Andre_Leonardo
PIGPIO daemon
Thu Mar 12, 2015 10:12 am
How to run the pigpio daemon when pi boots to use with python scripts :?:
joan
Re: PIGPIO daemon
Thu Mar 12, 2015 11:17 am
There are several ways.
One of the simplest is adding the following line to the root crontab.
@reboot              /usr/local/bin/pigpiod
Use
sudo crontab -e
to edit the root crontab and add that line to the end. Then ctrl-o return ctrl-x to exit.
Andre_Leonardo
Re: PIGPIO daemon
Thu Mar 12, 2015 11:27 am
Thnx for the help, What are the other possible methods
B.Goode
Re: PIGPIO daemon
Thu Mar 12, 2015 11:34 am
You've had advice direct from the developer/maintainer of the package you want to run: I'd be inclined to listen...
If you really want an alternative you could see what the Raspberry Pi Foundation have to say in their documentation: http://www.raspberrypi.org/documentatio ... c-local.md
Re: PIGPIO daemon
Thu Mar 12, 2015 12:07 pm
joan wrote:There are several ways.
Use
sudo crontab -e
I'd do it with a /etc/init.d/ script and update-rc.d.
# sudo cp /etc/init.d/skeleton /etc/init.d/pigpiod or copy my version down there ... VVV
sudo chmod 755 pigpiod
sudo nano /etc/init.d/pigpiod
#! /bin/sh
### BEGIN INIT INFO
# Provides:          pigpiod
# Required-Start:    $remote_fs $syslog
# Required-Stop:     $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Start the pigpio daemon
# Description:       Start the pigpio daemon during system boot
### END INIT INFO
# Author: Joan <Joan on http://raspberrypi.org/forums>
# Do NOT "set -e" # AND NOBODY KNOWS WHY
PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/local/bin
DESC="pigpio daemon"
NAME=pigpiod
DAEMON=/usr/local/bin/$NAME
DAEMON_ARGS=""
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
# Function that starts the daemon/service
do_start()
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
                || return 1
        start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
                $DAEMON_ARGS \
                || return 2
# Function that stops the daemon/service
do_stop()
        # Return
        #   0 if daemon has been stopped
        #   1 if daemon was already stopped
        #   2 if daemon could not be stopped
        #   other if a failure occurred
        start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
        RETVAL="$?"
        [ "$RETVAL" = 2 ] && return 2
        start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
        [ "$?" = 2 ] && return 2
        rm -f $PIDFILE
        return "$RETVAL"
case "$1" in
  start)
        [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
        do_start
        case "$?" in
                0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
                2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
        esac
  stop)
        [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
        do_stop
        case "$?" in
        esac
  status)
        status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
  restart)
        log_daemon_msg "Restarting $DESC" "$NAME"
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                        1) log_end_msg 1 ;; # Old process is still running
                        *) log_end_msg 1 ;; # Failed to start
                esac
                # Failed to stop
                log_end_msg 1
        esac
        echo "Usage: $SCRIPTNAME {start|stop|status}" >&2
        exit 3
esac
I've stripped out the reload & force-reload functions and lots of the junk in that version.
sudo update-rc.d pigpiod defaults
sudo update-rc.d pigpiod enable
daverck
Re: PIGPIO daemon
Sun Jun 26, 2016 9:42 pm
thank you :)
mmweb
Re: PIGPIO daemon
Mon Jun 27, 2016 4:02 am
While using an RPi 3 Model B, my executable for pigpiod was stored at /usr/bin/ instead of /usr/local/bin/. I thought I'd add to this thread that you can make sure that you are using the correct path in the root crontab by running
whereis pigpiod
raspdroid
Re: PIGPIO daemon
Thu Sep 08, 2016 10:09 pm
viewtopic.php?p=717198#p717198
I have used this script with DAEMON=/usr/bin/$NAME
pi@raspberrypi:~ $ whereis pigpiod
pigpiod: /usr/bin/pigpiod /usr/man/man1/pigpiod.1.gz
But it is not possible to connect from a remote client via socket. I have disable to connect.
868 sudo update-rc.d pigpiod disable
869 sudo reboot
870 sudo pigpiod
This rc file disable the socket interface ?
Best regards
jcummings
Re: PIGPIO daemon
Fri May 12, 2017 3:23 pm
On Raspbian 8 (jessie) with pigpio version 1.60-1 from an apt-get install, I was able to simple run:
sudo systemctl enable pigpiod.service
tomfitzphilly
Re: PIGPIO daemon
Sat Mar 24, 2018 3:58 am
Thanks so much all. on the rpi3 jessie stretch it is, indeed, at /usr/bin
Return to “Python”
