John_Spikowski
Re: Liberation through Computer Literacy
Thu Nov 07, 2019 5:25 pm
I tried running T(s)=100 with Petatami on my laptop and killed it after an hour or so. This doesn't seem to be a viable direction.
ejolson
Thu Nov 07, 2019 5:53 pm
It seems the PET emulator goes to sleep when a Tatami computation is running for some time without receiving input events from the window manager. At least it doesn't snore unlike some pets. That explains why the overnight run didn't finish. I looked on the menu but did not see an entrée to prevent this behavior. Would a different brand of dog food help?
At anyrate, the run just finished with the correct result, so that rules out any obvious bugs.
A computation to find the smallest s such that T(s)=100 is now in progress.
ejolson
Thu Nov 07, 2019 7:05 pm
The former developer of FidoBasic just reminded me a version of Commodore Basic which runs 1000 times faster than the original was mentioned in the previous thread.
https://www.raspberrypi.org/forums/view ... 5#p1453349
The cbmbasic interpreter was obtained by disassembling the ROM memory in the C64 and automatically translating the 6502 assembler into C. When run on the Raspberry Pi 4B I obtained
$ time cbmbasic PETAMI.BAS
T( 8400 )= 10
real    0m4.775s
user    0m4.770s
sys 0m0.000s
Note that since cbmbasic is actually the same interpreter that was in one of the 6502-based 8-bit microcomputers from the golden age, the same memory constraints are in place and the same 5-byte floating-point format is used.
For your reading enjoyment the source code for PETAMI.BAS is
1000 REM COMPUTE T(S) FROM PROJECT EULER PROBLEM 256
1010 REM WRITTEN NOVEMBER 6, 2019 BY ERIC OLSON
1100 N=10:X=2
1120 S=X:GOSUB 2010:IF T<>N THEN X=X+2:GOTO 1120
1160 PRINT "T(";X;")=";N:GOTO 9999
2000 REM CALL T(S)
2010 T=0:I=2
2030 I=I+1:J=INT(S/I)
2040 IF I>J THEN RETURN
2050 IF I*J<>S THEN 2030
2060 K=I:L=J:GOSUB 3010:T=T+F:GOTO 2030
3000 REM CALL F(K,L)
3010 M=INT(L/K):A=(K+1)*M+2:B=(K-1)*(M+1)-2
3040 IF L<A OR B<L THEN F=0:RETURN
3080 F=1:RETURN
9999 END
Woohoo! The Raspberry Pi-powered time machine can now move forward in 4-dimensional spacetime at the rate of 1000 seconds per second.
John_Spikowski
Thu Nov 07, 2019 7:21 pm
We should have a challenge on how to avoid ScriptBasic at any cost.
jahboater
Thu Nov 07, 2019 8:00 pm
jcyr wrote:
Thu Nov 07, 2019 7:44 pm
Looking at the disassembled code, I see that the Pi4 does software integer division! Does the Pi4 not support the IDIV instruction?
Yes the Pi4 has SDIV and UDIV instructions (Signed and Unsigned division), but sadly in 32-bit mode (Raspbian) they only work for 32-bits, and 64-bit division is done by a library routine.
If its doing 32-bit division by software then it may have been compiled for ARMv6 (the Pi Zero).
ejolson
Thu Nov 07, 2019 8:18 pm
Note also if you do any 64-bit division, that the support library included with the system compiler in Raspbian was built to be reverse compatible with ARMv6. Thus, a super-slow routine is used when performing a 64-bit division no matter what compiler options are specified later.
For 32-bit divisions the correct march and mtune options are all that's needed.
Heater
Thu Nov 07, 2019 8:40 pm
John_Spikowski,
I don't know about "how" but "why" does not seem to be much of a challenge.
Joking, only joking, honest :)
ejolson
Thu Nov 07, 2019 9:27 pm
Speaking of avoiding things, is it possible to solve the Tatami challenge in Rust while avoiding the use of mut variables? The vice-president of testing and code review, who claims an official pedigree, wants to know.
Heater
Thu Nov 07, 2019 10:03 pm
I'm not the right person to ask. I'm a Rust newbie and I have no idea what that tatami code is doing or why anyway!
However I'm told that whatever can be computed can be computed with Church's Lambda Calculus and hence Function Programming with no mutables or side effects.
Also there is library support for such Functional Programming in Rust which presumably removes the need for any mutables.
So tentatively my answer is "yes".
Personally I like to have as many mutts, sorry mut's, in my code as possible. As Turing intended.
John_Spikowski
Thu Nov 07, 2019 10:07 pm
John_Spikowski,
You're lucky you're talking to me and not Peter. He would have had your scalp hanging from his belt by now.
Just kidding.
Heater
Thu Nov 07, 2019 10:20 pm
I'm all for a discussion with Peter, or anyone about any programming language. I'm sure they all have perfectly sound reasons for being as they are.
Not so keen on the scalp hunters though :o
ejolson
Fri Nov 08, 2019 1:46 am
jalih wrote:
Thu Nov 07, 2019 12:22 pm
Heater wrote:
Thu Nov 07, 2019 8:33 am
From everything I ever heard about it I got the impression it was some mythic beast of software development that was slain before it could get off the ground.
It truly is a mythic beast with a lot of interesting ideas. I personally applaud the choice of PL/I as the system programming language.
You can run the most current release using simulator and try it yourself!
In addition to PL/I it would appear that Multics includes Basic and C.
  • Thanks to two good programmers and one mathematician, everyone in the golden age had a copy of the language used by the Dartmouth timesharing system to run on their personal computers.
  • Thanks to another good programmer assisted by the multitude, everyone in the second age has a copy of the Unix operating system originally designed for minicomputers to run on their personal computers.
  • Thanks to yet one more visionary and many others, everyone on this forum has a personal computer so inexpensive that it can be included for free with a magazine.
What I find amazing is that, in addition to most modern software, through hardware emulation that inexpensive single-board computer can run almost all software ever written. This lucky circumstance is due, in part, to the efforts of the many unnamed software engineers and hobbyists who carefully curated that historical software as well as the generosity of the authors. Thanks!
jahboater
Fri Nov 08, 2019 3:02 am
And BCPL !!
And a GCOS simulator.
Cool ...
John_Spikowski
Fri Nov 08, 2019 4:52 am
I tried to convert @jcyr's C tatami.c to ScriptBasic but I'm getting a zero returned for tatami(s). It seems to taking about the right time if it was working correctly. Another set of eyes would be great.
' Tatami.sb
nMax = 6700000
nMaxSqrt = SQR(nMax)
SPLITA STRING(nMax, "0") BY "" TO v
FUNCTION Tatami(s)
  FOR i = 7 TO nMaxSqrt STEP 2
    k2 = i + 3
    IF (i * k2) < nMax THEN
      k3 = i + i - 4
      k = 1
      WHILE k2 <= k3
        k4 = nMax / i
        IF k3 < k4 THEN
          k4 = k3
        END IF
        FOR j = k2 TO k4 STEP 2
          v[i * j] += v[i * j]
        NEXT
        k2 += i + 1
        k3 += i - 1
        k += 1
      WEND
    END IF
  NEXT
  FOR i = 8 TO nMaxSqrt STEP 2
    k2 = 1 + 3
      k3 = i + i - 4
      k = 1
      WHILE k2 <= k3
        k4 = nMax / i
        IF k3 < k4 THEN
          k4 = k3
        END IF
        FOR j = k2 TO k4
        NEXT
        k2 += i + 1
        k3 += i - 1
        k += 1
      WEND
    END IF
  NEXT
  FOR i = 0 TO nMax
    IF v[i] = s THEN
      Tatami = i
      EXIT FUNCTION
    END IF
  NEXT
END FUNCTION
s = 100
PRINT FORMAT("The smallest room size s for which T(s) = %d is %d\n", s, Tatami(s))
jrs@jrs-laptop:~/sb/tatami$ scriba Tatami.sb
The smallest room size s for which T(s) = 100 is 0
John_Spikowski
Fri Nov 08, 2019 5:34 am
I changed the code to v[i * j] += 1 but I'm still not getting the correct answer.
' Tatami.sb
nMax = 6700000
FUNCTION Tatami(s)
    k2 = i + 3
      k3 = i + i - 4
      k = 1
      WHILE k2 <= k3
        k4 = nMax / i
        IF k3 < k4 THEN
          k4 = k3
        END IF
          v[i * j] += 1
        NEXT
        k2 += i + 1
        k3 += i - 1
        k += 1
      WEND
    END IF
  NEXT
    k2 = 1 + 3
      k3 = i + i - 4
      k = 1
      WHILE k2 <= k3
        k4 = nMax / i
        IF k3 < k4 THEN
          k4 = k3
        END IF
        FOR j = k2 TO k4
          v[i * j] += 1
        NEXT
        k2 += i + 1
        k3 += i - 1
        k += 1
      WEND
    END IF
  NEXT
  FOR i = 0 TO nMax
    IF v[i] = s THEN
      Tatami = i
      EXIT FUNCTION
    END IF
  NEXT
END FUNCTION
s = 100
Output
The smallest room size s for which T(s) = 100 is 240240
ejolson
Fri Nov 08, 2019 11:14 am
Is the correct answer for T(s)=100 produced by the original C code?
jahboater
Fri Nov 08, 2019 1:45 pm
The original C code says:
The smallest room size s for which T(s) = 100 is 6683040
ejolson
Fri Nov 08, 2019 4:11 pm
It is likely I dismissed the idea of literate programming too quickly.
ejolson wrote:
Sun Nov 03, 2019 5:14 pm
As to the mystery surrounding what the program does and how it works, that's the topic of literate programming
https://en.m.wikipedia.org/wiki/Literate_programming
which, in my opinion, may not generally be as useful as yoga.
Although I've tried to avoid the tangle Professor Knuth created with his vision of literate programming, it's true that mathematical formulas and graphs are often useful in explaining how an algorithm works. For unifying the documentation with the source code, there are two obvious choices:
  • Including a machine understandable version of the source code scattered throughout the documentation, as practiced by Knuth.
  • Including a human understandable version of the documentation scattered throughout the source code, as practiced by others.
When I asked the vice-president of code review which is preferable, the former developer of FidoBasic said, neither is needed nor possible since the current curriculum is fully based on Scratch. I replied, because Scratch is a graphical programming language, it must be possible to include graphs as comments in the code. After that Fido looked at me with head turned sideways, then pawed at one ear. I suspect the dog developer is having trouble hearing after using the turbo encabulator to shred paper.
With Basic the line numbers can be used for cross reference while keeping the documentation and the source code separate. Could true liberation come from Basic or literate programming?
Fri Nov 08, 2019 4:48 pm
Thu Nov 07, 2019 4:10 am
Gavinmc42 wrote:
Thu Nov 07, 2019 2:03 am
Is that farm simulator running on Pi's?
It's running on Windows 10. It's really taking advantage of what my new laptop has to offer.
AllBASIC Forum Thread
So, really, shouldn't be on this forum at all?
Please try to keep on topic. And since my commute home is currently taking twice as long due to tractors, spud and beet lifters, and filthy roads, less farm talk.
John_Spikowski
Fri Nov 08, 2019 5:15 pm
I may have published a bad one along the way.
Are you saying the final C code never produced the correct answer nor was it tested?
John_Spikowski
Fri Nov 08, 2019 6:07 pm
Those tractors are what keeps the world fed. Do you complain when standing in line at McDonald's?
ejolson
Fri Nov 08, 2019 6:12 pm
Thanks for checking.
Is it possible the post was edited after you downloaded the code?
I'll admit my factor.c program originally gave wrong answers--it's correct now. I suspect others make similar mistakes. Fortunately, it's possible to go back and fix things, even without a time machine. If you do so before anyone notices, then all is well. On the other hand, if the bug becomes the focus of further forum discussion, then it is likely better to leave the original post alone and create a new post with the updated code. In either case, to be safe when updating posted code, I think it's a good idea to add a comment of the form
Edit: Updated the code to fix bug.
I didn't follow my own advice for my factor.c program, but have now added a note to this post to inform anyone who might have previously downloaded the code that it has changed.
As before, one of the tasks is to verify all posted code. As this is a challenge rather than a contest, everyone who submits a working program wins. At the same time, all winners must be content with fame only, because there is no fortune due to lack of prizes. However, if any benefactor wishes to supply prizes to all people who submit working code (for example an 8GB version of the Pi 4B), it may be possible to arrange something.
My personal experience suggests that things learned without financial reward are often more liberating anyway than always focusing on the money.
John_Spikowski
Fri Nov 08, 2019 6:22 pm
I'm giving a free copy of ScriptBasic away to anyone coming up with the correct answer.
Last edited by John_Spikowski on Fri Nov 08, 2019 6:39 pm, edited 1 time in total.
ejolson
Fri Nov 08, 2019 6:32 pm
I'm giving a free copy of ScriptBasic away to anyone coming up with correct answer.
Are you sure you don't have any 8GB Pi 4B computers you would like to donate?
John_Spikowski
Fri Nov 08, 2019 6:38 pm
