neal1 wrote: ↑Sun Aug 16, 2020 4:08 am
Tested, It worked It worked, but didn;t completely solved the issue
1st step didn't did anything
Second brought back icons
Third made them disappear again
and last command brought back all icons.
When when i boot image again icons disappeared again, and i needed to use same accomand to bring icons back.
pi@raspberrypi:~ $ sudo update-icon-caches /usr/share/icons/*
pi@raspberrypi:~ $ lxpanelctl restart
pi@raspberrypi:~ $ openbox --restart
pi@raspberrypi:~ $ killall pcmanfm lxpanel
pi@raspberrypi:~ $ pcmanfm --desktop --profile LXDE-pi &>/dev/null &
[1] 800
pi@raspberrypi:~ $ lxpanel --profile LXDE-pi &
[2] 810
pi@raspberrypi:~ $ ** Message: 19:35:53.375: x-terminal-emulator has very limited support, consider choose another terminal
grep: /home/pi/.config/lxpanel/LXDE-pi/panels/*: No such file or directory
** Message: 19:35:53.669: Connecting ...
** Message: 19:35:53.670: Status changed to down
xrandr: Failed to get size of gamma for output default
Unit pt-device-manager.service could not be found.
** (lxpanel:810): WARNING **: 19:35:53.799: Battery 0 not found
(lxpanel:810): GLib-GObject-WARNING **: 19:35:53.803: invalid (NULL) pointer instance
(lxpanel:810): GLib-GObject-CRITICAL **: 19:35:53.803: g_signal_handler_disconnect: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(lxpanel:810): GLib-GObject-CRITICAL **: 19:35:53.803: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
rfkill: cannot open /dev/rfkill: No such file or directory
rfkill: cannot read /dev/rfkill: Bad file descriptor
(lxpanel:810): Gtk-CRITICAL **: 19:35:53.974: IA__gtk_image_set_from_pixbuf: assertion 'GTK_IS_IMAGE (image)' failed
** Message: 19:35:54.672: Status changed to opened
** Message: 19:35:54.672: Connected to dhcpcd-8.1.2
** Message: 19:35:54.673: Status changed to initialised
You were right about internet, in terminal ping google.com responded.
Can you find a fix why all websites are crashing on chrome (but in strange way all local host addresses works perfectly)
