RonR
Upgrading Raspberry Pi OS Buster to Bullseye for Testing Purposes
Mon Aug 16, 2021 7:10 pm
The attached script will upgrade Raspberry Pi OS Buster (32-bit or 64-bit) to Bullseye.
Answer 'Yes' to any questions during the process. Be patient as it's a lengthy process.
It's best to run this script on a fresh installation of Raspberry Pi OS Buster.
Do *NOT* use this script without having a reliable backup of the system it's being run on!
Problems are a possibility as Raspberry Pi OS Bullseye is an unfinished/unreleased OS.
buster2bullseye.zip
(923 Bytes) Downloaded 4411 times
CaptainMidnight
Re: Upgrading Raspberry Pi OS Buster to Bullseye for Testing Purposes
Mon Aug 16, 2021 7:39 pm
Thanks RonR, I've been playing around with some initial test upgrades to Bullseye, but it's always interesting looking through your scripts and picking up some ideas...
Edit: worked better than my first attempts, all looks ok.
"Never get out of the boat."
Absolutely goddamn right!
Unless you were goin' all the way...
bls
Tue Aug 17, 2021 12:26 am
RonR, this is great! I used it upgrade a 64-bit RasPiOS sdm-customized image to Bullseye in a systemd-nspawn session.
Worked like a charm...Looks like there are a few things to chase down, but it booted and runs. Now I have a working ready-to-run 64-bit Bullseye image for early testing.
Thanks for sharing!
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
craigevil
Tue Aug 17, 2021 1:42 am
A RPIOS/Debian Bullseye sources.list with the links to relevant docs.
# Raspberry PI OS Buster repository
deb https://archive.raspberrypi.org/debian/ buster main
# Raspberry PI OS Bullseye repository
deb https://archive.raspberrypi.org/debian/ bullseye main
# Bullseye https://www.debian.org/releases/bullseye/arm64/release-notes/ch-upgrading.en.html
 deb https://deb.debian.org/debian/ bullseye main contrib non-free
# deb-src https://deb.debian.org/debian/ bullseye main contrib non-free
# Bullseye Security https://www.debian.org/releases/bullseye/arm64/release-notes/ch-information.en.html#security-archive
 deb https://deb.debian.org/debian-security bullseye-security main contrib non-free
# deb-src https://deb.debian.org/debian-security bullseye-security main contrib non-free
# Bullseye Updates https://wiki.debian.org/DebianBullseye#FAQ
 deb https://deb.debian.org/debian bullseye-updates main contrib non-free
# deb-src https://deb.debian.org/debian bullseye-updates main contrib non-free
# Bullseye Backports  https://backports.debian.org/
# deb https://deb.debian.org/debian/ bullseye-backports main contrib non-free
# deb-src https://deb.debian.org/debian/ bullseye-backports main contrib non-free
# Bullseye Proposed Updates https://wiki.debian.org/StableProposedUpdates
# deb https://deb.debian.org/debian/ bullseye-proposed-updates main contrib non-free
# deb-src https://deb.debian.org/debian/ bullseye-proposed-updates main contrib non-free
My actual sources.list
inxi -r
Repos: Active apt repos in: /etc/apt/sources.list
1: deb https://deb.debian.org/debian unstable main contrib non-free
2: deb https://deb.debian.org/debian experimental main contrib non-free
3: deb https://incoming.debian.org/debian-buildd buildd-unstable main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/github-cli.list
1: deb [arch=arm64 signed-by=/usr/share/keyrings/githubcli-archive-keyring.gpg] https://cli.github.com/packages stable main
Active apt repos in: /etc/apt/sources.list.d/raspi.list
1: deb https://archive.raspberrypi.org/debian/ buster main
2: deb https://archive.raspberrypi.org/debian/ bullseye main
Very nice update script!
Raspberry PI 400 Raspberry Pi OS (Debian Sid) Kernel: 5.15.5-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
Milliways
Tue Aug 17, 2021 4:53 am
I already had a Bullseye installation which I have been updating for some months, but the latest seemed to break WiFi.
I decided to try this on top of my working Buster image.
It seemed to work well, and didn't take too long.
I updated and was told "48 packages can be upgraded. Run 'apt list --upgradable' to see them."
Upgrade showed:-
The following packages have been kept back:
  libasound2-data libcairo-gobject2 libgtk2.0-bin libpulsedsp plymouth-label qpdfview-translations qt5-style-plugins
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
I note that python3 is still at 3.7, although my latest upgrade of my other Bullseye system installed 3.9 over 3.8
RonR
Tue Aug 17, 2021 5:02 am
Thanks for sharing!
I used Image File Utilities to upgrade copies of 2021-05-07-raspios-buster-arm*.img to 2021-05-07-raspios-bullseye-arm*.img:
1. image-shrink to add a couple of GB of free space to the image file while upgrading
2. image-chroot to chroot into the image file
3. buster2bullseye to upgrade the image file from Buster to Bullseye
4. image-shrink to remove the excess free space from the image file
RonR
Tue Aug 17, 2021 5:13 am
Upgrade showed:-
None of those problems here.
buster2bullseye is not intended to update an existing Bullseye installation (you must have removed the check for Buster).
Immediately after running buster2bullseye on a Buster installation:
root@raspberrypi:~# apt update
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
root@raspberrypi:~# python3 --version
Python 3.9.2
Try starting from a clean Buster installation.
ralphrmartin
Wed Aug 18, 2021 7:23 pm
For extra credit, how about a script to also upgrade (or even cross-grade) from 32-bit to 64-bit?
emma1997
Wed Aug 18, 2021 10:29 pm
James164 wrote:
Tue Aug 17, 2021 5:42 am
Looks like there's a few echos in here. Or maybe James plans to return at a later date and tack on a link or two?
pi-anazazi
Thu Aug 19, 2021 9:27 am
Upgraded in the past by changing repo names and apt update and apt full-upgrade. What does the script on-top/other?
Kind regards
anazazi
craigevil
Thu Aug 19, 2021 3:43 pm
You can't actually upgrade or whatever it would be to arm64 from armhf.
But you can do this:
dpkg --add-architecture arm64
And add
arm_64bit=1
to /etc/boot/config.txt
https://wiki.debian.org/Multiarch
twojstary
Thu Aug 19, 2021 8:00 pm
Debian Bullseye is out of testing now: https://www.debian.org/News/2021/20210814
I don't see an image for Raspbian Bullseye under https://downloads.raspberrypi.org/raspi ... hf/images/, anyone have any idea how long the packagers for Raspbian take?
As for stability, Bullseye has been more stable than buster in my experience. Wifi stability is the same still seeing occasional ARP response failures when under heavy IP load (by inbound UDP traffic to RPi).
Of note in Bullseye:
Systemd is actually becoming usable with 247.3 in this release since the aged 241-7 with plenty of needed options for normal operation. Of note: ExecCondition, which allows for the conditional starting of services.
Pulseaudio 15.0 didn't make it for this release, it's still on 14.2.
Bluez is at 5.55-3.1, 6 releases behind the current 5.60.
davidcoton
Thu Aug 19, 2021 9:39 pm
See viewtopic.php?f=66&t=317787#p1902031 and the replies there. (Ignore Dougie's link, it is not relevant.)
klricks
Thu Aug 19, 2021 10:08 pm
Based on past release history, 2 to 4 months: viewtopic.php?p=1899779#p1899779
tinker2much
Sat Aug 21, 2021 2:55 pm
I ran this last night and it worked great. Does take forever, even on an SSD. I haven't yet run it enough to know what, if any, gaps remain in bullseye.
(I used it in combination with another of your great utilities - MultiBoot - so it's just an additional partition on a large SSD.)
ralphrmartin
Sat Aug 21, 2021 2:56 pm
See
https://wiki.debian.org/CrossGrading
at least for 32-bt to 64-bit intel systems.
Sat Aug 21, 2021 3:48 pm
See
Hmm, I might give that a go with a spare 3B+. It'll need a few Pi specific changes though. I'll start with Lite and move to Desktop if I can find a spare monitor.
Unreadable squiggle
Botspot
Sat Aug 21, 2021 7:16 pm
This script does not work properly if the userland is 32-bit but the kernel is 64-bit.
Consider changing your script to use a method like this:
if [ "$(od -An -t x1 -j 4 -N 1 "$(readlink -f /sbin/init)")" = ' 02' ];then
  arch=64
elif [ "$(od -An -t x1 -j 4 -N 1 "$(readlink -f /sbin/init)")" = ' 01' ];then
  arch=32
else
  errexit "Failed to detect OS CPU architecture! Something is very wrong."
fi
Easily install apps on your Pi with Pi-Apps! Over 500k users.
Includes two Zoom desktop apps, 3 ways to run Minecraft, 10 web browsers, appearance themes, and 105 more.
RonR
Sat Aug 21, 2021 9:28 pm
  arch=64
  arch=32
else
fi
Consider this simple solution instead:
1. Remove the 'arm_64bit=1' line you added in /boot/config.txt
2. Run 'sudo ./buster2bullseye'
3. Add the 'arm_64bit=1' line back into /boot/config.txt
RonR
Sun Aug 22, 2021 1:55 am
Using the Bullseye system you've now created, it's easy to upgrade a Buster image file to Bullseye so you don't have to keep going through the process:
pi@raspberrypi:~# sudo image-shrink 2021-05-07-raspios-buster-armhf.img 2000
Shrink 2021-05-07-raspios-buster-armhf.img [Additional MB = 2000] (y/n)? y
pi@raspberrypi:~# sudo image-chroot 2021-05-07-raspios-buster-armhf.img
chroot to 2021-05-07-raspios-buster-armhf.img (y/n)? y
Attempting to chroot to 2021-05-07-raspios-buster-armhf.img
Host root filesystem is available at /host-root-fs
Use exit or ^D to terminate chroot
root@raspberrypi:/# /host-root-fs/pathto/buster2bullseye
root@raspberrypi:/# exit
exit
Exited chroot to 2021-05-07-raspios-buster-armhf.img
pi@raspberrypi:~# sudo image-shrink 2021-05-07-raspios-buster-armhf.img 0
Shrink 2021-05-07-raspios-buster-armhf.img [Additional MB = 0] (y/n)? y
pi@raspberrypi:~# mv 2021-05-07-raspios-buster-armhf.img 2021-05-07-raspios-bullseye-armhf.img
Botspot
Sun Aug 22, 2021 2:53 am
  arch=64
  arch=32
else
fi
Sure, I could work around the flaw in your script by editing a file twice and rebooting twice, but what about the average person who didn't read your script first before running it, didn't identify the flaw I identified, and didn't refrain from running your script which now added the wrong repositories - effectively breaking all apt updates and installations?
This seems like the kind of failure that you would want to fix.
And yes, running the 64-bit kernel on a 32-bit OS is not uncommon: it turns out a large portion of daily RPi users have the 64-bit kernel enabled on their 32-bit systems. (yes I have proof)
RonR
Sun Aug 22, 2021 8:12 am
buster2bullseye.zip (in the first post of this topic) has been updated.
This update adds support for 32-bit Raspberry Pi OS installations where the user added 'arm_64bit=1' to /boot/config.txt.
jeremym
Mon Aug 23, 2021 9:27 am
Firstly, thank you for posting the script RonR.
Please forgive my ignorance, but after using this script will my Pi automatically receive any changed packages, when the Raspberry Pi OS is officially upgraded to Bullseye? I note the sources are different to RonR's, after the upgrade.
apt update
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://packages.azlux.fr/debian buster InRelease
Get:4 http://deb.debian.org/debian bullseye-updates InRelease [36.8 kB]
Fetched 36.8 kB in 2s (15.8 kB/s)
is the source for Log2Ram.
I've used the script to upgrade ten Raspberry Pi 4's, running the 64-bit lite beta to do folding@home work, without any issues. But as there aren't any customisations, I expected that.
I'm a bit more cautious about using the script to upgrade my Pi Zero, which is my recursive DNS server (running PiHole, Unbound & Log2Ram). Has anyone used the scripts to upgrade their DNS server?
RonR
Mon Aug 23, 2021 6:09 pm
Only Raspberry Pi OS package sources are changed from Buster to Bullseye by the script.
If you have third party packages installed that are currently coming from Buster repositories but have Bullseye versions available, you would need to change those sources if you wish those packages to be upgraded.
Play it safe and create a backup before making any changes.
Spaco
Thu Aug 26, 2021 4:35 pm
Great script! One observation, the install gcc-8-base actually ends up removing a bunch of packages which I don't think are correctly replaced, e.g. libc-dev. This breaks a lot of things once you're up and running on bullseye, i.e. most build processes. I had to fix it by hand.
Apparently, this is due to transitional libraries missing for the gcc8 to gcc10 upgrade path. This explains it better:
https://salsa.debian.org/rpavlik/gcc-10-compat
