rolgiati
Memory split with less video memory ?
Sun Apr 07, 2013 12:10 pm
I am looking into freeing more usable memory on a Raspi 256Mb that will be used headless, and only accessed through ssh in CLI mode.
Would it be possible to change the memory split and reduce the video memory to 12 MB ?
( which should be sufficient for a VGA display of 800 x 600 in 16 colours )
How could it be done ?
pluggy
Re: Memory split with less video memory ?
Sun Apr 07, 2013 1:18 pm
If you're using debian, run
sudo raspi-config
I'll let you work the rest out. ;)
You'll find the minimum is 16MB, it will accept figures for less, but sets it to 16MB.
chris57100
Fri Apr 12, 2013 2:35 pm
I think that now the minimum is 8Mb. Also i am not sure but a 8 multiple is recommanded
Raspberry Pi Home Server : http://www.pihomeserver.fr
Software and electronic tutorials : Samba, Airplay, CUPS, Time machine, Nginx, Owncloud, rTorrent, Wordpress, etc.
Full Wi-Fi hotspot installation on a RPi 3 including a captive portal and freeradius management: https://github.com/pihomeserver/Kupiki-Hotspot-Script
pluggy
Fri Apr 12, 2013 6:13 pm
chris57100 wrote:I think that now the minimum is 8Mb. Also i am not sure but a 8 multiple is recommanded
root@raspberrypi:~# uname -a
Linux raspberrypi 3.6.11+ #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013 armv6l GNU/Linux
root@raspberrypi:~# tail /boot/config.txt -n1
gpu_mem=32
root@raspberrypi:~# cat /proc/meminfo|grep Mem
MemTotal:         481288 kB
MemFree:          433492 kB
root@raspberrypi:~#
edit & reboot
gpu_mem=16
MemTotal:         497544 kB
MemFree:          450076 kB
root@raspberrypi:~#
edit & reboot
gpu_mem=8
MemTotal:         497544 kB
MemFree:          450400 kB
root@raspberrypi:~#
edit & reboot
gpu_mem=4
MemTotal:         497544 kB
MemFree:          452832 kB
root@raspberrypi:~#
edit & reboot
gpu_mem=3
MemTotal:         497544 kB
MemFree:          450332 kB
root@raspberrypi:~#
edit & reboot.
gpu_mem=1
MemTotal:         497544 kB
MemFree:          452856 kB
root@raspberrypi:~#
I rest my case ?
chris57100
Fri Apr 12, 2013 7:21 pm
Excellent ! I never tested and really thought that 1Mb was not possible :shock:
pluggy
Fri Apr 12, 2013 7:36 pm
It isn't, it just accepts the figure. The memory is identical to the 16MB setting.
chris57100
Fri Apr 12, 2013 8:15 pm
Oups, bad eyes !!!
Ok thanks for the tip
rolgiati
Fri Apr 12, 2013 9:03 pm
Thanks for the info.
ProDigit
Fri Aug 02, 2019 7:07 am
Old topic, but,
What if you have bought one of them 3,5" Rpi screens with a resolution of 480x320 pixels?
It should be possible to lower the Vram to a mere 1MB, as there's only about 153k pixels to feed?
RaTTuS
Fri Aug 02, 2019 7:19 am
no need to necro this , on the older pi's 16MB is as low as you can go with the memory split IIRC
dunno about Pi4
Covfefe
Fri Aug 02, 2019 8:07 am
Impressive necro though, might be a record.
