No good reason, and off-topic for this thread probably
I haven't uninstalled PulseAudio from the 64-bit OS - ideally I'll be able to get it working, or an update will fix up the config.
pasman1 wrote: ↑Sun Dec 13, 2020 11:31 pmKernel 5.10 is released.
https://www.phoronix.com/scan.php?page= ... 0-Released
I haven't found the proper solution, but:Bluestang wrote: ↑Mon Dec 14, 2020 3:06 pm@6by9
What is the magic formula to get the KMS audio driver working with the new pulse audio updates?
Both my 32-bit and 64-bit images no longer will output sound with the KMS driver. I had to revert back to the firmware audio to get sound back. Sound worked previously with both images before the update, and the info in this thread.
systemctl --user stop pulseaudio.socket
systemctl --user stop pulseaudio.service
Checked vc4-hdmi.conf matches version as linked, but found stopping the pulseaudio.service kills the menu bar?dom wrote: ↑Mon Dec 14, 2020 7:21 pmI haven't found the proper solution, but:Bluestang wrote: ↑Mon Dec 14, 2020 3:06 pm@6by9
Both my 32-bit and 64-bit images no longer will output sound with the KMS driver. I had to revert back to the firmware audio to get sound back. Sound worked previously with both images before the update, and the info in this thread.and make sure vc4-hdmi.conf matches version here and audio worked again.Code: Select all
systemctl --user stop pulseaudio.socket systemctl --user stop pulseaudio.service
#dtparam=audio=on
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
#dtoverlay=vc4-fkms-v3d
dtoverlay=vc4-kms-v3d
[ 2.574719] debugfs: Directory 'fef00700.hdmi' with parent 'vc4-hdmi-0' already present!
[ 2.575172] vc4_hdmi fef00700.hdmi: ASoC: no DMI vendor name!
[ 2.575464] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.576171] debugfs: Directory 'fef05700.hdmi' with parent 'vc4-hdmi-1' already present!
[ 2.576865] vc4_hdmi fef05700.hdmi: ASoC: no DMI vendor name!
[ 2.585378] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 50.404719] vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
Not for medom wrote: ↑Mon Dec 14, 2020 7:21 pmand make sure vc4-hdmi.conf matches version here and audio worked again.Code: Select all
systemctl --user start pulseaudio.service
systemctl --user start pulseaudio.socket
journalctl -xe | grep snd -B 5 -A 5
-- The job identifier is 943.
Dec 14 22:00:43 rpi-tv pulseaudio[897]: E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
Dec 14 22:00:43 rpi-tv pulseaudio[897]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="platform-fef00700.hdmi" card_name="alsa_card.platform-fef00700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
Dec 14 22:00:43 rpi-tv kernel: vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
Dec 14 22:00:43 rpi-tv pulseaudio[897]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="1" name="platform-fef05700.hdmi" card_name="alsa_card.platform-fef05700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
Dec 14 22:00:43 rpi-tv udisksd[918]: udisks daemon version 2.8.1 starting
Dec 14 22:00:43 rpi-tv udisksd[918]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
Dec 14 22:00:43 rpi-tv udisksd[918]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Dec 14 22:00:44 rpi-tv udisksd[918]: Failed to load the 'mdraid' libblockdev plugin
Dec 14 22:14:05 rpi-tv rtkit-daemon[911]: Supervising 3 threads of 3 processes of 1 users.
Dec 14 22:14:05 rpi-tv pulseaudio[1988]: E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
Dec 14 22:14:05 rpi-tv pulseaudio[1988]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="platform-fef00700.hdmi" card_name="alsa_card.platform-fef00700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
Dec 14 22:14:05 rpi-tv pulseaudio[1988]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="1" name="platform-fef05700.hdmi" card_name="alsa_card.platform-fef05700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
Dec 14 22:14:05 rpi-tv kernel: vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
Dec 14 22:14:05 rpi-tv systemd[586]: Started Sound Service.
-- Subject: A start job for unit UNIT has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support
I'm seeing the same problem, but not just with kernel 5.10.0 but also with the latest 5.4.83 kernel from rpi-update.DougieLawson wrote: ↑Tue Dec 15, 2020 12:55 amSomething bad has happened with 5.10. Every one of my Zeros and RPI1Bs has failed to boot with that latest BRANCH=next rpi-update.
My 2B failed.MrEngman wrote: ↑Tue Dec 15, 2020 1:40 amI'm seeing the same problem, but not just with kernel 5.10.0 but also with the latest 5.4.83 kernel from rpi-update.DougieLawson wrote: ↑Tue Dec 15, 2020 12:55 amSomething bad has happened with 5.10. Every one of my Zeros and RPI1Bs has failed to boot with that latest BRANCH=next rpi-update.
Only the Pi4 4GB and 8GB and Pi400 work. All other Pi failed to boot, Pi0, Pi0W, Pi1B, Pi2B, Pi3A. More info viewtopic.php?p=1779825#p1779825
MrEngman
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
That was quick thank you. I'll give that a go (on a subset of machines first - so I don't lose another four hours).
Fix works for me on all the Pi I had problems with.DougieLawson wrote: ↑Tue Dec 15, 2020 5:02 pmThat was quick thank you. I'll give that a go (on a subset of machines first - so I don't lose another four hours).
Nothing has been changed in this regard downstream. I'm not sure what may have changed upstream.
As described in the first post, when it's ready.
