When I first tried using the dht11 overlay a while back, I had some difficulty getting it to work with a DHT22. I needed to set up some temperature sensors and so thought I would try again and it appears to work OK now with a DHT22. I am having one issue and that is what I think are conflicts with the system writes to the data storage location and my software's reads. I get two different error messages back from a cat of the storage location or the sensor value:
pi@localhost:/sys/bus/iio/devices/iio:device0 $ cat in_temp_input
cat: in_temp_input: Input/output error
pi@l ocalhost:/sys/bus/iio/devices/iio:device0 $ cat in_temp_input
cat: in_temp_input: Connection timed out
27000
27000
Is there some sort of file locking mechanism or do I just have to put up with the occasional failed read?
I have hunted around for documentation and code for the overlay but have not found anything. Is the code for the overlay public? There must be some more documentation somewhere because I had the location of the data in my notes from long ago but I can't find it anywhere other than in forum posts now.
Re: dtoverlay=dht11?
The "protocol" used by the DHT sensors is a bit tedious. They respond with a variable-length pulse-position modulated signal that has quite a small timebase - 20uS - and the Pi sometimes misses these pulses resulting in a failed decode.
A while ago I did try submitting an upstream patch that increased decoding reliability somewhat, but after a couple of weeks back-and-forth with the maintainers of the relevant kernel driver(s) it didn't get accepted.
I would suggest repeatedly reading the sensor value at a 2-second interval and discarding any IO errors. The returned data word is protected by a CRC so this practically guarantees that any read result that does not have an IO error is the value the sensor reported.
Rockets are loud.
https://astro-pi.org
The DHTxx series use a simple checksum rather than a CRC.
For a reliable reader try http://abyz.me.uk/rpi/pigpio/examples.html#pdif2_DHTXXD
So I've been reading the file every few minutes and if I get an exception I wait 400ms and read it again. I do 5 attempts this way and if I don't get good data I move on. Should I spread out the interval to 2 seconds? Does reading the data file trigger a read of the device?jdb wrote: ↑Sat Aug 11, 2018 8:58 pmI would suggest repeatedly reading the sensor value at a 2-second interval and discarding any IO errors. The returned data word is protected by a CRC so this practically guarantees that any read result that does not have an IO error is the value the sensor reported.
I haven't been able find any documentation on this overlay other than how to enable it so I really don't know how it works.
These sensors are on Pi 1Bs. Do you think it would work better on faster Pis?
Thanks Joan, I looked at your code and I and have written a C program using the pigpio library that works pretty well too. I used Java for the program I'm working on because I wanted to send some emails on temperature readings and that is really easy to write in Java (and I know it pretty well). Reading a file location for the temperature/humidity is pretty simple as well.joan wrote: ↑Sat Aug 11, 2018 9:11 pmThe DHTxx series use a simple checksum rather than a CRC.
