jdb
Raspberry Pi 4 VL805 firmware release 0138a1
Mon May 04, 2020 12:57 pm
A new firmware from VIA is available for testing. There are a couple of issues with the USB host controller that have been fixed in this release.
1) User settings of the ASPM bits in the PCI configuration space link control register are now maintained
Previously the firmware would trample these bits on start/stop of an isochronous stream if they had been modified from default. This should allow for better diagnosis of issues where the added latency caused by link power management is suspected to be the cause.
2) Better full-speed Isochronous endpoint support
In previous firmware versions, there was a cap on the maximum size of Isochronous full-speed endpoint that could be configured. This limit was 792 bytes. This cap has been removed, so single endpoints up to 1023 bytes are now supported, but be aware that the total Isochronous FS bandwidth across all configured endpoints is still limited to a maximum of 1023 bytes.
Ensure that your Pi's software is up-to-date prior to installing. Run sudo apt update && sudo apt upgrade.
Download the Beta bootloader recovery files from here: https://github.com/raspberrypi/rpi-eepr ... 7.16-138a1
NB: Do *NOT* attempt to update the VLI EEPROM if you are currently using the BETA USB mass storage bootloader with a release date before 2020-05-28. There is a bug where the bootloader will incorrectly read the VLI EEPROM and end up in an endless loop programming/verifying/rebooting. Either roll back to "critical" bootloader with an SD card rescue image, or update the beta bootloader to the latest version.
Copy the contents of the zip file to a blank FAT32-formatted SD card. Insert and power on the Pi. Once EEPROM reprogramming is complete, the activity LED will flash in a constant pattern and a green screen will be displayed on both HDMI ports.
Remove the SD card and replace with whatever OS SD card you were using previously.
Verify the output of sudo rpi-eeprom-update reports the correct version in the CURRENT field:
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
BOOTLOADER: up-to-date
CURRENT: Thu 16 Apr 17:11:26 UTC 2020 (1587057086)
 LATEST: Thu 16 Apr 17:11:26 UTC 2020 (1587057086)
 FW DIR: /lib/firmware/raspberrypi/bootloader/beta
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000137ad
Please test and report back.
Rockets are loud.
https://astro-pi.org
Kendek
Re: Raspberry Pi 4 VL805 firmware release 0138a1
Mon May 04, 2020 5:44 pm
I've updated and everything seems OK.
> vl805
VL805 FW version: 000138a1
ASPM works fine, activates with some delay:
> lspci -vvv | grep ASPM
LnkCtl:	ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
HDD and SSD speed is good:
> lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    |__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
> hdparm -t /dev/<HDD> /dev/<SSD>
/dev/<HDD>:
 Timing buffered disk reads: 448 MB in  3.01 seconds = 148.79 MB/sec
/dev/<SSD>:
 Timing buffered disk reads: 1024 MB in  3.00 seconds = 340.83 MB/sec
and stable:
> iozone -a
iozone test complete.
nothing new in the dmesg.
kevinthefixer
Thu May 07, 2020 2:06 am
As detailed in this thread: viewtopic.php?f=28&t=267331, my Espotek Labrador o-scope now works fine after this update. However, I cannot use the 'scope, a keyboard, and a mouse all three at once when using the type-a usb ports. Any two work but the mouse drops out whenever the third device is plugged in, or in the case of the Labrador board, as soon as it's activated by its software. However I still have the usb-c port forced into host mode, and I can plug both input devices into a usb-c hub and the Lab into a type-a port and all is fine. Perhaps the bandwidth cap mentioned above? Personally I'm happy with this setup but I'm thinking a new Labrador/Pi4 owner would get very frustrated. I intend to alert Chris Esposito, Espotek founder/developer, of this...ummm...development in order to minimize said frustration but I'm not real hopeful it'll help a lot. Anyway thanks to all who helped me out here, I don't want to mention any names 'cuz I heard @jdb embarasses easily!
--Kevin
lingon
Mon May 11, 2020 1:21 pm
I made brief tests with two old SSD:s in different USB-boxes that I have. The first one is a 500 GB Crucial BX500 SSD in a LC-Power LC-25U3-C2 USB 3 enclosure with the chipset ASM235CM and UAS support. https://www.lc-power.com/en/product/hdd ... c-25u3-c2/. This device works without any quirk.
rpi-eeprom-update
BCM2711 detected
CURRENT: Thu 16 Apr 2020 05:11:26 PM UTC (1587057086)
LATEST: Thu 16 Apr 2020 05:11:26 PM UTC (1587057086)
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000137ad
[  142.082565] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[  146.000572] usb 2-2: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[  146.000589] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[  146.000602] usb 2-2: Product: ASM235
[  146.000615] usb 2-2: Manufacturer: ASMT
[  146.000627] usb 2-2: SerialNumber: XXXXXXXXXXXXXXX
[  146.032643] scsi host0: uas
[  146.037490] scsi 0:0:0:0: Direct-Access     CT500BX1 00SSD1           0    PQ: 0 ANSI: 6
[  146.040107] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[  146.040293] sd 0:0:0:0: [sda] Write Protect is off
[  146.040309] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[  146.040615] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  146.041339] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[  146.043581]  sda: sda1 sda2
[  146.046401] sd 0:0:0:0: [sda] Attached SCSI disk
[  146.139414] sd 0:0:0:0: Attached scsi generic sg0 type 0
hdparm  -I /dev/sda
/dev/sda:
ATA device, with non-removable media
        Model Number:       CT500BX100SSD1
        Serial Number:      XXXXXXXXXXXXXXXX
        Firmware Revision:  MU02
        Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
        Supported: 9 8 7 6 5
        Likely used: 9
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:    16514064
        LBA    user addressable sectors:   268435455
        LBA48  user addressable sectors:   976773168
        Logical  Sector size:                   512 bytes
        Physical Sector size:                   512 bytes
        Logical Sector-0 offset:                  0 bytes
        device size with M = 1024*1024:      476940 MBytes
        device size with M = 1000*1000:      500107 MBytes (500 GB)
        cache/buffer size  = unknown
        Nominal Media Rotation Rate: Solid State Device
Capabilities:
        LBA, IORDY(can be disabled)
        Queue depth: 32
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 2   Current = 1
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
           *    Write cache
           *    Look-ahead
           *    Host Protected Area feature set
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    DOWNLOAD_MICROCODE
                SET_MAX security extension
           *    48-bit Address feature set
           *    Device Configuration Overlay feature set
           *    Mandatory FLUSH_CACHE
           *    FLUSH_CACHE_EXT
           *    SMART error logging
           *    SMART self-test
           *    General Purpose Logging feature set
           *    WRITE_{DMA|MULTIPLE}_FUA_EXT
           *    64-bit World wide name
           *    WRITE_UNCORRECTABLE_EXT command
           *    {READ,WRITE}_DMA_EXT_GPL commands
           *    Segmented DOWNLOAD_MICROCODE
           *    Gen1 signaling speed (1.5Gb/s)
           *    Gen2 signaling speed (3.0Gb/s)
           *    Gen3 signaling speed (6.0Gb/s)
           *    Native Command Queueing (NCQ)
           *    Host-initiated interface power management
           *    Phy event counters
           *    READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
                DMA Setup Auto-Activate optimization
                Device-initiated interface power management
           *    Software settings preservation
                Device Sleep (DEVSLP)
           *    SMART Command Transport (SCT) feature set
           *    SCT Write Same (AC2)
           *    SCT Features Control (AC4)
           *    SCT Data Tables (AC5)
           *    SANITIZE feature set
           *    BLOCK_ERASE_EXT command
           *    DOWNLOAD MICROCODE DMA command
           *    WRITE BUFFER DMA command
           *    READ BUFFER DMA command
           *    Data Set Management TRIM supported (limit 8 blocks)
           *    Deterministic read ZEROs after TRIM
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
                supported: enhanced erase
        4min for SECURITY ERASE UNIT. 4min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: XXXXXXXXXXXXX
        NAA             : 5
        IEEE OUI        : XXXXXXX
        Unique ID       : XXXXXXXX
Device Sleep:
        DEVSLP Exit Timeout (DETO): 20 ms (default)
        Minimum DEVSLP Assertion Time (MDAT): 10 ms (default)
Checksum: correct
hdparm -Tt /dev/sda2
/dev/sda2:
Timing cached reads: 1676 MB in 2.00 seconds = 838.57 MB/sec
Timing buffered disk reads: 1096 MB in 3.00 seconds = 364.77 MB/sec
source /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;303407;592
seq-write;0;0;23464;45
rand-4k-write;0;0;69719;17429
rand-4k-read;61884;15471;0;0
Sequential write speed 23464 KB/sec (target 10000) - PASS
Random write speed 17429 IOPS (target 500) - PASS
Random read speed 15471 IOPS (target 1500) - PASS
root@raspberrypi:~# source /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;316599;618
seq-write;0;0;288704;563
rand-4k-write;0;0;50373;12593
rand-4k-read;61191;15297;0;0
Sequential write speed 288704 KB/sec (target 10000) - PASS
Random write speed 12593 IOPS (target 500) - PASS
Random read speed 15297 IOPS (target 1500) - PASS
Run 1
seq-write;0;0;310597;606
rand-4k-write;0;0;69497;17374
rand-4k-read;54795;13698;0;0
Sequential write speed 310597 KB/sec (target 10000) - PASS
Random write speed 17374 IOPS (target 500) - PASS
Random read speed 13698 IOPS (target 1500) - PASS
The first agnostics run showed only a sequential write speed of 23464 KB/sec, but the two following runs were OK, so that is a bit strange. Otherwise the performance is similar to the one with the earlier firmware version 000137ad.
The second drive is a 60 GB OCZ Vertex3 in a RaidSonic Icy Box IB-254U3 enclosure. https://www.raidsonic.de/products/exter ... jectID=476. This one has a JMicron JMS579 chipset and requires a quirk to be used, otherwise the performance is really bad. In principle this device supports UAS, but it is blacklisted and not used:
[   46.519154] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[   46.550418] usb 2-2: New USB device found, idVendor=152d, idProduct=1576, bcdDevice= 2.04
[   46.550433] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   46.550446] usb 2-2: Product: JMS579
[   46.550458] usb 2-2: Manufacturer: JMicron
[   46.550470] usb 2-2: SerialNumber: 987654321029
[   46.554017] usb 2-2: UAS is blacklisted for this device, using usb-storage instead
[   46.554150] usb 2-2: UAS is blacklisted for this device, using usb-storage instead
[   46.554173] usb-storage 2-2:1.0: USB Mass Storage device detected
[   46.559205] usb-storage 2-2:1.0: Quirks match for vid 152d pid 1576: 800000
[   46.559378] scsi host0: usb-storage 2-2:1.0
[   47.609605] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX3              0204 PQ: 0 ANSI: 6
[   47.617938] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
[   47.619064] sd 0:0:0:0: [sda] Write Protect is off
[   47.619082] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[   47.627999] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   47.632967]  sda: sda1 sda2 sda3 sda4
[   47.633369] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   47.636637] sd 0:0:0:0: [sda] Attached SCSI disk
hdparm -I /dev/sda
/dev/sda:
        Model Number:       OCZ-VERTEX3
        Serial Number:      XXXXXXXXXXXXXXXXXXX
        Firmware Revision:  2.25
Standards:
        Used: unknown (minor revision code 0x0110)
        Supported: 8 7 6 5
        Likely used: 8
Configuration:
        Logical         max     current
        heads           16      16
        sectors/track   63      63
        LBA    user addressable sectors:   117231408
        LBA48  user addressable sectors:   117231408
        device size with M = 1024*1024:       57241 MBytes
        device size with M = 1000*1000:       60022 MBytes (60 GB)
Capabilities:
        Queue depth: 32
        R/W multiple sector transfer: Max = 16  Current = 16
        Advanced power management level: 254
Commands/features:
        Enabled Supported:
           *    SMART feature set
           *    Write cache
                Look-ahead
           *    NOP cmd
           *    Advanced Power Management feature set
                Power-Up In Standby feature set
           *    SET_FEATURES required to spinup after power up
           *    FLUSH_CACHE_EXT
           *    SMART self-test
           *    IDLE_IMMEDIATE with UNLOAD
                Write-Read-Verify feature set
           *    Device automatic Partial to Slumber transitions
           *    SET MAX SETPASSWORD/UNLOCK DMA commands
           *    Data Set Management TRIM supported (limit 1 block)
           *    Deterministic read data after TRIM
Security:
                supported
        not     enabled
        not     locked
        not     frozen
        not     supported: enhanced erase
        2min for SECURITY ERASE UNIT.
        NAA             : 5
        IEEE OUI        : XXXXXX
        Unique ID       : XXXXXX
Checksum: correc
root@raspberrypi:~# hdparm -Tt /dev/sda4
/dev/sda4:
Timing cached reads: 1670 MB in 2.00 seconds = 834.97 MB/sec
Timing buffered disk reads: 806 MB in 3.00 seconds = 268.59 MB/sec
Run 1
prepare-file;0;0;140937;275
seq-write;0;0;135685;265
rand-4k-write;0;0;23124;5781
rand-4k-read;20183;5045;0;0
Sequential write speed 135685 KB/sec (target 10000) - PASS
Random write speed 5781 IOPS (target 500) - PASS
Random read speed 5045 IOPS (target 1500) - PASS
The performance is similar also for this SSD and USB-box compared to the previous firmware version. I have not done any extensive stress testing of either of the SSDs.
noee
Wed May 13, 2020 1:28 pm
Testing with a pi4 4GB (not overclocked/over-volted) which basically just runs pihole, JRiver MediaCenter and the occasional video (connect to 4K tv).
The pi has two USB DACs connected (SMSL => USB3, xDUoo => USB2) and a SSD to USB3 (root/home). Each DAC serves a playback zone in the house, so they both play simultaneously.
It's also on the latest 5.4 kernel, running 32bit. All appears normally working, I've not experienced any unexpected behavior so far.
Linux arya 5.4.40-v7l+ #1316 SMP Tue May 12 13:10:42 BST 2020 armv7l GNU/Linux
BCM2711 detected
 FW DIR: /lib/firmware/raspberrypi/bootloader/critical
VL805: up-to-date
CURRENT: 000138a1
 LATEST: 000137ad
Kendek
Sat May 30, 2020 10:41 am
NB 2: This upgrade method has no effect on Pi 4 8GB boards, because the VLI EEPROM is a no-fit part. The VLI firmware has been rolled into the bootloader EEPROM.
Ok, this is completely understandable. But when will the firmware version 0138a1 be available as beta? Is there any chance that this firmware become integrated into the beta bootloader EEPROM images?
HawaiianPi
Sun May 31, 2020 10:17 am
RaspberryPi4B2:~$ sudo rpi-eeprom-update
BCM2711 detected
Dedicated VL805 EEPROM detected
CURRENT: Thu 28 May 2020 07:22:33 AM UTC (1590650553)
LATEST: Wed 27 May 2020 05:47:29 PM UTC (1590601649)
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000137ad
RaspberryPi4B2:~$ uname -a
Linux RaspberryPi4B2 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
Update went okay. Running both the beta USB-MSD boot EEPROM update 2020-05-28 and VL805 138a1 firmware, along with the rpi-update *.elf and *.dat files and 5.4 kernel. No problems that I've noticed.
jdb
Sun May 31, 2020 10:40 am
It will eventually, but there needs to be a longer shakedown of the USB MSD boot first.
Rockets are loud.
Kendek
Sun May 31, 2020 12:01 pm
A theoretical question as an curiosity. I see that the EEPROM chip is simply not soldered on Pi 4 8GB boards (just compared the new 8GB and old 4GB boards). However the soldering place is there and accessible. If the chip will subsequently installed, can it work? The rpi-eeprom-update just checks the board revision, so no go, but are there other software limitations?
cleverca22
Mon Jun 01, 2020 12:48 am
that script just runs vl805 (a static elf binary, in the same git repo), to do the actual updating of the SPI chip
so you can always bypass the script, and run vl805 directly, it has a --help and is simple to use
but the boot firmware may force things backwards to the version in the 2nd SPI chip, because its not expecting a vl805 SPI...
devmoon
Mon Jun 01, 2020 4:25 pm
I tested the new firmware with a raspberry pi 4 4GB. When I connect for example 12 audio devices, all of them are recognized and I can use each one individually. There is a problem when I use all the devices at same time, the first 5 that start to play, play ok, but the others fail with a message "usb_set_interface failed (-28)".
Using a raspbery pi 3 I can play 9 devices at same time, more than the 5 devices that I can play at same time using a raspberry pi4.
This new firmaware not solve this problem. Is this a firmware limitation that will be solved in an other firmware release?
Thanks in advance.
jdb
Tue Jun 02, 2020 6:30 pm
Quoting the first post:
" be aware that the total Isochronous FS bandwidth across all configured endpoints is still limited to a maximum of 1023 bytes."
This firmware increases the supported single endpoint size, not the total available Isochronous FS bandwidth. In future there may be a firmware release that makes better use of all available HS periodic bandwidth.
Rockets are loud.
HawaiianPi
Mon Jun 15, 2020 10:31 pm
MacLe wrote:
Mon Jun 15, 2020 8:54 pm
After bootlader update to 000137ad my screen is inverted ;-(
The bootloader is not the VL805 firmware, so you posted in the wrong thread. Also, screen rotation is an OS function and not really related to the bootloader (which only affects function before the rainbow GPU test splash screen, not after).
From what you have posted, you are still running the default firmware anyway, so ... ¯\_(ツ)_/¯
haris_g
Sun Jul 05, 2020 3:08 am
I am using Ubuntu 18.04 server on my raspberry pi4 4GB.
I had issue of recording audio signals through a microphone array connected on USB port of rpi4, and I am hoping the firmware upgrade may resolve the issue.
I am a newbie and facing the following issues.
1. I am unable to install rpi-eeprom-update package on rpi4.
2. to check the current version of EEPROM I used command vcgencmd bootloader_version. And I am also unable to install vcgencmd package.
I have been smashing my head into lot of stuff randomly, any help and guidance that how can I upgrade the rpi4 firmware will be highly appreciated.
Thank you. Have a good weekend.
Sun Jul 05, 2020 4:56 am
The RPT / RPF only support RaspiOS (formerly Raspbian), Canonical support their Ubuntu Operating System.
haris_g
Sun Jul 05, 2020 5:07 am
Thanks for your reply.
So if I upgrade firmware after installing raspbian and then go back to ubuntu, should it work?
Because ultimately I have to use ubuntu because some of my targeted softwares only work on ubuntu.
Kendek
Sun Jul 05, 2020 7:56 am
You can update the VL805 firmware with vl805 tool, which is a downloadable and executable binary file.
> wget https://github.com/raspberrypi/rpi-eeprom/raw/master/firmware/vl805
> chmod +x vl805
> sudo vl805 -w vl805-000138a1.bin
The bootloader EEPROM is also upgradable without the rpi-eeprom-update package. You can use flashrom, and also the bootloader is capable to update itself (ENABLE_SELF_UPDATE -> /boot/pieeprom.upd and /boot/pieeprom.sig).
> sudo -i
> dtparam audio=off
> dtoverlay spi-gpio40-45
> modprobe spidev
> modprobe spi-bcm2835
> flashrom -p linux_spi:dev=/dev/spidev0.0,spispeed=16000 -w pieeprom.bin
You can use the rpi-eeprom-config Python script to reading and writing the configuration file in the EEPROM image.
Here is my current shell script (pieeprom_flash.sh <pieeprom.bin>):
#!/bin/sh
[ -s "$1" ] && {
    rpi-eeprom-config --out /tmp/pieeprom.cfg "$1"
    sed -i \
      -e s/BOOT_UART=0/BOOT_UART=1/ \
      -e s/WAKE_ON_GPIO=1/WAKE_ON_GPIO=0/ \
      -e s/POWER_OFF_ON_HALT=0/POWER_OFF_ON_HALT=1/ \
      -e s/ENABLE_SELF_UPDATE=1/ENABLE_SELF_UPDATE=0/ \
      -e s/BOOT_ORDER=0xf41/BOOT_ORDER=0xf14/ \
      -e "s/^$/USB_MSD_PWR_OFF_TIME=0\n/" \
        /tmp/pieeprom.cfg
    rpi-eeprom-config --config /tmp/pieeprom.cfg --out /tmp/pieeprom.bin "$1"
    vcmailbox 0x00030056 4 4 0 >/dev/null
    dtparam audio=off
    modprobe spidev
    flashrom -p linux_spi:dev=/dev/spidev0.0,spispeed=16000 -w /tmp/pieeprom.bin
    rm /tmp/pieeprom.*
Ratsima
Sun Jul 05, 2020 8:57 am
I am also a tyro who knows pretty much nothing about hardware. I have a USB camera with an USB extension cable. This worked just fine on a Pi2. I tried to use it with a Pi4. However, the 4 kept dropping all the devices (the camera, a Canon scanner and a powered hub) from the bus. I hoped that the firmware update would help.
VL805: up-to-date
CURRENT: 000138a1
LATEST: 000137ad
It did not. In order to get the camera to work with the Pi4 I have to remove the extension cable which means that I can't put the camera where I want it. I'm still mystified as to why it worked with the Pi2 but not the Pi4.
hippy
Sun Jul 05, 2020 3:41 pm
Just a note to say 'flashrom' has been deprecated and when I had tried to use that it did not work.
Kendek
Sun Jul 05, 2020 3:50 pm
Thanks, but it still works for me, and I have used flashrom several times lately (under Ubuntu, RPi OS and LibreELEC).
haris_g
Tue Jul 07, 2020 7:18 am
> chmod +x vl805
> sudo -i
> dtparam audio=off
> modprobe spidev
#!/bin/sh
[ -s "$1" ] && {
    sed -i \
        /tmp/pieeprom.cfg
    dtparam audio=off
    modprobe spidev
    rm /tmp/pieeprom.*
I am very grateful for your help.
I updated the firmware of rpi4 to 0138a1 using this vl805 executable binary file on ubuntu 18.04.
As I was hoping, my issue is now resolved, microphone array is working fine on USB port to record audio.
However I had to execute the vl805 file as follows:
>sudo ./vl805 -w vl805-000138a1.bin
soundcheck
Mon Jul 13, 2020 1:26 pm
Why isn't this firmware showing up on
https://github.com/raspberrypi/rpi-eepr ... r/firmware
And I am also confused to see the same "critical" !?!? (finally released) vl805 firmware under each branch (beta/stable/critical) of the github firmware tree. :?
I'd say the 0138a1 would belong into beta.
Stable would currently be empty.
And Critical keeps the 0137ad.
Sorry for my ignorance.
And (RPI) Devs!
Why not
alpha
beta
stable
OK. OK. I know That's a different subject. ;)
____________________________________________________________________________________
RPi 4B - Raspberry PI OS (64) (w/ custom RPiOS4 (rt-)kernel )
jdb
Mon Jul 13, 2020 1:49 pm
soundcheck wrote: Why isn't this firmware showing up on
You're conflating two different things. The bootloader updates are independent of the VLI firmware version, but to limit the amount of complexity you always get the "latest stable" VLI firmware in whatever bootloader release stream you select. Given the positive reports (and lack of negative ones) in this thread, I'm close to declaring version 0138a1 "latest stable".
In good time there will be a beta bootloader release that changes the VLI firmware to 0138a1, once the dust has settled from switching the USB-capable bootloader to stable.
Rockets are loud.
jdb
Mon Jul 13, 2020 2:32 pm
Offtopic posts will be deleted without warning.
Rockets are loud.
soundcheck
Mon Jul 13, 2020 2:50 pm
Off topic?
Look. I am a designer myself.
Just for me to understand. You release beta VLI firmware using this forum. And if you finally release it you put it on github.
And that you do, even though github is offering us designers beta firmware branches.
For me it would be much easier to have that VLI beta also in the beta branch. From the outside world, we as maintainers,
consider VLI and eeprom firmware one package. The tools offered by the foundation handle both the same way.
Not to forget. I actually have to scan the forum all the time to find out if there's new beta firmware. That'l be a hell of a job.
Thx for listening.
