Bluestang
Scripts to Install Vulkan on Pi 4
Sat Oct 24, 2020 3:37 pm
A disclaimer of sorts - only install this if you want to test the Vulkan driver for the Pi 4 that is currently in the MESA repo. Otherwise wait until it is released through apt...
The Vulkan driver only works in X11. KMS/DRM will be added later - source folder is missing an entire file of code that implements Vulkan Direct Display extensions.
Kudos to @rpiMike for the original script.
Copy-paste into your own script file with proper permissions in 32-bit RPiOS:
sudo rm -r /home/pi/mesa_vulkan
echo 1/8 Update
sudo apt update
echo 2/8 Upgrade
sudo apt full-upgrade -y
echo 3/8 Install pre-requisites
sudo apt install -y libxcb-randr0-dev libxrandr-dev \
        libxcb-xinerama0-dev libxinerama-dev libxcursor-dev \
        libxcb-cursor-dev libxkbcommon-dev xutils-dev \
        xutils-dev libpthread-stubs0-dev libpciaccess-dev \
        libffi-dev x11proto-xext-dev libxcb1-dev libxcb-*dev \
        bison flex libssl-dev libgnutls28-dev x11proto-dri2-dev \
        x11proto-dri3-dev libx11-dev libxcb-glx0-dev \
        libx11-xcb-dev libxext-dev libxdamage-dev libxfixes-dev \
        libva-dev x11proto-randr-dev x11proto-present-dev \
        libclc-dev libelf-dev git build-essential mesa-utils \
        libvulkan-dev ninja-build libvulkan1 python-mako \
        libdrm-dev libxshmfence-dev libxxf86vm-dev libunwind-dev \
		valgrind libzstd-dev vulkan-tools
echo 4/8 Install meson
sudo apt purge meson -y
sudo pip3 install meson
echo 5/8 Install mako
sudo pip3 install mako
echo 6/8 Get v3dv
cd ~
git clone https://gitlab.freedesktop.org/mesa/mesa.git mesa_vulkan
echo 7/8 Build v3dv
cd mesa_vulkan
CFLAGS="-mcpu=cortex-a72 -mfpu=neon-fp-armv8" CXXFLAGS="-mcpu=cortex-a72 -mfpu=neon-fp-armv8" meson --prefix /usr -Dplatforms=x11 -Dvulkan-drivers=broadcom -Ddri-drivers= -Dgallium-drivers=kmsro,v3d,vc4 -Dbuildtype=release build
ninja -C build -j4
sudo ninja -C build install
echo 8/8 Updated Mesa Driver
glxinfo -B
Copy-paste into your own script file with proper permissions in 64-bit RPiOS:
echo 1/8 Update
sudo apt update
echo 2/8 Upgrade
echo 6/8 Get v3dv
cd ~
echo 7/8 Build v3dv
cd mesa_vulkan
CFLAGS="-mcpu=cortex-a72" CXXFLAGS="-mcpu=cortex-a72" meson --prefix /usr -Dplatforms=x11 -Dvulkan-drivers=broadcom -Ddri-drivers= -Dgallium-drivers=kmsro,v3d,vc4 -Dbuildtype=release build
ninja -C build -j4
glxinfo -B
Gavinmc42
Re: Scripts to Install Vulkan on Pi 4
Sun Oct 25, 2020 8:37 am
Yippee, worked on a 64bit 5.4.72 Raspberry OS :D
Now trying it on my messed up, SSD based Raspberry OS.
I'm dancing on Rainbows.
Gavinmc42
Sun Oct 25, 2020 9:16 am
Rats, mesa won't update on my messed up system..
Everything seems to be building and then it broke at the install stage?
Will backtrack though the script.
ninja: Entering directory `build'
[1/2] Installing files.
Installing src/mapi/shared-glapi/libglapi.so.0.0.0 to /usr/lib/aarch64-linux-gnu
  File "/usr/local/lib/python3.7/dist-packages/mesonbuild/mesonmain.py", line 140, in run
    return options.run_func(options)
  File "/usr/local/lib/python3.7/dist-packages/mesonbuild/minstall.py", line 544, in run
    installer.do_install(datafilename)
  File "/usr/local/lib/python3.7/dist-packages/mesonbuild/minstall.py", line 362, in do_install
    self.install_targets(d)
  File "/usr/local/lib/python3.7/dist-packages/mesonbuild/minstall.py", line 517, in install_targets
    depfixer.fix_rpath(outname, t.rpath_dirs_to_remove, install_rpath, final_path,
AttributeError: 'TargetInstallData' object has no attribute 'rpath_dirs_to_remove'
FAILED: meson-install
/home/pi/.local/bin/meson install --no-rebuild
ninja: build stopped: subcommand failed.
Been having trouble updating mesa for some time, so not unsurprising.
glxinfo -B
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Broadcom (0x14e4)
    Device: V3D 4.2 (0xffffffff)
    Version: 19.3.2
    Accelerated: yes
    Video memory: 3796MB
    Unified memory: yes
    Preferred profile: compat (0x2)
    Max core profile version: 0.0
    Max compat profile version: 2.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.1
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL version string: 2.1 Mesa 19.3.2
OpenGL shading language version string: 1.20
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 19.3.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
Bluestang
Sun Oct 25, 2020 8:04 pm
Looks like it's another 64-bit version?
Hard to say what the issue might be without more info, but maybe you might want to start fresh on the SSD?
alpargataman
Sun Oct 25, 2020 9:08 pm
Working as expected on a fresh Raspberry Pi OS 64 bit installation. Thanks for the script
Waldnerr
Mon Oct 26, 2020 9:48 am
Hi all , installed without problems on my Pi4 ,32 and 64 bit , got some questions :
Vendor: VMware, Inc. (0xffffffff)
Device: llvmpipe (LLVM 9.0.1, 128 bits) (0xffffffff)
Version: 19.3.2
Accelerated: no
Accelerated means hardware encoding ?
Is that correct Accelerated=no ?
Hava a good day all
Gavinmc42
Mon Oct 26, 2020 11:27 am
That means software rendering
Hardware will give you something like this, it will be updated to 20.3... if this script runs ok
Version: 19.3.2
Accelerated: yes
Gavinmc42
Mon Oct 26, 2020 11:43 am
Thanks guys, if you don't have a messed up OS like me, the script works fine :oops:
I have only tested the 64 bit version.
https://vsg-dev.github.io/VulkanSceneGraph/
VulkanScenegraph compiles and works.
The demo myfirstvsgapplication works too :D
Only tested a few vsgExamples so far :D
VSG removes lots of big Vulkan coding issues ;)
The older OpenGL OpenSceneGraph is also the core of some big pieces of code like FlightGear.
OpenMW is porting to VSG?
Waldnerr
Mon Oct 26, 2020 2:07 pm
Version: 19.3.2
Accelerated: yes
Sorry previous report was with VNC , here's the correct
Version: 20.3.0
Accelerated: yes
Everything is working : Thanks a lot !
Gavinmc42
Tue Oct 27, 2020 11:22 am
Vkmark score of 311, not exactly fast but at least it runs the benchmark :D
Very impressed so far with Vulkan.
Just one beef, Warzone2100 needs 1.1.148 and it only detects 1.1.97 :(
One day maybe?
Omicron777
Wed Oct 28, 2020 4:04 am
echo 1/8 Update
sudo apt update
echo 2/8 Upgrade
echo 6/8 Get v3dv
cd ~
echo 7/8 Build v3dv
cd mesa_vulkan
ninja -C build -j4
glxinfo -B
Could you per chance elaborate on step 7 of 8. After entering the "CFLAGS=..." string...? I don't know what to do? "
sudo ninja -C build Install
" returns with
Ninja: Entering directory 'build'
Ninja: error: loading 'build.ninja': No such file or directory
I check with ls, ...there's a 'build' directory...(?)
cd build
& there are two files, but if I run '
' there...I get a similar error...except with the added:
fatal: chdir to 'build' - no such file or directory
I'm not getting whatever it is for some reason...(?) To be honest, I'm ~proficient at best on the command line; it could very well be something ridiculous...For God's sake, look at the formatting of this post...!! Definitely don't discount the ridiculous! BUT! I also don't know what other information to provide... The process was very smooth all the way right to there...then...a brick wall! (~for me...?)... Any ideas would be greatly appreciated!
Gavinmc42
Wed Oct 28, 2020 4:40 am
uname -a
Are you running 32 or 64 bit OS?
That "CFLAG" tells the compiler which version to make it for.
Omicron777
Thu Oct 29, 2020 4:20 am
uname -a
It is 64-bit; BUT! No more worries. Your instruction set worked; I got it to compile just a few minutes ago! ...It is a very nice; Thank You!
If it's of help to anyone—?
I installed synaptic so I could literally just see what was missing...basically piecemeal, listed, & searchable...& with boxes to check.
The issue was with the X C Binding Library Files; a few of the libxcb–dev files were unchecked. I just grabbed those with Synaptic, went back to terminal, continued with the instruction set, & away it went!
Gavinmc42
Mon Jan 18, 2021 11:46 am
Rats, errors on vsginput.
Reading symbols from vsginput...done.
(gdb) run
Starting program: /home/pi/vsgExamples/bin/vsginput
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
Program received signal SIGSEGV, Segmentation fault.
0x000000555560a830 in vsg::ref_ptr<vsg::Options>::operator=(vsg::ref_ptr<vsg::Options> const&) [clone .isra.42] ()
(gdb)
Most of the vsg examples are working including vsgimgui with event record and playback.
rbafrom
Thu Jun 03, 2021 1:28 pm
I ran those on Raspberry Linux raspberrypi 5.4.42-v8+ #1319 SMP PREEMPT aarch64 GNU/Linux and got this error:
pi@raspberrypi:~ $ glxinfo -l
Error: unable to open display
Although all scripts succeeded.
Any thoughts on what could be causing this? Thanks.
nikal
Fri Jul 02, 2021 10:00 am
I have done this numerous times trying to get dolphin emulator working with vulkan driver. Of course I tried everything on a fresh install of 64bit raspios.
The main problem is that after a reboot nothing works. The rendering reverts back to software and the dolphin stops working. Why is that happening? Isn't supposed that the installation is something permanent ? How can I fix this issue?
My system is a raspberry pi 4/8GB booting from a M.2 SATA disk with PINN.
Thanks in advance for your time and help.
Gavinmc42
Tue Jul 13, 2021 1:12 am
Time to rerun/update that script?
https://www.phoronix.com/scan.php?page= ... ry-Shaders
I need to make myself an new 64bit OS and try this new stuff.
thatchunkylad198966
Mon Jul 19, 2021 4:30 pm
Will you be updating this, OP?
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
