RonR
Raspberry Pi EEPROM Manager
Fri Aug 21, 2020 12:06 am
Raspberry Pi EEPROM Manager (rpi-eeprom-mgr) is a menu-driven front-end for rpi-eeprom-update.
Available actions are:
Display EEPROM Status
Update Bootloader EEPROM
Edit Bootloader Configuration
Update VL805 (USB) EEPROM
Remove Pending Update
Change Firmware Directory
Disable Automatic EEPROM Updates
Enable Automatic EEPROM Updates
Automatic EEPROM Update Status
Display/Change Boot Order
All actions have a confirmation prompt before being executed.
rpi-eeprom-mgr.zip
(3.97 KiB) Downloaded 1567 times
melqui
Re: Raspberry Pi EEPROM Manager
Fri Aug 21, 2020 12:04 pm
Disable EEPROM Update Service
Enable EEPROM Update Service
Great , is in the official repository?
hippy
Fri Aug 21, 2020 2:20 pm
Nice job.
RonR
Fri Aug 21, 2020 6:30 pm
It's attached to the first post of this topic (rpi-eeprom-mgr.zip).
Simply extract rpi-eeprom-mgr (unzip rpi-eeprom-mgr.zip), make it executable (chmod +x rpi-eeprom-mgr) and run it (sudo ./rpi-eeprom-mgr).
RonR
Sun Aug 30, 2020 10:26 pm
rpi-eeprom-mgr (in the first post of this topic) has been updated.
The previous version contained two actions that allowed automatic EEPROM updates to be disabled/enabled:
These actions have been replaced by:
These new actions allow automatic EEPROM updates to be disabled/enabled without exacerbating the Serious Problem in Bootloader EEPROM.
RonR
Tue Sep 01, 2020 2:44 am
rpi-eeprom-mgr has been enhanced to circumvent the issue described in the topic: Serious Problem in Bootloader EEPROM
rpi-eeprom-mgr now ensures that no previous EEPROM updates are pending, thus preventing the possibility of an endless EEPROM reprogramming loop.
scotty101
Tue Sep 01, 2020 8:11 am
Why not share this via a Github (or similar) repository rather than a download that some might be suspicious of? I certainly won't download a random zip
wildfire
Tue Sep 01, 2020 8:38 am
To be fair it's a bash script which can easily be examined before execution.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
algorithm
Sun Sep 13, 2020 9:12 am
Typo on line 368 "errrxit"
RonR
Sun Sep 13, 2020 6:35 pm
Yes, that should be "errexit". Fortunately, it does no harm. I'll get that changed.
skr1b
Wed Sep 23, 2020 3:51 am
[/quote]
Where do i put "rpi-eeprom-mgr"? I extracted it on my desktop but when i go into command line and type in "chmod +x rpi-eeprom-mgr". I get an error that says " chmod: cannot access 'rpi-eeprom-mgr': No such file or directory "
I am stuck on what to do from here. Please help
RonR
Wed Sep 23, 2020 5:18 pm
You can put rpi-eeprom-mgr anywhere you like.
If it resides on your desktop and you open a command prompt in /home/pi, you would execute:
chmod +x Desktop/rpi-eeprom-mgr
sudo Desktop/rpi-eeprom-mgr
or
cd Desktop
skr1b
Wed Sep 23, 2020 8:57 pm
or
cd Desktop
chmod + x rpi-eeprom-mgr
[/quote]
Thanks but no luck still getting same error message for both . Am I doing something wrong? File is still on my desktop
chmod: cannot access 'Desktop/rpi-eeprom-mgr': No such file or directory
RonR
Wed Sep 23, 2020 9:09 pm
I just tried both methods here and they both work as expected.
Is your command prompt running in /home/pi/Desktop when you run 'chmod +x rpi-eeprom-mgr'? Does 'ls -l' show rpi-eeprom-mgr?
skr1b
Wed Sep 23, 2020 10:06 pm
[/quote]
I attached a screen shot of what I tried. How do i know if my command prompt is running in home/pi/desktop? Im using Putty Image
Screenshot
Screenshot 2020-09-23 150427.png (32.52 KiB) Viewed 12399 times
RonR
Wed Sep 23, 2020 10:24 pm
Your command prompt shows your current location:
pi@retropie:~/Desktop $
The '~' means your HOME directory (/home/pi).
What does 'ls -l /home/pi/Desktop' show? You should see whatever is on your Desktop, including:
-rw-r--r-- 1 pi pi  13505 Sep 23 17:19 rpi-eeprom-mgr
Both of your attempts were incorrect.
In the first one, you typed rpi-eeprom=mgr instead of rpi-eeprom-mgr.
In the second one, you typed '+ x' instead of '+x'.
Something else to try is: 'find ~ -name rpi-eeprom-mgr'
It should display: '/home/pi/Desktop/rpi-eeprom-mgr'
skr1b
Wed Sep 23, 2020 11:34 pm
[/quote]
I did the above and attached a screenshot. Its not showing up even though its on my desktop?
Screenshot 2020-09-23 163316.png (22.24 KiB) Viewed 12357 times
RonR
Wed Sep 23, 2020 11:41 pm
One last shot...
sudo find / -name rpi-eeprom-mgr
skr1b
Thu Sep 24, 2020 2:27 am
One last shot...
nothing... so strange. What if i put the file somewhere in my pi folder with SSH? Like retropie/configs/all or somewhere it might be able to read it other then my desktop?
RonR
Thu Sep 24, 2020 2:34 am
I don't know what you have on your desktop that appears to be rpi-eeprom-mgr, but Linux says there's no file by that name anywhere on your system.
It doesn't matter where you put rpi-eeprom-mgr as long as you can find it, make it executable with chmod, and run it.
AkulaMD
Thu Sep 24, 2020 3:20 am
You didn't exactly answer his question.
Raspberry Pi OS (32-bit) with desktop and recommended software
Raspberry Pi 4 Model B 8GB at stock speed (never overclock)
Never overclock your Pi.
Encourage optimization instead.
RonR
Thu Sep 24, 2020 3:29 am
It appears the answer is no:
root@raspberrypi:~# apt search rpi-eeprom-mgr
Sorting... Done
Full Text Search... Done
root@raspberrypi:~#
skr1b
Thu Sep 24, 2020 3:48 am
Sorting... Done
root@raspberrypi:~#
[/quote]
Well...i tried it. And it atleast now says its on my system... can you help me from here now with correct commands?
Screenshot 2020-09-23 204727.png (4.24 KiB) Viewed 12275 times
RonR
Thu Sep 24, 2020 3:56 am
sudo chmod +x /opt/retropie/configs/all/rpi-eeprom-mgr
sudo /opt/retropie/configs/all/rpi-eeprom-mgr
skr1b
Thu Sep 24, 2020 5:44 am
INCREDIBLE! It worked :P We finally did it ha. Thank you good sir! Appreciate it very much
