rbn
RPi.GPIO needs later version for new Pi 2
Fri Feb 06, 2015 9:10 pm
Existing module for RPi.GPIO in Raspian doesn't work on new Pi 2. AdaFruit blog has an article showing you how to upgrade until it is fixed. I have also seen comments that you may need to update firmware with sudo rpi-update to keep PWM happy.
https://blog.adafruit.com/2015/02/05/ho ... erry-pi-2/
gordon77
Re: RPi.GPIO needs later version for new Pi 2
Fri Feb 06, 2015 9:16 pm
Its also here http://www.raspberrypi.org/forums/viewt ... 00#p683480
I used it to get my gpio working.
croston
Fri Feb 06, 2015 9:26 pm
rbn wrote:I have also seen comments that you may need to update firmware with sudo rpi-update to keep PWM happy.
The firmware patch may not even available through rpi-update yet - RPi.GPIO with newer firmware is completely untested until later tonight - my advice for now is not to use PWM.
rbn
Fri Feb 06, 2015 10:42 pm
Ok re not using PWM
I wish I hadn't done an rpi-update. It kills Sonic Pi on the Pi 2. Sam Aaron is aware of this but doesn't yet know why. Can anyone give me the git hash for the firmware in the latest Raspian release on 31/1/2015 so that I can downgrade to it?
joan
Fri Feb 06, 2015 10:53 pm
rbn wrote:Ok re not using PWM
https://github.com/Hexxeh/rpi-firmware/commits/master
Numbers on the right hand side.
sudo rpi-update long_commit_number
croston
Sat Feb 07, 2015 1:21 am
Update: a new development version is now available. All tests now pass except a couple of wait_for_edge() tests, providing you have run rpi-update first.
