ZacharyI123
32 or 64 bit
Mon Dec 31, 2012 6:24 pm
When installing software through the browser on the pi, would l install Linux 32 or 64 bit? Would average Linux software work on the pi not concerning power and ram? I am running raspbian wheezy.
Don't be mean, I'm only thirteen 8-)
itimpi
Re: 32 or 64 bit
Mon Dec 31, 2012 6:40 pm
you can only use software specifically compiled for the Pi (which uses an ARM processor). Your question regarding 32/64 bits is only relevant when running a version of Linux on a machine with an Intel compatible processor (such as a typical PC).
Cloudcentric
Re: 32 or 64 bit
Mon Dec 31, 2012 7:11 pm
..to be more precise the the Raspberry Pi has an ARMv6 CPU, these CPU's are a different architecture to the x86 and x86-64 to which you are referring.
Raspbian is based of ARMv7 Debian Wheezy ARMHF and compiled to run on the ARMv6:
http://www.raspbian.org/RaspbianFAQ
Re: 32 or 64 bit
Mon Dec 31, 2012 7:12 pm
ZacharyI123 wrote:When installing software through the browser on the pi, would l install Linux 32 or 64 bit? Would average Linux software work on the pi not concerning power and ram? I am running raspbian wheezy.
What software do you want to install? If it's not in the Raspbian software repository you may need to download the source and build it yourself.
moduleWolf
Re: 32 or 64 bit
Fri Mar 08, 2013 3:42 pm
ARM instructions are always 32-bit, and are aligned on a four-byte boundary.
Register direct instruction support for 64-bit integers is limited, and 64-bit operations require sequences of two or more instructions to synthesize them.
I would tell your compiler 32.
jrenner
Re: 32 or 64 bit
Sun Mar 24, 2013 3:21 pm
I believe ARMv8 supports 64 bit
timrowledge
Re: 32 or 64 bit
Mon Apr 01, 2013 11:55 pm
Yes ARMv8 does 64 bit - but I think it might be a while before it is possible to make a $35 machine based on one….
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Mattney
Re: 32 or 64 bit
Wed Dec 04, 2013 8:18 pm
I'm trying to install chatscript on my pi. Linux supports it in 32... I'm completely new so forgive me please but, is there anyway to make it run on the rpi
ric96
Re: 32 or 64 bit
Thu Dec 05, 2013 7:24 am
if its a .deb package then it should have armhf at end of its name and not i386 or amd_64
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
Re: 32 or 64 bit
Thu Dec 05, 2013 7:49 am
ric96 wrote:if its a .deb package then it should have armhf at end of its name and not i386 or amd_64
and should state that is for the Raspberry Pi/Raspbian. Most ordinary Debian armhf .debs are not compatible.
A link to the web site for chatscript would be handy so we can look.
Mattney
Re: 32 or 64 bit
Thu Dec 05, 2013 5:12 pm
I Found it at source forge here http://sourceforge.net/projects/chatscript/
Re: 32 or 64 bit
Thu Dec 05, 2013 5:37 pm
Mattney wrote:I Found it at source forge here http://sourceforge.net/projects/chatscript/
That package does include source code, but there's no config script or Makefile or instructions.
So best of luck trying to build that.
plugwash
Re: 32 or 64 bit
Thu Dec 05, 2013 5:39 pm
jrenner wrote:I believe ARMv8 supports 64 bit
But other than apples horribly locked down devices you can't actually buy it yet.
totoharibo
Re: 32 or 64 bit
Thu Dec 05, 2013 8:59 pm
have a look at
LINUX/LinuxCompile.sh
and then at DOCUMENTATION.
for me explanations are a bit foggy
Good luck ...
roadrash
Re: 32 or 64 bit
Wed Apr 29, 2015 6:54 pm
If its on sourceforge then it should be Open source so ask for the source code to be posted.
Heater
Re: 32 or 64 bit
Wed Apr 29, 2015 7:26 pm
plugwash,
But other than apples horribly locked down devices you can't actually buy it [64 bit ARM] yet.
But very soon you can: https://www.96boards.org/products/hikey/
64 bit ARM. Eight cores. 1 gig RAM, 1GHz, 130 dollars.
Bring it on!
plugwash
Re: 32 or 64 bit
Wed Apr 29, 2015 10:35 pm
Heater wrote:plugwash,
So they taunt us by giving us the fancy new 64-bit core but giving it with a piddling ammount of ram :(
dannyk96
Re: 32 or 64 bit
Mon Mar 07, 2016 12:07 pm
I know this is an old thread, but the announcement now is..
There *is* a 64bit Rasperry Pi - with the new Model 3 , even has built in Wifi and Bluetooth
Fidelius
Re: 32 or 64 bit
Tue Mar 08, 2016 7:14 am
dannyk96 wrote:I know this is an old thread, but the announcement now is..
That's true. Now the question of the original thread poster got relevant. ;-)
Heater
Re: 32 or 64 bit
Tue Mar 08, 2016 8:35 am
Almost. We still only have 32 bit operating systems to run on the Pi 3.
ghans
Re: 32 or 64 bit
Tue Mar 08, 2016 8:39 am
99 % of all random "Linux 64Bit" binary downloads will
be for x86_64.
The notion that even half of those website owners
currently care or know about AARCH64 is very optimistic.
Those binary packages will not work on any Pi.
ghans
Re: 32 or 64 bit
Tue Mar 08, 2016 8:54 am
https://en.wikipedia.org/wiki/ARM_archi ... ng_systems
https://wiki.debian.org/Arm64Port
Just need someone / anyone with the time and effort to implement :shock:
rompelstilchen
Re: 32 or 64 bit
Fri Mar 11, 2016 8:05 pm
itimpi wrote:you can only use software specifically compiled for the Pi (which uses an ARM processor). Your question regarding 32/64 bits is only relevant when running a version of Linux on a machine with an Intel compatible processor (such as a typical PC).
all cpu have a pipeline
so question is definetely relevant
6by9
Re: 32 or 64 bit
Fri Mar 11, 2016 9:05 pm
But was asked in December 2012. ARMv8 was announced in 2012, so it wasn't relevant to any realised ARM processors at all, let alone Pi, when the question was asked.
harry4516
Re: 32 or 64 bit
Wed Apr 20, 2016 11:16 pm
Bring it on!
forget about this beast. I have got this board and the debian 64 does not work at all.
There is not even a 2D accelerator for X11, if you move a window on the screen you can get a cup of coffee
until it moves.
