Johnholmes
Debian based barebones server
Thu Oct 18, 2012 3:41 pm
Is there any (or is someone willing to do) barebone server installation for raspberry with only bash terminal/ssh access (u/p: pi : raspberry), crontab, nano, basic logging and networking and programs + apt-get?
I'd like to use my 256mb memory version as server with only minimal amount of memory for graphics. Any programs I would install using the apt-get. It would be great if it could be installed to usb-drive (without sd-card) and it would use the whole drive capacity..
I
Johnholmes
Re: Debian based barebones server
Thu Oct 18, 2012 4:17 pm
Actually, why not base it to raspbian wheezy :P ... and oh it should handle netfilter (for iptables based firewalling)
Anyway, is there someone who could do this?
RaTTuS
Thu Oct 18, 2012 4:21 pm
you have to boot from the SD card - there is no way around that
you can move the root FS to a USB hard disk if you want
there are a couple of threads about what you can remove from an installation
Covfefe
milhouse
Thu Oct 18, 2012 4:31 pm
If you boot Raspbian Wheezy, then execute the following commands as root to remove all the desktop GUI/X11 programs and associated services:
apt-get update
# Remove libx11-6 to remove x11 and all dependent packages (anything GUI related, basically)
apt-get remove libx11-6 libgtk-3-common xkb-data lxde-icon-theme raspberrypi-artwork penguinspuzzle
# Clean up redundant packages
apt-get autoremove
# Purge config files for removed packages
dpkg -l | awk '/^rc/ {print $2}' | xargs dpkg --purge
You'll be left with a paired down installation suitable as a server, but still with dev tools and various scripting languages (Python etc.). Remove the scripting languages if you don't want those too.
bantu
Thu Oct 18, 2012 4:41 pm
@milhouse: Use "apt-get purge" instead of "apt-get remove" to also remove the config files.
apt-get wrote:Commands:
remove - Remove packages
purge - Remove packages and config files
Johnholmes
Thu Oct 18, 2012 5:16 pm
Ahh! Excellent! Thank you!
How can I set the memory usage so that there is only bare minimum used for the graphics?
milhouse
Thu Oct 18, 2012 5:35 pm
bantu wrote:@milhouse: Use "apt-get purge" instead of "apt-get remove" to also remove the config files.
Ah yes, I realised that after I had removed the packages and then purge had no effect, hence my workaround. Should remember to use purge in future! :)
milhouse
Thu Oct 18, 2012 5:38 pm
Johnholmes wrote: How can I set the memory usage so that there is only bare minimum used for the graphics?
You need to copy the required memory split file to start.elf, eg. arm240_start.elf would give you 240MB RAM with 16MB for the GPU (don't think you can go any lower than 16MB).
gdonald
Sun Dec 16, 2012 8:06 am
Or the even shorter
dpkg -P
