not true.
These three Raspberries 3Bs have on-board WiFi
** Challenger**
wlxb827ebd88739  UP             192.168.1.29/24
** Endeavour **
wlxb827ebfbcc71  UP             192.168.1.31/24
** Intrepid  **
wlxb827eb404ca4  UP             192.168.1.19/24
SurferTim
Fri Oct 06, 2017 8:44 pm
Ok, then I meant mine always comes up as wlan0. Stretch 2017-09-07
Fri Oct 06, 2017 10:10 pm
Did you migrate from Jessie to Stretch. If you did you need to find any systemd file that's involved with disabling predictable names in Jessie.
sudo rm /etc/systemd/network/99-default.link /lib/systemd/network/99-default.link
SurferTim
Fri Oct 06, 2017 10:25 pm
No. Fresh install.
Just out of curiosity, why doesn't the wlan0 interface come up with a predictable name? The ethernet interface comes up with the enx<mac address> name. Shouldn't the onboard wireless do that also?
Edit: I'll start watching for mac addresses on the wireless interface to insure the onboard wlan is booting up as wlan0.
Martin Frezman
Fri Oct 06, 2017 10:39 pm
The Orwellian naming scheme only affects USB devices.
eth0 is a USB device (even though it is "on-board').
The on-board wireless (on the 3B or the 0W) isn't.
Fri Oct 06, 2017 10:49 pm
Which version of Stretch? 2017-09-07 Stretch with apt update && apt -y dist-upgrade with predictable names enabled using the updated raspi-config works for me.
SurferTim
Fri Oct 06, 2017 11:23 pm
Thanks for the info, but mine is still showing wlan0. Stretch 2017-09-07 with update upgrade and dist-upgrade. I also enabled predictable interface names with the new raspi-config.
